First post, by khyypio
A project video
https://youtu.be/jsPLQ0QkgfA
The attachment post1.png is no longer available
For years I´ve dreamed about a streamlined retro setup containing both PCI and ISA sound cards, and also Voodoo3 paired with Voodoo1. All this working side by side. My latest Win9x machine contains a Voodoo3 2000 paired with Voodoo1, and SB Live! paired with Orpheus2. The sound signal goes from SB Live´s line-out to Orpheus2´s line-in and from Orpheus2´s line-out to the speakers. This enables using both sound cards simultaneously in Windows without switching channels, SB Live set as a preliminary audio device. Works beautifully!
The attachment 11.png is no longer available
The attachment 22.png is no longer available
The attachment 33.png is no longer available
The attachment 44.png is no longer available
MSI MS-6119, Slot1 Pentium 3 600 MHz & RAM 3 * 128 Mb
Voodoo3 & Voodoo1
Sound Blaster Live! SB0100 & Orpheus II LT + X2GS wavetable
USB 2.0 expansion card & D-Link DGE-528T
Fan control, HD dock with SD2IDE adapter
Asus P2B-F
Reply 1 of 11, by AppleSauce
Man that's a really clean and capable build , nice job , i really like the woodgrain as well.
Reply 2 of 11, by JvV
Looks amazing! Watched your video and love you monotone voiceover in it (in a positive way), cool look on how to use the hardware and gave some good ideas!
Reply 3 of 11, by mrzmaster
I always love your builds and look forward to your videos! Great work, and excellent build!
I especially love what you tend to do with cases, in terms of rehabbing them and modding them. Great stuff!
Reply 4 of 11, by Joseph_Joestar
Awesome work with the case modifications! Not sure if you painted or retrobrighted the case and the drives, but they seem to have the same hue now, which looks super clean.
BTW, I don't know what gear you use for recording, but your videos always look really good. Very crisp and with nice lighting. Great production values all around!
Reply 5 of 11, by Intel486dx33
Is that a Bx440 motherboard ?
Those were the most desired motherboards for running windows in late 1990’s
Very stable and reliable.
Reply 6 of 11, by RetroPCCupboard
Very nice build. Very well put together video also. I am curious how many retro pcs you have in active use?
Reply 7 of 11, by khyypio
AppleSauce wrote on 2025-08-25, 14:48:
JvV wrote on 2025-08-25, 18:25:
mrzmaster wrote on 2025-08-25, 19:29:
Thanks guys! 😀
Joseph_Joestar wrote on 2025-08-25, 19:56:
Thank you! I painted them all with off-white. I shoot with my Canon 6D Mark II, f2.8 20-70 mm and f2.8 70-200 mm. For lighting I use two studio bulbs and I use simple adapters to use them in SMDV softboxes that are meant for speedlights. The adapters enables this modification without breaking anything.
Intel486dx33 wrote on 2025-08-25, 19:58:
Yes, both MSI-MS6119 and Asus P2B-F are 440BX boards.
RetroPCCupboard wrote on 2025-08-25, 22:12:
Thanks! I have three builds, two of them are currently in active use: this one and my P4-powered Win98 machine, and they are also hooked up with an ethernet cable for some multiplayer 😁
Reply 8 of 11, by TheIpex
Looks great, very clean. Love your use of Noctua fans.
Reply 9 of 11, by chinny22
You have a very good eye for detail.
I think the brushed metal and woodgrain goes really well, somewhat like how old home stereo systems were.
I also like the mix of modern with old. Like the head spreaders on the RAM sticks, the more modern approach to case cable management.
The V1 and Orpheus + X2GSwill cover dos really well.
Personally I'd prefer an Audigy over SB Live, just to keep the high end feel, I doubt it really matters though.
Video was also really good, I really liked the hardware section when you would light up the item, then turn the light off just before moving to the next item.
Reply 10 of 11, by khyypio
TheIpex wrote on 2025-08-27, 23:56:
chinny22 wrote on 2025-08-29, 02:48:
You have a very good eye for detail. I think the brushed metal and woodgrain goes really well, somewhat like how old home stereo […]
Thanks guys! Cable management has become a very important aspect for me, it really improves airflow when the cable are out of the way and also makes it easier to work with the interior. Considering the games I play with this machine, I doubt upgrading to Audigy makes any difference.
Reply 11 of 11, by igna78
Your build is truly beautiful:
1) aesthetically, it conveys a classic yet modern feel, something truly fascinating 👍
2) technically, it's impeccable, virtually invisible cables, components that are well-suited to the DOS and Win9x eras, providing top-notch audio and video construction 😄
And let me tell you, in the video, you truly look like a professional science communicator! (Or are you?) Congratulations! 😁
