ATI x850xt win 98 No vram
First post, by rotzgurke
Hey
I have finished my win 98 build und finally ran into a Problem (i guess). My GPU shows No vram size. I installed the Last catalyst 6.2 from philscomputerlab site. Installation without any Problems. It is a PCI variant If necessary.
Any ideas or hints?
Reply 1 of 53, by dominusprog
What about the display properties? Try this driver.
https://archive.org/details/ati-8.291
Creative AWE64 Value ❇ 8.4GiB Quantum Fireball ❇ Win95 OSR2 Plus!
Reply 2 of 53, by rotzgurke
Okay, it seems okay so far.
The attachment Screenshot_20250904-203737.png is no longer available
The attachment Screenshot_20250904-203752.png is no longer available
The attachment PXL_20250904_183220831.jpg is no longer available
What kinde Driver you have linked und what should i Test?
Reply 3 of 53, by rotzgurke
Sorry....
Reply 5 of 53, by rotzgurke
I am Not able top Higher the Resolution 🙁
Reply 6 of 53, by dominusprog
rotzgurke wrote on 2025-09-04, 18:41:
dominusprog wrote on 2025-09-04, 11:22:
Are These compatible with x850 series ?
Yes, but remove the currently installed driver first.
Reply 7 of 53, by rotzgurke
dominusprog wrote on 2025-09-04, 18:44:
Alright.....i give it a try.
Reply 8 of 53, by rotzgurke
Best practice for uninstall?
Reply 9 of 53, by rotzgurke
As i thought. No drivers for x850 in your linked package. Max is x600 series uncluded 🙁
Reply 10 of 53, by rotzgurke
I was able to Install 2006_january_4.15.1.9165_9x.zip from philscomputerlab. But manually without Setup. The Setup calls No "inf Driver was found". I have Seen every DLL File in this package Had an Unserscore _ right dl_ and coud Not find the Driver. I renamed them and Installation as Said only manually was possible. No i need controle Center or a way to install via Setup. I am confused.
Reply 11 of 53, by dominusprog
rotzgurke wrote on 2025-09-04, 20:59:
So I've checked the AMD site for the driver, and it supports Windows 2000 and up. Also, read this topic.
looking for x1300 win 9x/ME driver
https://www.amd.com/en/support/downloads/driv … 8xx-series.html
Reply 12 of 53, by rotzgurke
What do you mean?
Reply 13 of 53, by dominusprog
rotzgurke wrote on 2025-09-05, 13:12:
What do you mean?
Your graphics card doesn't support the Win9X. You have to install either Windows 2000 or XP.
Reply 15 of 53, by Duffman
@rotzgurke
The Radeon X850XT should work in win9x.
Is it just the VRAM count not working? are games working?
MB: ASRock B550 Steel Legend
CPU: Ryzen 9 5950X
RAM: Corsair 64GB Kit (4x16GB) DDR4 Veng LPX C18 4000MHz
SSDs: 2x Crucial MX500 1TB SATA + 1x Samsung 980 (non-pro) 1TB NVMe SSD
OSs: Win 11 Pro (NVMe) + WinXP Pro SP3 (SATA)
GPU: RTX2070 (11) GT730 (XP)
Reply 16 of 53, by Dothan Burger
rotzgurke wrote on 2025-09-05, 13:47:
dominusprog wrote on 2025-09-05, 13:38:
What do you mean?
I guess your re wrong. It is supported. See my posted links e.g.
Radeons usually have two instances in device manager. Is there another GPU in the dropdown menu of HWInfo?
Reply 17 of 53, by rotzgurke
I will Check later and reply. I kmow in device Manager are two. Primary ans secondary
Reply 18 of 53, by agent_x007
Should work fine, driver used was Catalyst 6.2 for Win98 IIRC :
The attachment 3DMark 03 X850 XT PE 12GB 2GHz.png is no longer available
Reply 19 of 53, by rotzgurke
The catalyst 6.2 is working ( i already Had that running) but i askes why the vram size is not showing Up and why i am Not able zu Higher the Resolution above or let me say to full hd (target Resolution).
