Reply 30080 of 30086, by NeoG_
yourepicfailure wrote on Today, 07:36:
Shame the panel has yellowed though, this is a mighty fine 9x laptop.
I would be opening the screen and seeing if I can get a new CCFL tube for the display
Retro Rig: SS7 AladdinV, K6-2+/550, V3 2000, 128MB PC100, 20GB HDD, 128GB SD2IDE, SB Live!, ES1868F, PicoGUS, WP32 McCake, iNFRA 6000 CD
Reply 30081 of 30086, by yourepicfailure
NeoG_ wrote on Today, 07:43:
In this case, I hate to be that kind of person but I'm going to leave it alone.
The laptop does have some history (original hard disk has some military documents on it, do not ask for them) and I would prefer to leave it yellowed to show it has history.
I mentioned the T21: The A21e's "really good" sibling. It is unmarred, and would offer a near-identical experience (minus the included floppy drive, slightly smaller screen and S3 Savage IX GPU) to the A21e. But its res is 1400x1050...
The attachment the_T21.jpg is no longer available
The attachment le-T21.PNG is no longer available
EDIT: I forgot... the display mode was set to 16bit color...
Reply 30082 of 30086, by hornet1990
Last night I was all set to have a play with my retro rig and finally put the StarTech IDE-SATA adapter to use with an SSD and install Windows98... until I started the machine up and it just kept either restarting itself or just locking up - in both cases the symptoms were the same. After anything from 30s to a few minutes the VGA would go off, along with the power light on the case (but not the HDD light) and a sound like rapid HDD reads would be emitted from the speaker. It usually wouldn't respond to the power or reset buttons being pressed either. After two hours trying to diagnose the problem I gave up and went to bed thinking I'll be looking for a new mobo over the weekend.
This morning on a hunch I dug out an old (~2010 ish) barely used PSU and swapped it over. Rock solid for the time it took to do two passes of Memtest86+ (good half hour at least).
This is the old PSU.
The attachment psu.jpg is no longer available
And I'm guessing that brown gunk shouldn't be there and is probably the cause of the stability issues?
The attachment leak.jpg is no longer available
On the plus side the replacement PSU has a big slow fan which will improve air extraction in the case no end. The downside is its bigger and I could barely get 3 of the screws in to hold it - the fourth is a no go as it's just ever so slightly offset from the case slot.
I've currently got a Diamond Stealth S540 (Savage 4 Pro) in the machine and I also noticed the heatsink on that gets a bit hot - not uncomfortably so but I think I need to try and get some additional cooling on that too.
Although now the missus is expecting a parcel to arrive next week with "more computer crap"... I'd hate to disappoint her! 😁
https://rogueone.uk Kyro and other things
Reply 30083 of 30086, by yourepicfailure
that gunk is rotting glue, but not the problem right now. I would remove it safely later, after you figure out the stability problem.
check capacitor ratings, which would involve removing some of the glue anyways.
Reminds me, I do need to check on my Nipron Non-Stop PSU. Been going 24/7 for a very long time.
Reply 30084 of 30086, by dr_st
yourepicfailure wrote on Today, 09:03:
These make quite nice Win9x/Me retrogaming systems, with the DOS-compatible audio card and all. I had an A21m for some time, but, alas, it died. 🙁
Reply 30085 of 30086, by PcBytes
hornet1990 wrote on Today, 09:34:
Last night I was all set to have a play with my retro rig and finally put the StarTech IDE-SATA adapter to use with an SSD and i […]
Classic DEER crap. Discard it.
Reply 30086 of 30086, by hornet1990
PcBytes wrote on Today, 11:29:
Thanks, yeah, I wasn’t minded to try fixing it. Possibly a bit outside my comfort zone working on a PSU anyway…
