Reply 30080 of 30103, by NeoG_
yourepicfailure wrote on 2025-09-06, 07:36:
Shame the panel has yellowed though, this is a mighty fine 9x laptop.
I would be opening the screen and seeing if I can get a new CCFL tube for the display
Retro Rig: SS7 AladdinV, K6-2+/550, V3 2000, 128MB PC100, 20GB HDD, 128GB SD2IDE, SB Live!, ES1868F, PicoGUS, WP32 McCake, iNFRA 6000 CD
Reply 30081 of 30103, by yourepicfailure
NeoG_ wrote on 2025-09-06, 07:43:
In this case, I hate to be that kind of person but I'm going to leave it alone.
The laptop does have some history (original hard disk has some military documents on it, do not ask for them) and I would prefer to leave it yellowed to show it has history.
I mentioned the T21: The A21e's "really good" sibling. It is unmarred, and would offer a near-identical experience (minus the included floppy drive, slightly smaller screen and S3 Savage IX GPU) to the A21e. But its res is 1400x1050...
The attachment the_T21.jpg is no longer available
The attachment le-T21.PNG is no longer available
EDIT: I forgot... the display mode was set to 16bit color...
Reply 30082 of 30103, by hornet1990
Last night I was all set to have a play with my retro rig and finally put the StarTech IDE-SATA adapter to use with an SSD and install Windows98... until I started the machine up and it just kept either restarting itself or just locking up - in both cases the symptoms were the same. After anything from 30s to a few minutes the VGA would go off, along with the power light on the case (but not the HDD light) and a sound like rapid HDD reads would be emitted from the speaker. It usually wouldn't respond to the power or reset buttons being pressed either. After two hours trying to diagnose the problem I gave up and went to bed thinking I'll be looking for a new mobo over the weekend.
This morning on a hunch I dug out an old (~2010 ish) barely used PSU and swapped it over. Rock solid for the time it took to do two passes of Memtest86+ (good half hour at least).
This is the old PSU.
The attachment psu.jpg is no longer available
And I'm guessing that brown gunk shouldn't be there and is probably the cause of the stability issues?
The attachment leak.jpg is no longer available
On the plus side the replacement PSU has a big slow fan which will improve air extraction in the case no end. The downside is its bigger and I could barely get 3 of the screws in to hold it - the fourth is a no go as it's just ever so slightly offset from the case slot.
I've currently got a Diamond Stealth S540 (Savage 4 Pro) in the machine and I also noticed the heatsink on that gets a bit hot - not uncomfortably so but I think I need to try and get some additional cooling on that too.
Although now the missus is expecting a parcel to arrive next week with "more computer crap"... I'd hate to disappoint her! 😁
https://rogueone.uk Kyro and other things
Reply 30083 of 30103, by yourepicfailure
that gunk is rotting glue, but not the problem right now. I would remove it safely later, after you figure out the stability problem.
check capacitor ratings, which would involve removing some of the glue anyways.
Reminds me, I do need to check on my Nipron Non-Stop PSU. Been going 24/7 for a very long time.
Reply 30084 of 30103, by dr_st
yourepicfailure wrote on 2025-09-06, 09:03:
These make quite nice Win9x/Me retrogaming systems, with the DOS-compatible audio card and all. I had an A21m for some time, but, alas, it died. 🙁
Reply 30085 of 30103, by PcBytes
hornet1990 wrote on 2025-09-06, 09:34:
Last night I was all set to have a play with my retro rig and finally put the StarTech IDE-SATA adapter to use with an SSD and i […]
Classic DEER crap. Discard it.
Reply 30086 of 30103, by hornet1990
PcBytes wrote on 2025-09-06, 11:29:
Thanks, yeah, I wasn’t minded to try fixing it. Possibly a bit outside my comfort zone working on a PSU anyway…
Reply 30087 of 30103, by Standard Def Steve
Living fairly close to a forest, I find myself discarding deer crap on a weekly basis! 😅
So anyway, as I was setting up a trio of Win98 machines for an upcoming LAN party, I had a bit of an epiphany: It's not a drum, it's a frickin HARD DRIVE!
Specifically, this thing:
The attachment Win98.png is no longer available
For the longest time, I thought that little animation depicted something like a snare drum. But as I was sitting there drooling on the keyboard waiting for Win98 to do its thing, I realized that an animation of read/write heads gliding across what looks like a full-height stack of HDD platters makes a lot more sense!
"A little sign-in here, a touch of WiFi there..."
Reply 30088 of 30103, by pete8475
Standard Def Steve wrote on 2025-09-06, 18:25:
Living fairly close to a forest, I find myself discarding deer crap on a weekly basis! :sweat_smile: […]
It's always been a drum in my mind and I can't unsee it at this point, but your idea does make sense.
Reply 30089 of 30103, by gmaverick2k
Upgraded rgh aurora Xbox 360 to 500gb SSD and loaded complete xbox arcade and a dozen full games using fatxplorer, time consuming but worth it in the end I think 😒
"What's all this racket going on up here, son? You watchin' yer girl cartoons again?"
Main:z440/2699v3/RTX3060Ti/iFiZenDAC/T480 IPS
98:KT333/AthlonXp 2500+Barton/V3 3000/Vortex2/SC-55
DOS:SS7/P166MMX/V3 2000/PicoGus
XP:Edge72/3570K/GTX970/X-FiTi
Reply 30090 of 30103, by NeoG_
I'm going to go out on a limb and say it is a drum and it's supposed to be a visual representation of a drumroll
Reply 30091 of 30103, by pan069
NeoG_ wrote on 2025-09-07, 00:29:
Agreed. It's a drum representing a drumroll trying to represent anticipation.
Reply 30092 of 30103, by Ozzuneoj
pan069 wrote on 2025-09-07, 01:42:
This, definitely a drum... but it is funny to imagine it as a horribly drawn animation representing hard drive read heads and platters... 🤣
If someone wants to look at this to sanity check themselves, here is the animation:
https://oldwindowsicons.tumblr.com/post/66911 … 6839680/drumani
Also, as far as I know, no hard drives have two read heads on the same side of a platter coming from different angles.
Reply 30093 of 30103, by Standard Def Steve
Wow, that...actually makes more sense. I suppose Microsoft really were into the ta-da back then. Fine, it's a drum.
But you know, as Win98 installed that DirectX update this morning -- hard drive clattering away in the background -- a disk activity animation would've been just perfect.
Ozzuneoj wrote on 2025-09-07, 04:44:
Well, this is Microsoft we're talking about. 😉
Reply 30094 of 30103, by BitWrangler
Been futzing with my Epson ActionNote on and off. Arrived early in the year dead HDD, no CMOS battery life...
Anyway, after having it sitting partially open for months (interrupted project, story of my life) I got to looking at what could be done with the CMOS battery... it has a dallas module. Now I saw a webpage where dude said he just swapped it out, because it was socketted, and I first glanced at mine and was "Aw, must be nice." since mine was sitting right down flush on the board. First impression was it was soldered down... then I noticed little raised silvery rings... ahhhh...
Yeah it's got those "socket in pin" individual pin sockets that are like zero profile not just low profile. So eased out the dallas and stuck in a newish one. Yay, full functionality. I had had another HDD plugged in, thinking it was necessary, but it had a translation I could not get this 386 era BIOS to like very much. On a whim, I tried the old (Original?) HDD and found a translation that worked and booted. So that was not dead after all. Kinda boring stuff on there, DOS 6.0, Win 3.1, and some desqview network/terminal kind of setup that did office/admin off a server over modem, no files on it to indicate what really. Might have been legal or medical.
Next job, get the floppy working again... IDK if the connector needs cleaning or I got a micro-crack in the stupid ribbon from unplugging/manipulating. Hate those things.... but know enough to be super careful with them, but that's not always enough when they're old. Was working but crunchy sounding before disassembly, might need some lube, but it's failing to get anything right now.
So interesting lessons here, if you've let any boards sit and wait because Dallas needed desoldering, take a closer look, maybe used those socket pins. They will look "fat" from the back of the board... or you might spot the wider than regular riveted through-hole silver ring around the pins.
Reply 30095 of 30103, by DosFreak
RandomStranger wrote on 2025-09-04, 15:16:
I don't know how does much does this site comply with the rules here. It does the same as REMOVED 'play retro games in your browser' section. A coworker showed this site to me REMOVED
Played a few offline rounds of Quake 3 Arena (man, I got rusty) and a little bit of doom there. To me it works much better than archive.org
Removed links to sites that downloads copyrighted games when you supposedly "stream" them with no proof of permission to do so by the copyright holder(s).
Make your games work offline
Reply 30096 of 30103, by sketchus
I stupidly broke the plastic retention clips that came with my slotket, so I made some really, really basic 3D printable ones. There are more advanced ones available on various sites, but I thought I'd share these in case someone else needs them. They work on my ASUS P2b, with Super Slotket III, they should be fairly universal, but may require some adjustments depnding on what you have.
https://www.printables.com/model/1409113-slot … -retention-clip
Reply 30097 of 30103, by mtest001
I recently discovered the exceptional quality of the Hammond GM-1000 MIDI module... I'm so in love, today I couldn't stop listening to Doom E2M8 soundtrack non-stop: https://youtu.be/ro8y5wNt7Os?t=715
The second part after the drums break is simply amazing.
/me love my P200MMX@225 Mhz + Voodoo Banshee + SB Live! + Sound Canvas SC-55ST = unlimited joy !
Reply 30098 of 30103, by Ozzuneoj
Anyone know why a GTX 770 would simply not work in an X79 motherboard in Windows 10?
I have two different EVGA 770s and I have tried different driver packages (475.14 is the latest), tried DVI and DisplayPort...
With the default Windows 10 drivers from 2020 I was just getting a black screen during startup (not no signal, an actual black screen). Switching to 475.14 (the latest with 770 support) it will crash during the driver install with a garbled screen, and when I reboot the system it will hang with a garbled screen or slowly load a sad face blue screen, where it then hangs indefinitely.
Very odd issue though since it happens with two different cards. I am not familiar with the X79 platform and I haven't used a Kepler based card in Windows 10 in years, so I don't know if there are some hoops I have to jump through to make these work together happily. Any ideas?
BTW, I know this is probably not retro to a lot of people, but none of this 12+ year old hardware is supported by Windows or the manufacturers anymore. If I ask anywhere but VOGONS I'm going to get harassed... 😀
EDIT: Hmm... seems to work if I switch the PCI-E slots to Gen2 in the BIOS? Man... that'd put a damper on my plan to run SLI on this thing...
I am running a 4930K so it should work. Also, a Quadro K2200 (Maxwell based... basically a 4GB GTX 750) works fine without touching PCI-E gen settings.
Googling it I'm not coming up with any reason why an X79 system with a 4930K would not work with a GTX 770 in a Gen3 slot. The motherboard BIOS is fully up to date as well. The board is an ASUS P9X79-E WS.
Reply 30099 of 30103, by tehsiggi
The Hercules Radeon 9600 Pro arrived.. it either does not post.. or if I apply pressure on certain memory IC:
The attachment 2.jpg is no longer available
The attachment 1.jpg is no longer available
The pattern changes, so that's good. No time for it today.. but it'll live again!
As for my X800GTO that arrived.. well not sure, it plays HL2 just fine 😁
AGP Power monitor - diagnostic hardware tool
Graphics card repair collection
