Reply 3160 of 3490, by RaVeN-05
Tested: Nascar 1999 Edition:
cockpit view decrease fps a little bit, external view is faster. (set 39 cars behind and ahead of view in graphic settings)
Richmond raceway have bad clamping texture on grandstand.
Game crashes sometimes due to DMA bug, can't be reproduced (know)
Mouse cursor in main menu get copied over all screen (can be fixed by force screen refresh or draw tiny triangle somewhere) . Menu where we can see our car is being redrawn a lot and do not have that bug.
https://www.youtube.com/user/whitemagicraven
https://go.twitch.tv/whitemagicraventv
Reply 3161 of 3490, by sharangad
https://nirvtek.com/downloads/RReady.Alpha.20250905.003.7z
MD5: 31aafcd95b679fa450069709db37efb6
- Nascar 1999R texture clamping fix
- Whiplash coloured lines at edges of screen fix. V_FIFO_MEM_CLEAR_RECT was being called to erase these, but RReady wasn't filling the entire row and column.
- vQuake1/2/vHexen II should render correctly on AMD R7 250. V_FIFO_QSPAN wasn't working. This is a Rendition Quake specific function call.
ICR2: Colorado, Springs, Continental Divide, Daytona, Croix-en-Ternois and Crystal Palace
https://youtu.be/VlZWkwOvN2M
https://www.youtube.com/@sharangadayananda\
https://patreon.com/Rready
Reply 3162 of 3490, by sharangad
Super resolution:
https://youtu.be/CKQK_JeCjD4
[EDIT]
https://nirvtek.com/downloads/RReady.Alpha.20250907.003.7z
MD5: 650f01dfb146df313af5d2eb19a88677
- Frame gen should work correctly.
[/EDIT]
https://nirvtek.com/downloads/RReady.Alpha.20250907.002.7z
MD5: e054f5f5517c2d43420dda4a07ed2ad9
RLauncher has options for enabling and configuring super resolution. The resolution can be specified directly like 16384x16384 OR as a factor 8 (which for ICR2 would render at (640x8)x(480x8)). Using a factor would be better than using direct resolution as it would eliminate scaling artifacts.
- Extremely alpha Super Resolution support.
To Rendition.cfg add:
super=1 (set to 0 to disable)
superres=5200x3800
https://nirvtek.com/downloads/RReady.Alpha.20250907.001.7z
MD5: e476daff8bb34b1b1398a80514798c50
rttp=1
rttpres=5200x3800
- to disable super resolution , set super=0
- This will internally render at 51200x2300 to a texture and downsample this to the screen resolution. This will allow artifacts in ICR2's rev counter to be corrected (this resolution is an integral multiple of 640 and 480, For vquake, a horizontal and vertical multiple of the in-game resolution would have to be used). The maximum super resolution is 16384x16384, GPU RAM and performance permitting.
- It has been tested to work with vQuakes 1 & 2 and ICR2. vHexen II is currently incompatlble. Other games probably won't work. For a win32 game click on the game in the "win apps" tab and click browse to get to the folder with rendition.cfg. For dos based apps, click on the relevant dosbox.exe in the "DOs apps" tab and click browse to get to the folder with rendition.cfg. For DOS apps, the setting is shared, for Windows apps, each app has its own setting.
- This code has been unused for a few years now, so YMMV.
This codepath isn't recommended for Intel HD graphics.
Reply 3164 of 3490, by sharangad
RaVeN-05 wrote on 2025-09-07, 08:14:
This is not Super Sampling AntiAliasing? or maybe i doing something wrong, i only see that watermark get more clearness or thinness . Rest oscene aliased.
It renders to a texture at a higher resolution and downscales it to the display res.
You can use a higher res like 16384x16384 to see if there's a difference. I'll post a video. Quake engine games have problems with the underwater resolution. Using a factor of 8 should render at 8 times the horizontal and vertical resolution of the game's internal resolution.
It fixes the icr2 rev counter aliasing.
Reply 3165 of 3490, by sharangad
This is not Super Sampling AntiAliasing? or maybe i doing something wrong, i only see that watermark get more clearness or thinness . Rest scene aliased.
It should fix the vquake polygon gaps/coloured edges or at least it should.
Reply 3166 of 3490, by RaVeN-05
When downscaling it's resamples?
Like having 8 bigger resolution and downscaling back it's like nearest 8 pixels, those rgb values must be added in each own separate channels and then devide by 8 or other downscale factor, so this smoothes pixel makes them antialiased.
Maybe nVidia settings need to be dropped or I need some special settings.
I expect this should AA things especially noticeable at far distance objects
Reply 3168 of 3490, by sharangad
120 fps frame interpolation (quad-rate interpolation)
https://nirvtek.com/downloads/RReady.Alpha.20 … 8.001.120fps.7z
MD5: 5ff504bfc1b7a42318964a7b53626966
RLauncher has options for enabling 60 fps (double rate) and 120 fps (quad-rate) frame generation/interpolation. It will currently only work with ICR2, the Nascar games, Die by the Sword and GPL (36 *4 fps=144 fps).
I can't test this because I only have 60 Hz displays, the video I've uploaded to youtube, which isn't available yet, has been captured with vsync disabled. OBS struggles to capture even 60 fps video with super resolution turned on.
Reply 3169 of 3490, by sharangad
RaVeN-05 wrote on 2025-09-07, 10:23:
When downscaling it's resamples? Like having 8 bigger resolution and downscaling back it's like nearest 8 pixels, those rgb valu […]
I render to a texture at a higher resolution and render to a lower res framebuffer. I'm not actually doing the downsampling, the videocard is.
Reply 3170 of 3490, by sharangad
@Been_nath_058 there're a couple of settings in nvidia settings which allow directshow to work with Mw2 and RReady:
I think they're new.
[EDIT] No they're not new.
Reply 3171 of 3490, by sharangad
RReady Alpha (September 12, 2025, 1.0.45) (Fully tested Alpha Release)
https://nirvtek.com/downloads/RReady.Alpha.20250912.001.7z
MD5: 65340dc9755ab39f8b9900d880e284b7
- Initial support for Super Resolution (for ICR2 and N*scar2/1999(
- Initial support for quad-rate (120fps) frame generation/interpolation (ICR, N*scar, Die by the Sw*rd and GPL)
- Corrects vQ*ake 1,2 and vH*xen II QSPAN rendering bug AMD R7 240 GPUs.
- ICR2, internal (in-game) FPS indicator should render correctly.
- ICR2 [Alt+B] auto-brake should activate almost immediately. Keyboard logic reworked.
- Reduced CPU load on most systems. Dual thread systems should run faster.
- Improved DMA mode stability for DOS (Speedy3D) apps.
- Rebel Moon chroma keying bugs in later levels fixed.
- Software rendered ICR2 (Cart.exe) should now be runnable along with Rendition ICR2 (Indyc*r.exe and Cart.exe).
- Internal support for ICR2 polygon transparency. This is disabled by default will be enabled once custom tracks and carsets supporting the feature become available.
- Scorched Planet fixes polygon shading and chroma keying fixes.
- Dosbox-Rendition no longer needs the Microsoft Visual C runtime.
- Frame generation/interpolation for games such as ICR 2,GPL, “Die by the Sword” should work more reliably and will only be enabled for supported games.
- SODA Offroad menus should render correctly with AMD Radeon GPUs.
- Microsoft Monster Truck Madness 2 should detect a V1000 and enable a full graphical feature set instead of running in V2000 mode.
- Dosbox-Rendition and Dosbox-Staging-Renditoin thread prioritization control with threadpriorities=n,m where n and m are between [-1,1]. Default is -1,1.
- vQuake particle alpha bug fixed.
- vQuake cvars d_bilerp and d_dither work correctly.
- [PrintScreen] key should capture the screen for fullscreen DOS (Speedy3D) apps.
Also live on the Windows store.
[EDIT 16 September 2025]
More Rendition Ready tracks (Michigan 2000/1995/1967, Bull Run, Mont Tremblant):
https://youtu.be/B2QZRQv5mEc
Reply 3172 of 3490, by sharangad
@Gona, could you post the resources used in Windows 98 by your 3DBlaster VLB? I'm interested in ports and address ranges. I hope these are listed in device manager.
Reply 3173 of 3490, by sharangad
@robertmo3, I'm trying to build seabios on a Linux VM and I get this:
root@debian:/home/sharanga/Documents/qemu-10.0.0-rc4/roms# make bios
mkdir -p seabios/builds/seabios-128k
cp config.seabios-128k seabios/builds/seabios-128k/.config
make -C seabios \
EXTRAVERSION=-prebuilt.qemu.org \
CROSS_PREFIX=x86_64-linux-gnu- \
KCONFIG_CONFIG=/home/sharanga/Documents/qemu-10.0.0-rc4/roms/seabios/builds/seabios-128k/.config \
OUT=/home/sharanga/Documents/qemu-10.0.0-rc4/roms/seabios/builds/seabios-128k/ oldnoconfig
make[1]: Entering directory '/home/sharanga/Documents/qemu-10.0.0-rc4/roms/seabios'
/bin/sh: 1: scripts/test-build.sh: Permission denied
/home/sharanga/Documents/qemu-10.0.0-rc4/roms/seabios/builds/seabios-128k/src/misc.d:1: *** target pattern contains no '%'. Stop.
make[1]: Leaving directory '/home/sharanga/Documents/qemu-10.0.0-rc4/roms/seabios'
make: *** [Makefile:97: build-seabios-config-seabios-128k] Error 2
The latest seabios from github builds fine but I don't know whether that'll work in an MS-DOS VM.
Reply 3174 of 3490, by sharangad
OK it compiles OK in WIndows but fails to link:
C:/msys64/ucrt64/bin/../lib/gcc/x86_64-w64-mingw32/14.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: scripts/kconfig/zconf.tab.o:zconf.tab.c:(.text+0xdb85): undefined reference to `regcomp'
C:/msys64/ucrt64/bin/../lib/gcc/x86_64-w64-mingw32/14.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: scripts/kconfig/zconf.tab.o:zconf.tab.c:(.text+0xdc1c): undefined reference to `regexec'
C:/msys64/ucrt64/bin/../lib/gcc/x86_64-w64-mingw32/14.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: scripts/kconfig/zconf.tab.o:zconf.tab.c:(.text+0xddc3): undefined reference to `regfree'
collect2.exe: error: ld returned 1 exit status
[EDIT] Just needed flex and bison linked in and now this:
  Working around non-functional -fwhole-program
Build Kconfig config file
Compile checking out/src/misc.o
C:\msys64\tmp\ccfvy2ds.s: Assembler messages:
C:\msys64\tmp\ccfvy2ds.s:301: Error: junk at end of line, first unrecognized character is `/'
[EDIT]
I can build SeaBIOS on Linux. It looks llike I won't be able to carry out custom steps from the BIOS like run DOSClient.exe if I do this.
Miami Homestead 2004 (Day & Night), 1997 and vanilla N3 conversions are now Rendition Ready:
https://youtu.be/Pw0bubBdn7s
Reply 3176 of 3490, by sharangad
Does anyone know how dosbox-rendition is ending up with this error in the debug console:
SHELL: Redirect output to INDYCAR.DMP
DOSBox has switched to max cycles, because of the setting: cycles=auto.
If the game runs too fast, try a fixed cycles amount in DOSBox's options
Speedy3D Initialised!
Connected to pipe Graphics
Connected to pipe IO
Both pipes connected
LLVM ERROR: out of memory
LLVM ERROR isn't from Dosclient and there doesn't seem to be an LLVM error string in the dosbox project.
Reply 3178 of 3490, by sharangad
Makus wrote on 2025-10-14, 14:53:
From what I understand, LLVM is a software component used during the compilation of DOSBox: - https://en.wikipedia.org/wiki/LLVM […]
- https://stackoverflow.com/questions/65468120/ … -if-its-fixable
- https://stackoverflow.com/questions/71992377/ … -up-all-the-ram
I'm familiar with LLVM, but didn't realise VS2022 was using it. I have a user on an Alpha release who's having all sorts of weird issues and I mean really weird. Both the wrapper and dosbox seem to be running out of memory.
Reply 3179 of 3490, by sharangad
Got a crazy problem with a user (Intel laptop/UHD630/GTX1660). Actually this user also had a problem with the store based version running as a different user messing things up, but that's been fixed now. For some reason the Alpha and the store release look like they're running a low colour mode. I am completely clueless as to what's happening. RReady requests a 32 bit colour (RGBA888) with a 24 (I *think*) bit z-buffer:
