First post, by jami3rez
Trying to install Lemmings 2 in pure DOS. It installs both discs fine to C:/L2 but then it gets to the point of creating the l2.ini file and it just hangs.
I’m on a Windows 98 machine using the Super Easy DOS loader and SB Live drivers from Phil’s site. Selected Sound Blaster as my audio and the default IRQ numbers.
Any suggestions?
Reply 2 of 5, by jami3rez
Ah. Any way around it? I have the game files installed on my HDD, it’s just missing the ini file.
Reply 3 of 5, by wbahnassi
Hmmm, I remember this happened to me once. Can you try running the installer under a clean CONFIG.SYS/AUTOEXEC.BAT ? Also it wouldn't hurt to try and "SetMul.exe L1D" before running the installer.
If the above doesn't make a difference, then it's probably another manifestation of the large HDD issue of the game, though that usually results in the game running in demo mode only.. but the installer should go fine.
Turbo XT 12MHz, EGA, MFM HDD
Intel 386 DX-33, Speedstar 24X, SB 1.5, 1x CD
Intel 486 DX2-66, CL5428 VLB, SBPro 2, 2x CD
IBM BlueLightning 100MHz, CL5428, SB16, 4x CD
Intel Pentium 90, Matrox Millenium 2, SB16, 4x CD
HP Z400, Xeon 3.46GHz, YMF-744, RTX2060
Reply 4 of 5, by jami3rez
Yeah tried that and no luck, thanks anyway, guess I’ll just give up on this one!
Reply 5 of 5, by Jorpho
Y'know, I was just thinking about this one today. It's been one of those lingering unsolved mysteries over the years – except, it seems, it's actually been solved. Kinda.
Lemmings 2 Disk Protection
In brief: you can edit two bytes in L2.RKO and thereafter the game will ignore the BOOT and BIOS items in L2.INI. That does mean you still need to get a copy of l2.ini from elsewhere... but that's not difficult.
Bios = 64803
Boot = 65535
Music = 1
SoundFX = 1
Mono = 0
SoundName = "music\adlib.bin"
SoundWord1 = 544
SoundWord2 = 263
FXName = "music\sblast.bin"
Input = 0
Sensitivity = 1
