First post, by renejr902
The system is: 440bx board with Pentium ii 350mhz overclocked to 456mhz fsb 133mhz and 128megs sdram and sb16 with opl3. directx 9.0a and win98se my 3dfx voodoo 3 velocity 100 8mb has a great fan and a very big metal cooler 😉 checked the pictures, enjoy 😀
The card dont get hot anymore, even at the back of the card. I flashed it with modded bios for normal voodoo 3 16mb. copied over the modded glide2x.dll to windows system and each games that needed it and i made the registry hack for 2 tmu. i overclocked it to 166 mhz.
i tried several games... and everything runs great
need for speed ii se in glide mode, nfs porsche max details with glide mode too with edited ini. ( its seem to run at 60 fps with maximum detail at 1024 x 768.
1. But is it possible in glide mode to have higher resolution like 1280 x 1024 in porsche unleashed with this 3dfx card ?
i cant choose higher than 1024 x 768.
2. i know its PII system, but 3dmark 2000 gave me a score of 953. it seems low to me, my 3dfx voodoo3 8mb is so much modded and overclocked, is it a normal score ? ( porsche runs so nicely )
3. Porsche unleashed in D3D at 1024 x 768 with max details runs bad, fraps show between 18fps to 28fps after a racing complete, is it normal with this p2 system and overclocked v3 8mb card ? But in glide mode same settings it seems 60 fps to me. i played glide instead in porsche.
Thanks for answer
Reply 1 of 1, by renejr902
Any idea or topic or tuto that can help me to add ram to it. i know a few people got it to 16 megs. i would like to add at least 4 megs, it would be thw first voodoo 3 with 12 megs, it could be cool and fun.
maybe its enough for 1280 x 1024 and the performance should be better
i find this topic and i just posted a question in it about ram expansion for velocity 100:
Velocity 100 memory expansion
