Reply 20 of 22, by Avenger
Glidos wrote on Yesterday, 13:29:The other texture packs are here: https://www.tombraiderxtra.com/ - the main packs really - some retexture the entirety of TR I.
There are a fair number of new textures in UB, but the texture packs are still useable.
The menu problem isn't that easy. It's the original game binary that looks for those files. I haven't yet worked out what the cause of the problem is.
Not to be a broken record but I have already stated several times what the problem is.
Both menu screen graphics have the exact same file name: "TITLEH.PCX". Therefore, they can't both be in the same "data" folder directory that TombATI looks in for said file at the same time.
If you put the base game's "TITLEH.PCX" in the "data" folder both Tomb Raider and Unfinished Business will use that asset for the menu graphic. If you put in Unfinished Business's "TITLEH.PCX" in the "data" folded instead then both Tomb Raider and Unfinished Business will use the Unfinished Business asset for the menu graphic.
TombATI has to be able to load both and display the correct menu graphic based on which game is being played.
