First post, by Half-Saint
- Oldbie
Hey guys,
I have this weird Abit TX5 motherboard with missing ATX connector. GND and +5V pins are bridged with two resistors in parallel. I thought that maybe somebody removed the connector but soldering on the bottom side is pretty consistent so I'm not 100% convinced. I'll try to make some decent photos from both sides but I'm just curious, if anyone came across something like this?
It's an early revision of the board but I can't find a single image of a TX5 board without an ATX connector.
The board works just fine with an AT power supply.
Cheers
