Reply 2380 of 2508, by bertrammatrix
Chadti99 wrote on 2025-09-17, 00:28:feipoa wrote on 2025-09-16, 23:46:Chadti99 wrote on 2025-09-16, 20:56:I ended up sourcing another m919 and this one seems to be quite a bit more stable although still inconsistent between boots.
That sounds like the majority of M919's. Maybe it's related to their thin and springy motherboards.
Agreed, you’ve warned me a few times. So far I got through a Windows install no problem but crashes when it finally boots to the desktop. I should really give up on this board.
I also tested the 1:1 pci thing recently with my 180 setup and no go. I used cards that have proven to work at a 60+ mhz bus on other boards previously. My matrox g200 would make it as far as dosbench after being hot switched and then freeze shortly into anything, my sis 6326 wouldn't even make it that far. I suspect they would if I relaxed cache timing....however experience tells me that the loss of speed from relaxing cache is not worth faster pci, so I'm not pursuing the 1:1 avenue any further
Do you have the same crash after windows install /desktop even if you slow down to 180? Also, if you run the quake benchmark from dosbench at 640x480 does it complete, or does it crash? Because if it crashes that just means that cpu won't run 200 reliably
Edit: one more thing if pursuing windows on these- I found both with the matrox card AND with a cl gd5464 laguna VGA card I was using I would have to turn off bus mastering in the driver's (and usually had to use the manufacturers driver for this as the windows one didn't offer it). If i did not, there would be trouble.
