Reply 700 of 764, by JustJulião
Gona wrote on 2025-02-15, 07:51:
According to vetz and Putas tests with PowerVR Midas3, Rendition Verite cards give the best compatibility. Furthermore with Tomb […]
JustJulião wrote on 2025-02-13, 02:16:
Which 2D card are you using for PowerVR? Unlike for 3DFX, it matters. Both for speed and compatibility.
According to vetz and Putas tests with PowerVR Midas3, Rendition Verite cards give the best compatibility. Furthermore with Tomb Raider PowerSGL patch (both PCX1 and PCX2) there are resolutions which are only available if Rendition Verite is present as a 2D card (although there is rare lagging in the most popular/playable 640x480).
In DOS the Tomb Raider PowerSGL patch (both PCX1 and PCX2) in 640x480 resolution I have found the Cirrus Logic CL-GD5436 as the most compatible (3rd column from the right here).
Although with OpenGL (GLQuake) Putas experienced 20% scores drop with Verite 2x00 and Trident Blade 3D and used Virge GX2 instead.
I did many tests too https://docs.google.com/spreadsheets/d/1p3G-l … dit?gid=0#gid=0
The Verite 2100 was one of the best for me too, but it was impossible to go below 640x480 in my testings, which can sometimes be a shame.
It's also hard to recommend since it's not cheap.
I had excellent results with a Cirrus Logic card too, the 5465 Laguna3D. Compatible and fast. RD-RAM might have helped here.
The best inexpensive solution to me is the Rage 128 Pro with old drivers (I found this out after my testings so it's reported to have bugs in my table).
The most intriguing was the Chips B69000, poor compatibility but very fast on Quake II. It's not that noticeable in the chart, I suspect minimum fps to be better than on the others. Again it could be related to RAM (it's directly on-chip).
Reply 701 of 764, by RaVeN-05
ok Matrox Impression games do not run on other Matrox video cards for sure.
i am managed to remove hardware check of Sento game and it crashes on any video card, even om Matrox Millenium.
So low level emulation LLE needed to run those games/ software written for Matrox Impression.
Currently 86box can emulate Matrox Millennium / Millennium II/Mystique / Mystique 220. The Matrox Impression probably can be a different chip with different 3d capabilities than those already emulated later Matrox cards.
Or maybe i am not careful enough on removing hardware check.
This is what i get
https://www.youtube.com/user/whitemagicraven
https://go.twitch.tv/whitemagicraventv
Reply 702 of 764, by marxveix
Ati2ddad 4.11.2611 drv is RageXL agp CIF compatible, i can already say that now with 5.38 base + modded 5.40 files made it to work@RageXL agp, downgraded Macxdd32 makes Rage2 to RageXL range work. Also it may work with Mobility AGP. For the Rage XL PCI (4752) or Rage XC PCI (4753) i have no or less hopes.This driver is tested with clean Windows 98 SE and DX6.1, this is the best or latest out there for CIF so far and no need to use multiple drivers, just one clean driver.
I share here also my Rage2/Rage3 new beta driver, thats modded 4.11.2611 driver works@RageXLAGP.
Someone with Rage Mobility (Rage3 based) could also test it. Rage XL PCI i have less hopes, this driver
got R3DVD playback imported also from Ati2ddad and 2611 is compatible with Rage2 Direct3D / 3DCIF.
RageXL has 3DCIF/Direct3D/OpenGL/ATiDVD, maybe Brenders and ATi Video Player should also work.
3Dfx emulator added from XGL200 and some more, MPEG1 gamma @menu maybe, d3d 8bit pallete.
OpenGL 8bit palleted textures over D3D->OGL wrapper only, but that also should work if @D3D work.
Macxw4.inf has readme inside, this is not my ideal rage2/rage3 final driver, but its more closer there.
bat file shoul be executed after or before install even with or without 3dfx emulator. Thank you all!
Some testing and tips would be helpful, 90% sure that with more hexedit no need to downgrade R2.
5043 Macxdd32 needs atid3d.dll correcty inputed, made some name changes inside ati2ddad files.
Best ATi Rage3 drivers for 3DCIF / Direct3D / OpenGL / GLUT / DVD : ATi RagePro drivers and software
33+MiniGL / OpenGL Win 9x dll files for all ATi-Rage3 based cards : ATi RagePro OpenGL files
Reply 703 of 764, by RaVeN-05
From matrox Impression datasheet document:
You can install
4 matrox Impression cards into one pc.
". Installation of up to four boards in a system"
Matrox impression Proprietary API called SXCI
"SXCI is a complete 2D/3D API which fully
exploits MGA’s hardware acceleration capabilities."
Also there should be way more documents:
Can anyone upload or point me there?
"1 .I .7 Documentation
Other documentation available for Matrox MGA products includes:
H MGA TITAN Specification (103 l&MS)* A description of the Matrox MGA TITAN chip.
. MGA ATLAS Specification (10348-MS)* A description of the Matrox MGA ATLAS chip.
. MGA DUBZC Specification (10232-MS)* A description of the Matrox MGA DUBIC chip.
. MGA SDK Manual (10330-MF) A user/reference manual for the MGA software
developer’s kit for DOS and Windows 3.1.
. MGA DynaView /2D for AutoCAD A user/reference manual for the Matrox MGA
Manual (10345MN) DynaView driver for AutoCAD and 3D Studio.
n MGA Supplemantary Drivers Manual An installation/user manual which describes our
(10352-MN) OS/2, Windows NT, and MicroStation PC drivers, as
well as the MGA WinSqueeze! and ConsistentColor
programs for the Windows platform.
* Like the ATHENA Specification, these are restricted documents. See your Matrox Sales representative
for more details.
The PCI Bus Specification from the PCI Special Interest Group contains additional information on
hardware implementation for the PCI architecture."
Reply 704 of 764, by DosWin
I've tried to make a python script to scan exe files to detect DirectDraw and D3D in the first place but then decide to wide functionality for detecting other APIs. Not all detects because some games uses another methods to link and detect API libraries and card presence (as example - Battle Race, Grand Prix Legends, Myth: The Fallen Lords).
Take a note its wasn't full my work - I've used Qwen2.5-Max.
Reply 705 of 764, by RaVeN-05
Hello. Please help in development of Creative 3D Blaster VLB wrapper/emulator.
Original Message RReady (Rendition Verite & CGL wrapper) Test Build (Alpha 1)
"Quick test for someone with a 3D Blaster VLB:
https://nirvtek.com/downloads/SMODEVLB.20250522.001.7z
MD5: 4fa8357c9ddd9b4afa8e06adb075f08d
Run SMODEVLB > vlb.txt.
Attach the VLB file or its contents or share it somehow."
Reply 706 of 764, by B24Fox
RaVeN-05 wrote on 2025-01-14, 14:20:
Who is brave enough to throw out 10k usd for tasmania3d? i want it but i can't go like this OMG!!!
https://www.ebay.com/itm/276815520799?mkpid=0 … 20799&recoPos=1
I think that's @Ozzuneoj 's card.
He has(or had) 2 of them. Here's his thread: Paradise Tasmania 3D 2MB PCI - First Generation 3D Accelerator
Reply 707 of 764, by marxveix
My latest 5.40x2611 drv takes now Rage2 up to RageXLAGP cards
Re: ATi RagePro drivers and software
Direct Vogons download link:
download/file.php?id=227500
Reply 709 of 764, by Dipshidian
@vetz I couldn’t help but notice that the A-Train 5 video link isn’t available anymore. You have my permission to use footage from my YT channel if you want to. This shows off the game’s tech: https://www.youtube.com/watch?v=V2mu23t218A
Your friendly source of public-domain PC game video captures on period-correct hardware! Youtube: @dipshidian
Reply 710 of 764, by vetz
Dipshidian wrote on 2025-10-18, 12:53:
Thanks! Fixed link
Reply 711 of 764, by marxveix
Some intresting new games and utilities listed as ATI CIF and two ATI CIF utilities where released and available when this list was made.
Croc is here as Brender game.
Games
Toshinden / ATI CIF
Space Rox / ATI CIF
Terracide / ATI CIF
Mechwarrior Mercenaries / ATI CIF
Flying Nightmares 2 / ATI CIF
Croc / Brender
Utilities
Extreme 3D / ATI CIF
Photosuite / ATI CIF
Reply 712 of 764, by vetz
marxveix wrote on 2025-10-21, 15:36:
Some intresting new games and utilities listed as ATI CIF and two ATI CIF utilities where released and available when this list […]
Games
Toshinden / ATI CIF
Space Rox / ATI CIF
Terracide / ATI CIF
Croc / Brender
Utilities
There are many of these lists which promised more support than was actually released. Unless someone can provide proof that a version of these games support ATI CIF then they can't be added to the list.
Reply 713 of 764, by marxveix
vetz wrote on 2025-10-21, 19:46:
Games
Toshinden / ATI CIF
Space Rox / ATI CIF
Terracide / ATI CIF
Croc / Brender
Utilities
Extreme 3D and Photosuite has ATi CIF as they where released already (not games).
Others are questionable yes and Flying Nightmares 2 was cancelled game i think.
Space Rox i have heard first time, what game is it?
Reply 714 of 764, by marxveix
Is there list of pc games that had no software renderer? The first games that had no software renderer was Descent 3 and Quake 3 as i know.
Here is the list of games that support sofware renderer:
https://www.pcgamingwiki.com/wiki/List_of_sof … rendering_games
Bit of googling and Turok was one the first pc games that abandoned software renderer.
https://www.reddit.com/r/boomershooters/comme … e_the_first_pc/
Reply 715 of 764, by marxveix
G-Police@3DCIF with Rage2 2MB up to Rage XL 8MB AGP
Rage3
Rage2
Reply 716 of 764, by Dipshidian
marxveix wrote on 2025-10-25, 11:30:
Any game in the early 3D accelerator days that was tied to a specific API as bundled software sold with a card could likely be considered the first games with no software renderer. I’m sure games bundled with the Tasmania 3D, and most definitely games bundled with the NEC PC 3DEngine (PowerVR PCX1) like ReVolte, required said cards to run at all.
Reply 717 of 764, by leileilol
Could pin it to 1995 with Rebel Moon. It does have a secret software rasterizer in it but it's unplayable on 95's CPUs though
Debian's fucked
Reply 718 of 764, by marxveix
Dipshidian wrote on 2025-10-27, 19:03:
Thank you for the input. From Directx8.1 Software mode was abandoned, i would like to have list of games with Direct3D / OpenGL games where Software mode was not available. The older the titles, the better. Turok 1 had Direct3D, but no Software mode and no OpenGL. Lets say ATi Rage Pro does not support OpenGL 1.2 or newer, but the game would at least start with OpenGL to Software mode tool if Sotware mode was not available, one such tool seems to be DarkGL.
https://en.wikipedia.org/wiki/DirectX
http://users.atw.hu/darkgl/index.html
Software mode or Direct3D and OpenGL is not main topic here, but i did not find this kind of list where no software mode available.
leileilol wrote on 2025-10-27, 20:06:
Thank you leileilol. Good if the game has Win9x support as well, this is dos game probably and has no OpenGL or Direct3D support i think.
Reply 719 of 764, by Dipshidian
I originally hesitated to mention Rebel Moon exactly because I had a feeling someone would point out that "nuh uh, it has a -vga command line option to run in software mode so it doesn't count" but it's very much true that it wouldn't have been a very practical way to enjoy the game when it was new (unless you had an x86 supercomputer processor from the future, somehow). This would be no different from having the option of emulating Direct3D instructions in a game that otherwise requires a 3D card. Sure, it technically can be "software rendered" but what good is a software renderer that doesn't even try to run the game with any kind of efficiency?
