Reply 440 of 624, by GeorgeMan
- Oldbie
5a796d wrote on 2025-09-18, 05:04:My current system (sblive/a7v600-x/win98) with unfortunate does not detect the sound card in the DOS games started by Win98, des […]
My current system (sblive/a7v600-x/win98) with unfortunate does not detect the sound card in the DOS games started by Win98, despite having everything in place (Drivers, IRQ, conflicts etc.
) I know the problem is the KT600 chipset (a7v600-x) that no longer supports nmi.I have an audigy 2 ZS, reading in the first post, reference is made to the advice to use the audigy instead of the release because the latter has compatibility problems.
Now I wonder: My Audigy 2 ZS on the KT600 and the sb16 emulation is detected?
I have an A7V600 with 98se and an Audigy 2 ZS and I can tell you it works.
But it's hugely resource dependant and you have to fiddle with different PCI slots.
HP Elitebook 14 G1a | Snapdragon 12core | 32GB LPDDR5X RAM | Adreno GPU | 32" AOC 75Hz 2K IPS + 17" DEC CRT 1024x768 @ 85Hz
Windows 11 on ARM --> pcem ARM | Eden & Dolphin ARM editions
