Reply 20 of 23, by Kahenraz
pentiumspeed wrote on 2025-09-28, 21:44:
440EX is cost, features reduced chipset and 66MHz fsb. The memory bank is 2 according to the wiki. This probably have to d […]
440EX is cost, features reduced chipset and 66MHz fsb. The memory bank is 2 according to the wiki. This probably have to do with specific memory issues you are having.
Have you tried two memory sticks of 128MB each for 256MB total? This is also what 440EX supports memory max size.
3Dnow and SSE is needed to work correctly which others have seen with both games and video card drivers requirements.
Cheers,
Two sticks of 128MB work just fine and is what I ended up using.
Reply 21 of 23, by pentiumspeed
Kahenraz wrote on 2025-09-29, 14:59:
Cheers,
Thank you for clarification. Please add this in your original report, since there wasn't there originally.
Cheers,
Great Northern aka Canada.
Reply 22 of 23, by marxveix
For my CT-6ESA2 (440EX) MATX board works 1x256mb stick (games also work).
Best ATi Rage3 drivers for 3DCIF / Direct3D / OpenGL / GLUT / DVD : ATi RagePro drivers and software
33+MiniGL / OpenGL Win 9x dll files for all ATi-Rage3 based cards : Re: ATi RagePro OpenGL files
Reply 23 of 23, by FullYes
Interesting thread! I’ve been testing these drivers with my FX5900XT and gotten pretty much identical results! I’m running 45.23 with the inf modded to support this GPU now. After having various issues with later ones
My other system specs
Athlon Xp 2600+ currently running at 1666MHz until I mod the motherboard
Soltek SL75-kav (KT133A chipset)
512mb PC133 SD-RAM (2x256mb) CL2
Sb Awe64
System 1: K6-3 400, MS-5158 (430TX), 256MB SDRAM, Voodoo3 2000 PCI, AWE64 (Dos/95-early 98)
System 2: Athlon XP 2000+, SL-75KAV (KT133A), 512MB SDRAM, FX5900XT, Audigy 2 ZS (late 98)
System 3: i7-2600k, P8P67-M, 2x4GB DDR3-1866, GTX 460 (XP)
