DAVE86 wrote on 2025-09-08, 09:21:I've got a slightly beaten up 'Multimedia Notebook Computer 862'. It's a socket7 notebook. The CPU and heatsink are missing. J […]
I've got a slightly beaten up 'Multimedia Notebook Computer 862'. It's a socket7 notebook. The CPU and heatsink are missing. Jumpers on the motherboard and the internal psu board and I couldn't find the settings on the web. I was wondering if someone might have the manual or point me to the right site. Thanks!
The attachment IMG_20250908_072946.jpg is no longer available
The attachment IMG_20250908_072920.jpg is no longer available
The attachment IMG_20250908_072900.jpg is no longer available
The attachment IMG_20250908_072829.jpg is no longer available
I can help partially? It's gone from the internet of course but google groups / newsgroup archives still had mention of this old page: https://web.archive.org/web/20040610062209/ht … ptop/index.html
It does refer primarily to the FMA86 (which I've got) rather than 862 and there are minor differences like working support for MMX CPUs, so the voltage table might be different.
There are some sub-pages too: https://web.archive.org/web/*/http://teytelma … du/~dim/laptop/*
I found the manual on driverguide.com: the first part: https://www.driverguide.com/driver/detail.php … driverid=616963 and 2nd part: https://www.driverguide.com/driver/detail.php … driverid=616964
But no dip switch settings in those 😒
Something I found helped a great deal the last time I was checking out mystery dip switches was to test with CPU removed, then use multimeter to check voltages, which I think is what you've done. Then an oscilloscope or frequency counter (my multimeter can up to ~50mhz) to check the clock pin to see what dip switch combinations give which frequencies.
The BIOS does show bus speed which helps but it seems like lots of the CPU speeds shown for pentium CPUs are guesstimages rather than exact, so figuring out the bus speed and multiplier is more reliable.
Since it's MMX capable there's probably a dip switch to set the BF1 pin as well as BF0. Then put them all into a table to keep track of what does what and try to guess what the various switches do, like this: Re: Need Help setting DIP Switches for FMA7600 Laptop CPU Upgrade
If anyone else has definitive information on the FMA862 then please mention it, I can't find much specific information on this later model.
edit: driverguide has now become a full-on scam site, here are the manuals:
The attachment 862_2.zip is no longer available
The attachment 862_1.zip is no longer available
