Reply 40 of 837, by marxveix
nd22 wrote on 2025-10-03, 17:17:marxveix wrote on 2025-10-03, 14:11:At the moment i have these Socket 754 cpu-s, maybe i have more: AMD Mobile K8 Athlon XP-M 3000+ – AHN3000BIX3AY, Socket 754 […]
AMD Mobile K8 Athlon XP-M 3000+ – AHN3000BIX3AY, Socket 754AMD Athlon 64 2800+ – ADA2800AEP4AX NewCastle DH-CG Socket 754
AMD Athlon 64 3000+ – ADA3000AEP4AX NewCastle DH-CG Socket 754AMD Sempron 64 2500+ – SDA2500AIO3BX Socket754
AMD Sempron 64 2600+ – SDA2600AIO2BX Socket754
AMD Sempron 64 2600+ – SDA2600AIO2BO Socket754
AMD Sempron 64 2800+ – SDA2800AIO3BX Socket754
AMD Sempron 64 2800+ – SDA2800AIO3BA Socket754
AMD Sempron 64 3000+ – SDA3000AIO2BX, SDA3000AIO2BA Socket754
AMD Sempron 64 3100+ – SDA3100AIO3BX Socket754AMD Mobile Sempron 2800+ – SMS2800BQX3LF L2 256kb Roma Socket 754
AMD Mobile Sempron 2800+ – SMS2800BOX3LB L2 256kb Sonora Socket 754
AMD Mobile Sempron 3000+ – SMS3000BQX2LF Roma DH-E6 Socket 754
AMD Mobile Sempron 3100+ – SMS3100BQX3LFx2 Socet 754
AMD Mobile Sempron 3300+ – SMS3300BQX2LFx4 E6 Roma 128kb, Socet 754
AMD Mobile Sempron 3300+ – SMN3300BKX2BX Albany E6, 62W, Socket 754AMD Turion 64 Mobile ML-28 – TMDML28BKX4LD Socket 754
AMD Turion 64 Mobile MT-32 – TMSMT32BQX4LD Socket 754
AMD Turion 64 Mobile ML-32 – TMDML32BKX4LD Socket 754
AMD Turion 64 Mobile ML-34 – TMDML34BKX5LD Socket 754
AMD Turion 64 Mobile ML-37 – TMDML37BKX5LD Socket 754AMD Mobile Athlon 64 3000+ 1800Mhz (AMA3400BEX5AR ClawHammer CG) Socket 754
AMD Mobile Athlon 64 3200+ 2000MHz (AMN3200BKX5BU Newark E5) Socket754
AMD Mobile Athlon 64 3400+ 2200Mhz (AMA3400BEX5AR ClawHammer CG) Socket 754SMS3300BQX2LF i have 4pcs maybe its better to take out ML-37 and use Sempron 3300+?
It has lower graphics card anyway, still 3400+ is missing from Mobile Sempron + 25w cpu!
Does the Sempron 3300+ and Radeon 9600xt work better together, less bottlenecking???
Of course this Mobile Sempron 3300+ is slower and it has only 128kb cache vs 1mb@turion
3400+ has 256kb and that would be the maximum Mobile Semrpon for Socket754 system2.4GHz i dont have yet, max is 2.2GHz @ my 754cpu collection.
You got quite a nice collection there! You will see some high end CPU's, all desktop versions but exotic ones.
Thank you! 2.4 and 2.6GHz still missing, but yes, its good option of 754 CPU-s.
https://www.cpumedics.com/amd-amn4000bkx5bu-2 … -cpu-processor/
Best ATi Rage3 drivers for 3DCIF / Direct3D / OpenGL / GLUT / DVD : ATi RagePro drivers and software
33+MiniGL / OpenGL Win 9x dll files for all ATi-Rage3 based cards : Re: ATi RagePro OpenGL files
