Reply 1620 of 1648, by NeoG_
Chadti99 wrote on 2025-09-21, 01:01:
Just wanted to share that I received my PicoGUS v2.0 today and the GUS emulation is working great but I've not been able to get a USB mouse working. I have the onboard serial ports disabled on the mobo, I have the PicoGUS in USB mode, the PicoGUS jumper is configured for IRQ3. pgusinit is configured with /mousecom 2. I'm using CTmouse /S23 and it throws the error: device not found. The one strange thing I'm noticing is that the LED's on the mouse go dark after a few seconds of plugging it in, like it's no longer receiving power, moving it doesn't wake it up, and I've tried a couple USB mice now.
I was just reading earlier in the thread, one person couldn't get COM2 to work but it did work with COM1. But also it seems that not every mouse works, people have reported issues with some wireless or wired mice. It's possible if the mouse presents multiple USB endpoints for other functions the PicoGUS firmware may not know which one to use. My suspicion is that this is more common with wireless mice for battery monitoring and pairing, but also may be the case for wired mice with RGB control and other stuff.
Retro Rig: BabyAT AladdinV, K6-2+/550, V3 2000, 128MB PC100, 20GB HDD, 128GB SD2IDE, SB Live!, ES1868F, PicoGUS, WP32 McCake, iNFRA 6000 CD
Reply 1621 of 1648, by justin1985
I'm about to finalise an order for a set of PC/104 PicoGUS 2.0's using UzixLS's GitHub project , which includes the Dream SAM2695 synthesiser. If anyone has any tips or experience with this version, I'd love to hear from you!
It seems with PCBWay that 5 cards essentially cost the same as 1 (apart from the component costs). At most, I'd like to keep two of these, so I'd be very happy to pass the others on at cost price - anyone interested please get in touch! (I'm in the UK, which might make a difference for import duties etc. depending where you are).
Reply 1622 of 1648, by britelite
justin1985 wrote on 2025-09-24, 17:29:
I would definitely be interested in a card 😀
Reply 1623 of 1648, by polpo
New PicoGUS firmware release:
https://github.com/polpo/picogus/releases/tag/v3.2.1
Fixes several regressions in pgusinit:
  • Fixes issue where port settings are parsed as decimal, not hex (fixes /mpuport, /gusport, /cdport, etc.)
  • Fixes /sbport and /gusport commands not passing through option
  • Fixes /wifistatus command
  • Restores /defaults command
General
  • Gives VREG a bit more time to settle at bootup/reset. Should improve stability on initial poweron, after changing modes, or flashing firmware.
Reply 1624 of 1648, by douglar
polpo wrote on 2025-09-26, 13:47:
I'll admit, that bug threw me off for a second when I saw the info message come up with an unexpected port value. Then I gave my monitor a side eye stare and thought to myself knowingly, "I see what you are up to!"
Reply 1625 of 1648, by NeoG_
Phil just put out a video covering the CD-ROM Emulation feature
https://www.youtube.com/watch?v=AkzHC6B1bKY
Edit: Reading the comments it appears that there is a decent amount of interest in physical MKE device emulation for various legacy hardware devices. Obviously the PicoGUS can't do that but it would be interesting if the upcoming PicoIDE eventually had an adapter to make it pin compatible with the physical MKE interface.
Edit2: The v3.2.1 zip file is triggering windows defender so people may have difficulty downloading it on a modern system, I downloaded it directly to the system with the PicoGUS using the Webone proxy and it works fine.
Reply 1626 of 1648, by Chadti99
Pardon my ignorance, what is an MKE device?
Reply 1627 of 1648, by weedeewee
Chadti99 wrote on 2025-09-27, 16:18:
https://en.wikipedia.org/wiki/Panasonic_CD_interface
Do not ask Why !
Reply 1628 of 1648, by FreddyV
It is the CD ROM connector on the Sound Blaster cards
Reply 1629 of 1648, by Niemi_81
Has anyone got Windows 95 sounds working? I can't seem to find correct drivers for SB 2.0 that would work. 🙈 CD-Rom emulation works fine.
Reply 1630 of 1648, by britelite
Just thought I'd mention that I'm still interested, but I apparently haven't written enough posts to be allowed to reply to PM's 😁
Reply 1631 of 1648, by DustyShinigami
Just to check - does the audio of the Pico work in Windows? Or is it purely for DOS? With my other motherboard, it has onboard audio, but my current one doesn't. I was able to daisy chain that with my ISA sound card to get digital audio working. But as the motherboard I'm using doesn't have any onboard audio, I can't. So wasn't sure if I should invest in a PCI card to have that option or if the Pico would solve the issue. Thanks.
OS: Windows 98 SE
CPU: Slot 1 Pentium III Coppermine 933MHz (SL448)
RAM: Kingston 256MB 133MHz
GPU: Nvidia 16MB Riva TNT
Motherboard: ABit AB-BE6-II Intel 440BX
HDD: 30GB - IDE 3; 40GB - IDE 3; 80GB - IDE 4
Reply 1632 of 1648, by Poot36
@polpo Sorry if this has been asked before but is it possible to have a PCB that is 102mm wide to get the cheaper PCB option from JLC PCB? I do realize that it would not reach the back of the computer case but I am ok with that. I would try changing it myself but have no clue how to use the PCB software that it was designed in. The PCB is the V1.2 version.
Reply 1633 of 1648, by myne
Play around with kicad.
It's really not that difficult after a while.
Worst case you screw it up and start again a few times
I built:
Reply 1634 of 1648, by NeoG_
DustyShinigami wrote on 2025-10-03, 15:24:
Mixed results, the devices that the PicoGUS emulates were never that good in the 95/98 environment to begin with since they are pre-directsound. They will produce sound for basic audio playback but you will get stutter and audio dropouts in quite a few programs. If you are planning on spending any decent amount of time in the 95/98 environment I would recommend a PCI card with hardware accelerated directsound buffers anyway.
Reply 1635 of 1648, by DustyShinigami
NeoG_ wrote on 2025-10-04, 08:32:
Great. Thank you. I mean, I might get a Pico anyway for the extra customisation and for DOS based games that will benefit from it.
Looks like I need to figure out what the best PCI sound card is to get.
OS: Windows 98 SE
Reply 1636 of 1648, by Niemi_81
I gave up on Windows audio and installed my trusty ISA Aztech SG Pro II. On DOS side it reads CD images just fine, but i can't get any CD Audio. Settlers 2 informs that there are no CD tracks, Homm2 just hangs and gives a black screen..
Could this be a poor quality usb stick problem, what brand would you recommend?
Reply 1637 of 1648, by Niemi_81
Update on that, Homm2 CD audio plays fine on Win95 version. 👍 Would be nice to get CD audio for DOS too.
Reply 1638 of 1648, by Delphius
I had my Toshiba Infinia open today so I thought it would be a good time to share some photos of a recent addition I have been using for my PicoGUS v1.2 this last month. Originally I had two USB on a PCI slot breakout bracket so that I could easily get OTG access the the PicoGUS from the back. But I found this 5.25" to 3.5" drive adapter on AliExpress that also has 2 USB ports built into the front. I like having access on the front and it also frees up the PCI bracket for another card if I want. I was already using a 5.25" to 3.5" adapter on the front so it made sense to combine it. Unfortunately I do not think these come in beige color, but maybe it would be work around for some 3d print designs for something like this.
The attachment signal-2025-10-08-130146-2.jpeg is no longer available
The attachment signal-2025-10-08-130146-1.jpeg is no longer available
Reply 1639 of 1648, by wargrip
I have a question about running it side by side with a Awe64.
My Awe64 is set to irq 5, dma 5/1, MPU port 300 and I want to use my picogus for midi and then sometimes usb and sometimes gus. I was hoping I could switch between gus and usb in software without messing with jumpers but I'm not sure what irq to use - my understanding is that usb needs irq 3 to be set and gus needs irq 7 - am I wrong? is there an irq setting that could work for both? it is a serial mouse I am wanting to use in usb mode, fyi
Thank you!
