marxveix wrote on Today, 19:57:What Compaq Presario model is this? Its got only 3xpci and 1xamr modem (no agp) and its intel old celeron. Can it be made useful […]
What Compaq Presario model is this? Its got only 3xpci and 1xamr modem (no agp) and its intel old celeron. Can it be made useful? 😀
Man, that is a tough one to track down. Must be a European exclusive?
Using a reverse image search I found a couple pages with pictures of it but no model listed. After much digging, these came up:
https://www.kleinanzeigen.de/s-anzeige/compaq … 623732-228-2761
https://www.amibay.com/threads/compaq-presari … -win98.2446205/
The specs on the second one don't match what you have, but the first may be a very similar model except with a P4 rather than a Celeron.
Problem is, the first link calls it a Presario EVO D310, which seems to be completely wrong since searching for that comes up with completely different computers which are all silver or black.
The second link calls theirs a Presario W0313 / CYMT-5FR103A-IT , but since it has a Duron and an AGP slot, the model number is probably very different from yours.
As for if you could do anything with it... it depends if the motherboard is in usable condition (bad caps, etc.), and if you have any use for a low end Intel box from that time period. I wouldn't expect to be able to play any 3D games made after 2000-2001 on it, even with a decent PCI video card. PCI bandwidth pretty much ensures that game performance will be bad no matter what GPU you put in it. It would probably be a solid system for 1997-2000 games though.
If the motherboard is no good, the caps could be replaced or the case could be used with a different motherboard.
Of course the PSU is probably not worth using either. If it is a standard size, it could be replaced. If it isn't, well.... yeah. It gets tougher. Judging from this page, it looks like it uses a standard sized ATX PSU... https://ogris.de/casehack/
