First post, by joeschmoe40
Or does it only run on the console box?
Reply 1 of 5, by Harekiet
Rank DOSBox Author
DOSBox Author
It should work in a slow way 😀
Reply 2 of 5, by frobme
If your output window isn't opengl, it will work sure. As mentioned it will be pretty slow on updates though.
Since it runs on just about any platform you can think of, why would you want to do this?
Reply 3 of 5, by MiniMax
Rank Moderator
Moderator
Others have asked, maybe tried, but never reported back:
using dosbox under linux only for command line without X
dosbox text mode only over ssh
_________________
Reply 4 of 5, by Harekiet
Rank DOSBox Author
DOSBox Author
It works fine here, running dosbox on my old celeron linux machine with a windows X server. As long as it's not a fullscreen 70 fps updating game it can work pretty decently 😀
Reply 5 of 5, by valnar
I can't see a reason doing this except perhaps running some old style BBS software? OP, do tell!
