Harry Potter wrote on Yesterday, 21:33:
I think your system's too small for disk compression, but if you get a utility such as PKZip or DOSRAR, you can create batch files to temporarily decompress programs, run them then clean up afterward by recompressing them and deleting the uncompressed copy. That should allow you to put more stuff on your hard drive.
Says you. I've run Double Space on a 4,77 MHz 8088 PC/XT no problem (Siemens-Nixdorf 8810 M35).
There was no performance penalty.
Rather the contrary, drive compression even helped performance with the slow MFM HDD.
CPU utilization was no big deal, either, no noticeable slow down.
Now, the OP's Amstrad PC1512 with 8086 and 8 MHz is about 4x as strong.
Anyhow, memory consumption is a valid argument, I think.
Double Space/Drive Space needs a few dozen KB of RAM..
So it's not for everyone. Users with an UMB RAM card are better off here, I think.
Edited.
PS: I forgot to mention. Double Space or Drive Space have a 2GB limit.
So it can't be used to increase capacity of, say, an 2 GB HDD.
It also doesn't like FAT32, I think.
