Reply 140 of 927, by Dothan Burger
- Member
Dothan Burger wrote on 2025-10-11, 03:26:Ozzuneoj wrote on 2025-10-11, 02:25:DFI also made great boards, at least with the LanParty series. […]
shevalier wrote on 2025-10-10, 11:19:Pf... I hate Asus. The best motherboards for AMD were made by Epox. Let's start with the implementation of the BusDisconnect fun […]
Pf... I hate Asus.
Let's start with the implementation of the BusDisconnect function for Athlon XP.
And I still prefer Soltek, although I don’t have their motherboards at the moment.DFI also made great boards, at least with the LanParty series.
I still have my Abit NF7-S 2.0 which has been used in the same PC with the same overclocked XP 1700+ with the same cooler and fan for something like 23 years now. I use it regularly for testing AGP cards still.
I also have an EPoX 9NDA3J, Socket 939 with the Nforce 3 Ultra (AGP) chipset. This was the board that I replaced the NF7-S with when I upgraded back in the day. I originally ran it with an A64 3000+, later used the board in a PC I sold to someone and 10+ years later they asked me for a new PC and gave me this one back, still in 100% working order! Now it has the beta BIOS installed I have it running an X2 4200+.
The board I purchased after the EPoX was a DFI LANParty UT nF4 Ultra-D. Wish I still had that, but it went into another person's system and I'm sure it's long gone. Very likely it ended up with bad caps. So far the Epox and Abit boards are rock solid with no signs of cap issues. 😀
Prior to these boards I had Tyan KX133 (Slot A), ECS K7S5A and a Gigabyte KT333 board. Still have the ECS too, but it needs lots of caps replaced (I did some 12+ years ago, but it needs more now).
Anyway, the EPoX and Abit boards have definitely earned a good name with me. Too bad both companies are no longer around.
Ultra-D and NF7-S are my favorites from back then. The Ultra-D was insane running the memory off the 3volt rail. You'd modify the rail to overvolt to 3.3v with some OCZ PC4000 Gold VX cas 2,2,2,5 1t @ 250mhz ... Good times.
