Reply 100 of 129, by DustyShinigami
- Oldbie
Unfortunately, I'm still having problems. Before looking into Norton Ghost, I decided to re-connect up the drives one by one, which has now caused a new issue. Every time I booted, it kept putting my E drive as the C drive and therefore it couldn't boot Windows. Figured I needed to change the boot order and select the right drive, and while that put the correct drive back to C, it still complains there's no Windows. 🙁 It gets past the Windows logo splash screen, but then gives up. Went back to reformat it again and I'm right back to it complaining that I need to insert the Windows CD in the D drive. I just know that if I try and disable each drive again, I'm just going to wind up going round in circles with it. 🙁
EDIT: Okay, looks like I was wrong. A is considered to be CDBOOT. Whereas F is actually the contents of the Windows 98 CD. Still no idea why it complains about the CD not being in the D drive though. But if it's recommended to install Windows via the CD's setup instead, I'll give that a go and see what happens.
EDIT 2: Christ, it really is never ending with the amount of problems I keep facing. For some stupid reason, the computer has taken it upon itself to label the C drive with a load of weird symbols, so there's no chance of being able to re-type it out to re-create a DOS partition. 🙁
OS: Windows 98 SE
CPU: Slot 1 Pentium III Coppermine 933MHz (SL448)
RAM: Kingston 256MB 133MHz
GPU: Nvidia 16MB Riva TNT/128MB Geforce 4 Ti 4200
Motherboard: ABit AB-BE6-II Intel 440BX
HDD: C, D - IDE 1, CD-ROM - IDE 2, E - IDE 3
