Reply 1020 of 1108, by EduBat
I had a look at the datasheet of the ESS 1868 just as an example and it looks like it allows the driver to setup the device configuration space anywhere between 100h-FF6h so, it may not follow the PnP specs if it doesn't want to.
I guess other sound cards may work in a similar way. It then becomes important to understand what the drivers are doing and/or trying to do.
Reply 1021 of 1108, by LSS10999
rasteri wrote on 2025-10-20, 19:47:
300/310/320/330/340/350/360/370 (+1/2/3) -- MPU-401 MIDI
I've since changed this port range to 30x-37x (x = 0~7) by default with my lpcexp stuffs, because GUS does use ports 3x4-3x7 (where x corresponds to 2x0 base port so if using 240 then 340-347 need to be opened), and that was the reason why I wasn't able to get PicoGUS working in GUS mode before (SB mode works fine).
vsharun wrote on 2025-10-20, 15:14:
Your PicoGUS works in games, like DOOM/Duke3D ? The only thing I have managed PicoGUS to work in - impulse tracker, both Doom/Duke3D (and Descent) failed to init (setup/game start) on Asus, Asrock and Gigabyte mobos I have, while pgusinit - okay. pgusinit just sends some in/out bytes, nothing more.
I have two H61 MSI's - they both okay and PnP friendly (both have populated LPC/TPM header), and recent acquisition - Z87M Gaming now on LDRQ1 soldering session: I will return back with findings.
Haven't tested in detail. With the aforementioned change to the 3xx port range GUS mode now works correctly to the point that GUSDRAM tests pass and ULTRAMID can be loaded without errors.
I did try testing the PicoGUS in GUS mode against DIGPAK but it froze. Maybe it's because I'm using DMA1 instead of DMA3 (since I do want to use its SB mode). I did set ULTRASND to DMA1 and IRQ7 (corresponding to my jumper settings) but I'm not sure if this needs to be set elsewhere also (such as INI file).
SB mode works perfectly fine in games, just that it being only SB2.0 means some games will not be able to enable some advanced effects.
EduBat wrote on 2025-10-20, 22:37:
The question is whether drivers for other OSes than DOS could also try initializing the card via bypass key mode. It should be noted that for ESS audio chips, one may need to use the driver for a different chip if it's operating at a different mode than default.
For instance, if ES1869 is used as a drop-in replacement on a PCB meant for ES1868, then ES1868 drivers must be used instead (ES1869 drivers won't work). This is the case for hkzlab's ES1868 card where I used an ES1869 since I could not source an actual ES1868 at that time, and I'm thinking if it's possible to use ES1868's PnP data on an external ROM to "spoof" the card as ES1868 so the OS will automatically pick the correct driver.
Reply 1022 of 1108, by dartfrog
After doing a bit of research, it seems many "PnP" cards exist in a few different flavors. Apparently a card saying it's "PnP" or having a lack of jumpers really tells us nothing about how they are configured.
I guess the good thing about this wild wild west of PnP ISA stuff; is it's unlikely a card by card basis but rather a vendor by vendor basis.
They can be :
  • Full PnP ISA Spec Compliant Cards
    • Follow complete PnP ISA specification (initiation key -> isolation -> CSN assignment -> configuration)
    • May also support vendor-specific PnP bypass shortcuts (e.g., ESS 1868 bypass key)
    • May also have proprietary configuration utilities with config files (CONFIG.SYS, AUTOEXEC.BAT, *.INI)
  • Partial PnP / Hybrid Cards
    • Do not follow full PnP ISA specification
    • Use vendor-specific PnP bypass only (simpler initialization, fixed addresses)
    • OR use proprietary configuration programs with config files
    • OR support both vendor bypass and proprietary utilities
  • Non-PnP / Legacy Cards
    • No PnP ISA support whatsoever
    • Configuration only via jumpers, DIP switches, or proprietary software utilities
    • May require manual resource assignment in CONFIG.SYS, AUTOEXEC.BAT, or *.INI files
I've done a a full PnP ISA Spec breakdown and an ESS 1868 bypass breakdown with a key differences for anyone who's interested in it.
The jist is that PnP ISA Spec is 4 states across 11 steps and the ESS bypass is 2 states across only 4 steps. Though the PnP ISA Spec has enumeration of other cards and the bypass doesn't.
Standard PnP ISA Protocol wrote:
Standard PnP ISA Protocol (with explicit states) Initial State: All cards power up in Wait for Key state (CSN=0) […]
  1. Send 32-byte initiation key to 0x279
    • State transition: Wait for Key -> Sleep (all cards)
  2. Send Wake[0] command (ADDRESS=0x03, WRITE_DATA=0x00)
    • State transition: Sleep (CSN=0) -> Isolation (all unconfigured cards)
  3. Configure READ_DATA port (ADDRESS=0x00, WRITE_DATA=port>>2)
    • Current state: Isolation (no state change)
  4. Run isolation protocol (72 pairs of reads from Serial Isolation register)
    • State transition:
      • One winning card: stays in Isolation
      • All losing cards: Isolation -> Sleep
  5. Assign Card Select Number (CSN) (ADDRESS=0x06, WRITE_DATA=1-255)
    • State transition: Isolation -> Config (winning card only)
  6. Read resource data (poll Status register, read Resource Data register)
    • Current state: Config (no state change)
  7. Configure resources (set I/O ports, IRQ, DMA, Memory base addresses)
  8. Activate device (ADDRESS=0x30, WRITE_DATA=0x01 per logical device)
  9. Return card to Sleep (optional: send Wake[0] to start enumerating next card)
    • State transition: Config -> Sleep (with CSN preserved)
  10. Repeat steps 2-9 for each additional card (incrementing CSN)
  11. Return all cards to Wait for Key when enumeration complete
    • State transition: Any state -> Wait for Key (CSNs preserved)
ESS 1868 PnP Bypass Protocol wrote:
ESS 1868 PnP Bypass Protocol (vendor-specific shortcut) Initial State: Card must be in Wait for Key state (CSN=0) […]
  1. Send 32-byte bypass key to 0x279 (vendor-specific sequence, NOT standard initiation key)
    • State transition: Wait for Key -> Config (card immediately configured!)
    • Note: This bypasses Sleep and Isolation states entirely
  2. Write low byte of desired I/O address to PnP address register (0x279)
    • Example: For 0x220, write 0x20
  3. Write high byte of desired I/O address to PnP address register (0x279)
    • Example: For 0x220, write 0x02
    • I/O address must be in range 0x100-0xFF8, aligned on 8-byte boundary
  4. Card is now active at specified address
    • Current state: Config (device automatically activated)
    • No isolation needed
    • No CSN assignment needed
    • No separate resource configuration needed
    • Card uses the bypass-specified address immediately
Key Differences wrote:
Key Differences Standard Protocol: […]
Key Differences
Standard Protocol:
  • Goes through all 4 states: Wait for Key -> Sleep -> Isolation -> Config
  • Can enumerate multiple cards systematically
  • Universal - works with all PnP ISA cards
  • More complex, requires full state machine
ESS Bypass:
  • Jumps directly: Wait for Key -> Config (skips Sleep & Isolation)
  • Single card only (no enumeration mechanism)
  • Vendor-specific - only works with ESS and similar cards
  • Much simpler, just send bypass key + address
  • Useful when BIOS/OS doesn't support PnP ISA
EDIT:
A PnP Enabler Utility will likely work in legacy OSes like DOS/9x for both dISApointment/ITE8888. For modern OSes like Vista onward, it will need a kernel driver for I/O port access AND proper OS integration (or risk confusing the OS). NT/2000/XP falls in between: needs admin rights + I/O port driver, but may still confuse the OS since enumeration happens before the enabler runs.
What Happens When OS Gets "Confused" by Hardware Appearing After Enumeration AND Possible Solutions:
  • Windows NT/2000/XP/Vista+
    • Device Manager doesn't see the card (no PnP event generated)
    • Drivers won't load automatically
    • Resource conflicts go undetected (OS thinks IRQ/DMA/I/O ports are free, might assign to another device)
    • Manual driver loading might work but could cause BSOD if driver expects PnP enumeration data
    • Power management breaks (card doesn't suspend/resume properly)
    • Yellow exclamation marks in Device Manager, RESOURCE_CONFLICT BSODs
  • Linux
    • No /dev/ entries created, lspci/lsusb won't show the device
    • /proc/ioports doesn't show resources in use (OS thinks they're free)
    • Manual module loading (modprobe) might work but udev may not create devices
    • Resource conflicts with other devices (kernel warnings, device probe failures)
    • ALSA/PulseAudio can't find the card even though hardware is active
    • dmesg shows I/O conflicts, intermittent hardware failures, possible kernel oopses
  • DOS/Windows 3.1/95/98
    • No confusion! These OSes expect manual hardware configuration
    • Drivers probe hardware directly, no sophisticated enumeration required
    • PnP enabler utility works perfectly
  • Core Problem
    • Hardware exists electrically but not in OS software device tree
    • OS resource manager has incomplete information -> assigns same resources to multiple devices
    • Results: driver load failures, hardware conflicts, system crashes/lockups
    • Only fixable by running enabler BEFORE OS enumeration or using proper kernel driver integration
Can You Fake/Trigger a PnP Event After Running the Enabler?
    • Partially possible using Device Manager "Scan for hardware changes"
    • Right-click "Computer" -> "Scan for hardware changes" triggers re-enumeration
    • BUT: Only works if bus driver supports runtime enumeration (PCI does, ISA typically doesn't)
    • ISA bus is considered "legacy" - no dynamic enumeration support in most systems
    • Alternative: Use SetupAPI functions to manually add device node (requires admin + code)
    • Result: Hacky and unreliable, OS still doesn't truly "discover" the device
  • Windows Vista+
    • Same as XP but even harder due to stricter driver model
    • Could manually add device via Device Manager -> "Add legacy hardware"
    • Must manually specify all resources (I/O ports, IRQ, DMA)
    • Driver must be loaded manually, no automatic matching
    • Breaks on Windows updates, requires re-configuration
    • Result: Not practical for end-users
  • Linux
    • More flexible than Windows - can trigger bus rescans:
      echo 1 > /sys/bus/pci/rescan
    • BUT: Only works for buses with rescan support (PCI/USB, not ISA)
    • ISA bus is legacy, no /sys/bus/isa/rescan mechanism in most kernels
    • Alternative: Manually create platform device in kernel module:
      platform_device_register(&my_isa_device);
    • Can use udev rules to auto-load drivers when platform device appears
    • Result: Requires kernel module, but more feasible than Windows
  • The Real Issue: ISA Bus is Static
    • PCI/USB have hotplug support, ISA doesn't
    • OS expects ISA devices to exist at boot, not appear later
    • Even "faking" the event doesn't solve resource management issues
    • OS resource allocator already made decisions based on incomplete info
  • Practical Workarounds
    • Windows: Use SetupDiCallClassInstaller() API to inject device, or manually add via Device Manager legacy hardware wizard
    • Linux: Create platform device in kernel module, udev handles the rest
    • Both: Reserve resources in OS config before running enabler (kernel parameters on Linux, registry on Windows)
    • Best solution: Don't fake it - run enabler at boot time before OS enumeration (BIOS option ROM, UEFI driver, or early kernel module)
  • Bottom Line
    • Technically possible to fake PnP events, but complex and fragile
    • Requires admin/root privileges, platform-specific code, and deep OS knowledge
    • Doesn't solve underlying resource conflict issues
    • Only reliable solution: Configure cards BEFORE OS boots (DOS/Win9x) or use proper kernel driver integration (modern OS)
I've thought about a dual boot scenario with full reboot but this won't work due to hardware reset, but a boot time configuration stage that chains into Windows via kexec or uefi app without rebooting might be a possible solution for modern OSes.
Using a Dual-Boot Configuration Kernel Approach:
  • The Problem with True Dual Boot (Separate Reboots)
    • Config kernel configures PnP cards -> Reboot -> Windows boots
    • Reboot triggers POST and ISA bus reset (RESET_DRV signal)
    • PnP cards return to "Wait for Key" state, lose all configuration
    • Windows sees unconfigured cards again
    • Only IT8888F PCI config persists (PCI survives reboot)
  • What Might Work: Single Boot Sequence Configuration
    • Don't reboot between config and Windows
    • Bootloader -> Config stage -> Chainload Windows (no reboot)
    • Cards stay configured throughout (Hopefully)
  • Practical Solutions
    • GRUB + kexec: Tiny Linux kernel runs PnP enabler, uses kexec to jump directly to Windows (no reboot)
    • UEFI Shell: UEFI app (.efi) configures cards, chainloads Windows Boot Manager
    • DOS Bootloader: Boot FreeDOS via MEMDISK, run PNPINIT.EXE, chainload Windows (Syslinux/LOADLIN)
    • Option ROM: Flash PnP enabler into ROM on IT8888F card, runs during POST before any OS
  • Summary
    • Full reboot = cards lose config (doesn't work)
    • Boot time config stage + chainload = cards keep config (Maybe)
    • Best: Pre-boot tool that configures then launches Windows in one sequence
    • For DOS/Win9x: Just run enabler in AUTOEXEC.BAT (simplest)
Potential Real working PCIe-to-PCI-to-ISA pathway repository: https://github.com/DartFrogTek/PCIe-PCI-ISA
Using KMDF driver on Win10 PicoGUS PLAYS DOOM SAMPLES VIA PORT IO & DMA!
Reply 1023 of 1108, by vsharun
I have made essinit utility around this bypass key feature with sources (here on the forum attached some pages back) and that help with init some ess1869 cards on the Asus systems (Z87 Gryphon, Z97M, all of the Asus's Z87/Z97 I have) with PnP upper range not routable to the LPC. The card then visible as 1688 in Impulse Tracker (which is okay, SB Pro 2.0 and ess's 44.1kHz 16bit stereo ), because no PnP id available, but control registers the same for the whole family starting from 1688.
Yamaha and Crystal ISA cards has no bypass key functionality.
Yamaha's 719-s exhibits terrible Adlib hanging notes in Wolfenstein3D (I have tested some five different PCBs I have via dISAppointment 0.2), both 8 and 11MHz ISA - no differences.
Crystal cards has terrible Adlib emulation support.
And only ESS'es so flexible and compatible.
Reply 1024 of 1108, by Tiido
YMF71x definitely have a "bypass key" function, although not same as the ESS ones. Instead of normal PnP key sequence you send it Yamaha specific one and the card automatically assigns a Card Select Number to it and you can use it to conf the card without having to go through the full PnP process. It will still need all the PnP specific IO ports to be available to work however. I believe Crystal cards work the same way.
Reply 1025 of 1108, by LSS10999
LSS10999 wrote on 2025-10-21, 02:57:
Haven't tested in detail. With the aforementioned change to the 3xx port range GUS mode now works correctly to the point that GU […]
I just did some GUS mode tests. Not too promising, though kind of ruled out possible incompatibilities with DMA1.
- Tetris Pro (by Michiel Ouwehand) works fine with GUS mode. This game does not require ULTRAMID, and most likely won't be able to run with ULTRAMID loaded as it needs a lot of conventional memory.
- Jazz Jackrabbit works with GUS mode provided ULTRASND has correct values. This game also does not require ULTRAMID.
- DIGPAK (requires ULTRAMID) hangs while testing. The system is not entirely frozen as there are LED activities from the Pico, and if necessary, the system can be rebooted via CTRL-ALT-DEL. An example: when setting music to use GUS, SETM would stuck after starting tests, while Pico's LED blinks slowly.
- Sound tests would finish very quickly without any actual sound output with DUKE3D's setup. Music tests would hang. The system will also hang when actually launching the game.
So with dISAppointment PicoGUS can work in GUS mode but it doesn't work everywhere.
On the other hand, I tested my 82C929 card (not PnP) with this system (MS-7860) and for some reasons, the system refuses to boot (hangs at BIOS screen) with the card plugged. I did a verbose setup (lpcisav) and actually the BIOS set the LPC bus to decode full 800 and A00 ranges, with the other two decoding registers disabled (set to 0x0).
And no, PnP cards still won't get detected. So for now PicoGUS seems to be the best thing to use here, other than non-PnP Creative SBPro/16 cards. ES688 and ES1688 (non-PnP, without ES968) can also be good choices.
Reply 1026 of 1108, by vsharun
LSS10999 wrote on 2025-10-21, 17:35:
You may try bypass-key's ess enabler (claude.ai vibecoded) suitable for some es1868F/1869F cards from here:
Re: dISAppointment - LPC to ISA adapter - ISA on modern motherboards
This will set A220 I7 D1 MPU330. Most of 1868/1869/1898 cards detected (no detection for any 1869FC of mine though), some "set".
After the init, important: duke3d's setup required to proper init of the DMA (IDK why), otherwise in some games there will be no SFX (classic doom for example, while no issues with Apogee drivers, like DN3D and Fastdoom). Just run setup and "sound test". This will also reset left/right swap I have on all of the cards I have, unisound/ess_enabler - both variants suffer.
Reply 1027 of 1108, by vsharun
Some update 😀
Both works at the same time:
PicoGUS still not suitable for gaming but okay for Impulse Tracker which has "IO only" driver, no DMA required . IRQ5 DMA3 MPU300 port 240
ESS's card 1898F - quite interesting rare chip between 1869F and 1869FC, I7 D1 port 220, control port 260h
ranges/masks 200 FC 300 FC 1d0 (forgot the mask) A00 FC will do the trick.
Don't worry PCH will not route "already used by PCI(e)" ports to the LPC so the mask will be applied after PCIe devices (and COM/LPT port ranges which I would like to check by inserting third card - ISA USR Courier with COM3/4).
I think I'll try with AWE64 later on. Leaving AWE64 as SB Pro device with EMU capabilities and PicoGUS in GUS mode with MPU at port 300 line out - line in.
The trick involves several sapphisa/lpcisa runs before unisound/pgusinit.
Reply 1028 of 1108, by LSS10999
vsharun wrote on 2025-11-12, 08:04:
I don't think it's that easy to use AWE64. EMU8000 requires 620, A20 and E20 (if your SB port is 220).
There's simply not enough configurable decode ranges for the purpose.
As for PicoGUS... or rather GUS in general... I'm afraid it might not have been optimized for environments past period-correctness. Some games, such as Jazz Jackrabbit handled it correctly, yet it looks like ULTRAMID itself might be the cause of numerous issues.
I remember when I tried PicoGUS on my AIMB-865, I have to use the version of ULTRAMID recommended by PicoGUS rather than the ones shipped with the game, as the ones shipped with the game would freeze the system when playing audio, while the one recommended by PicoGUS did not.
However, that version (recommended by PicoGUS) doesn't appear to work correctly with a dISAppointment environment, hence all the issues I experienced.
Reply 1029 of 1108, by vsharun
LSS10999 wrote on 2025-11-12, 09:01:
I don't think it's that easy to use AWE64. EMU8000 requires 620, A20 and E20 (if your SB port is 220). There's simply not enough […]
Oh, forgot this hardcoded nature of the AWE line 🙁
the relative positions +400h, +800h, and +C00h from the base port are fixed and cannot be independently customized.
Technically AWE64 will not require 3xx range at all and will fit in four decode ranges this way:
200 fc 300 fc a00 fc <- PnP init ranges (not sure where control register lies like ESS's SET BLASTER = ... Rxxx )
unisound
200 fc 600 fc a00 fc e00 fc <- this will make SB pro and AWE available
and/or
200 fc 300 fc <- this will make SB Pro and PicoGUS's MPU401 300's range available.
According to Polpo, he had hard times syncing timings. I have the very same issue with any ES1869FC cards (very last ISA chip from ESS, after 1869F & 1898F) - no detection or no init at all for all of the cards I have with this IC.
From my perspective PicoGUS still shines with Impulse Tracker playing cleanest samples vs computed ones using es186x ESS's 16 bit 44kHz digital noisy sound.
Reply 1030 of 1108, by myne
Anyone made a board list for this yet?
I've been doing some research, and it makes sense to combine if there is.
It's surprisingly difficult to find a matx board with both ldrqs accessible at a resistor, and a pin header for lpc. Supermicro seem to be the best since the board i looked at used "the standard" header with it all.
Even harder to find a fairly common board (Asus, gigabyte, msi) with ddr3, 2 pci, 2pcie (preferably 16x slots even if they're 4/8x, and a 9x capable lan.
Ideally there would have been a 775 board with the above but I've looked as far as b75.
All of these things exist. So far, not in the same board in my searching.
I built:
Reply 1031 of 1108, by vsharun
myne wrote on 2025-11-26, 09:38:
Anyone made a board list for this yet? […]
So, I have some 10+ boards.
All of the Asuses s1150 I have (Z87 Gryphon, Z97M Plus, Z87-C) has PnP init upper port range (0xAxx and I suppose not only this range) not routable to the LPC by known means. ESS "side band" init via bypass key - ok. Also has LMB misfire even if there's no mouse at all.
Asus P5Q - ok.
Gigabyte's Z87M-D3H and B85M-D3H both okay. The same for Asrock boards. Both ATX and mATX.
I would recommend Gigabyte then Asrock. Asrock boards has issues with win98 - any PCIe graphics adapters I have (x850, 5770 of ATI's, 6800gt/ultra/quadro, 7900gs/quadro,7950gt of Nvidia), resource conflict, not solveable. Gigabyte - okay.
Both Asrock and Gigabyte B85 boards are K-overclockable up to some revision.
MSI's H61 I have two very simple boards - both okay (LDRQ0 only exposed). But at the same time MSI's Z87M gaming seems not okay (no sfx), however I didn't spend much time with diagnostics why.
So for your feature matrix Gigabyte's Z87M-D3H or Z97M-D3H is the sweetest spot.
Most of the PCIe to PCI simple bridges are okay, mean you may connect any PCI lan via cheap bridge.
SATA SSD's are so fast, I have handful of Samsung EVO's, SM883, DC 883 - they're 250Mb's with ease, no need for smartdrive/lbcacache anymore.
No nvme boot for BIOS mode supported however.
Reply 1032 of 1108, by myne
Well, this is it so far.
If anyone wants to host it on a gsheets or something, go for it
I built:
Reply 1033 of 1108, by DJNW
So, another possibly stupid idea: Could this be approached from the other direction and add PC/PCI to a PCI-PCIE bridge? Then hook up a CS4181?
Unless I've misread this, pc/pci mostly just turns isa dma into pci bus mastering and talking to the bus arbitrator?
Reply 1034 of 1108, by myne
Many have tried.
See the last 10 or so pages for the ite8888 attempt that seems to have gone quiet.
The main problem seems to be address routing for dma.
Much like an Ethernet network, chipsets perform routing.
Certain routes are flexible, and others are hard coded.
Making isa work without dma is relatively easy. It is just a media convrter/bridge. Hundreds of industrial boards work this way just fine.
But approximately zero isa sound cards work without dma in the low range <15.
What is a cs4181?
I built:
Reply 1035 of 1108, by DJNW
Whoops, I meant CS4281 - it’s one of the Crystal sound chips that supported PC/PCI, hence my though of whether you could skip the ISA bus and go straight to PCI and mod in PC/PCI to support it.
Reply 1036 of 1108, by LSS10999
DJNW wrote on 2025-12-02, 08:52:
You can't. The last southbridge to have PC/PCI is ICH5 (minus 6300ESB).
Reply 1037 of 1108, by DJNW
I'm wondering if I'm making an incorrect assumption here.
Looking at a spec posted here Does PC/PCI actually require the presence of an ISA bus?
Reply 1038 of 1108, by LSS10999
DJNW wrote on 2025-12-02, 22:39:
I think it's more about the southbridge actually have the functionality as well as the required physical signals to enable ISA DMA over PCI bus.
Since ICH6 this functionality (along with its signals) has been removed, and I don't know of any other chipset past that point with the functionality retained.
Reply 1039 of 1108, by myne
Without looking, if it's what I think it is, then it was on boards as "sblink" (soundblaster), and yes, it was literally a few isa pins on a pin header so pci cards could do dos sound.
I built:
