I haven't messed with my Cyrix CPUs in a while (and was playing more with 486 sockets most recently a few years back), but when I was heavily tinkering with Super Socket 7 CPUs, I realized multiple of my 250 nm (mix of IBM and NS process) 2.9V rated parts would overclock like crazy, typically 233 or 250 MHz rated parts to 3x100 MHz without stability issues when running at stock voltage and windows 98 SE (plus multiple hours of playing Unreal Gold in software render mode, plus in 3DFX mode on). Asus P5A-B with Voodoo 3 2000.
I also discovered they would undervolt well with that motherboard but not necessarily with all (I had some issues on an MVP3 based board, I think Shuttle brand one, but forget right now, and didn't get around to testing on the FIC 503+ I have, or 503A). I routinely ran the 6x86 366 (2.5x 100 rated) at 2.5x 100 on 2.2V without issue as well. (same board has also had good luck running 2.2V K6-III 450 parts at 500 MHz at 2.0V without issue ... that's K6-III 250 nm, Sharptooth, not III+ 180 nm) Caution note on 250 nm AMD parts though: they instantly die at 3.3 or 3.5V, probably at around 3V too. I mean instantly die and might short out the motherboard. (I did that by accident with the jumper settings one time, no POST, and made the breaker buzz in the unusual AT PSU I was using at the time, one that has tripped from shorts before and saved me from destroying a 486 motherboard and CPU at least once due to socket mis-insertion, plus another when a tantalum capacitor failed short ... but 250 nm K6 wise, either it fried the chip itself, or managed to short circuit the surface mounted caps on the chip shorted, not sure; but AMD's 250 nm parts are nothing like the IBM and NS parts in late model 2.9V rated 6x86s)
Note: 350 and 250 nm 6x86 parts were rated at 2.9V and SOME 250 nm parts were also rated 2.2V while other 2.2V parts were 180 nm, so you need to do more digging using the identification guide on CPUShack.
Those 2.9V 350 nm chips I tested also overvolted for prolonged periods at 3.0 to 3.2V (the same voltages I was using for Pentium MMX 233 chips around the same time, though those are 350 nm) and didn't have signs of failure or damage. At the time I hadn't actually realized they were 250 nm and not 350 nm parts, as this was just when I was getting into CPU testing with retro tech stuff around 2010. And that MII 366 was the first Cyrix chip I bought. I vaguely recall trying it all the way up to 3.5V, but I'm not 100% sure on that and as I recally it didn't help pushing the speed any higher than 300 MHz beyond the POST screen.
I also haven't gotten that board to run reliably above 115 MHz FSB, and 115 is hit and miss (though it's hard to tell when it's CPU vs MB limits or a combination). 110 MHz tends to work reliably for CPUs that tolerate it, and I recall getting 330 MHz that way out of that Cyrix MII and maybe another 2.9V rated one, but didn't make it to windows before hanging. (plus it was probably at a higher voltage than I was comfortable with sticking to, and it ran at 300 MHz at 2.9V without issue, so I stuck with that ... I think it also worked at 2.8V at 300 MHz)
I've had no problem running 350 nm cyrix parts at 3.5V for longer periods, though, but mostly did that with 6x86L-200 (150 MHz rated), maxed out at 3x68 MHz (208 MHz) but stable ... also tried running Unreal Gold that way. I believe I've tried 5 different 6x86Ls that way and all did 208 MHz and ran benchmarks + games in Win98SE. I know I also walked back the voltage to see where the minimum overvolt was, but forget the nuanced results. I recall at least some working at 3.3V.
AMD's 350 nm parts also seem to tolerate 3.5V fine (which makes sense given the K-6 233 was factory overvolted to 3.2V and there was at least some rare 3.3V marked examples), plus I believe the same process was used for the AMD 5x86 (or 486 x 5) CPUs which have been pushed to well over 4 volts, though also known to fail at 5V, though not instantly like my 250 nm K6 accident. (I've also had Cyrix DX4-100 486s and PR-75 100 Mhz 5x86s running at 5V without any signs of destruction, but those are on larger fabs than that, .68 micron I think for both cases, and while the absolute rating voltage is below 5V in the MSDS for those chips, I never ran into tendency for failure, but also only ran the 5x86 at 2x66 MHz 5V for a few hours, mostly trying it in DOS running the floppy disk version of X-Wing for extended periods, but also without any of the register enhancements enabled; it ran at 2x60 MHz at 3.5V so I spent more time at that, while I'd already been running multiple of those DX4 100 CPUs ... specifically ST marked ones, not Cyrix marked, for months in an older 5V only 486 board, running at 4x40 120 MHz, playing games on it or running demos almost daily with no issues ... plus one instance where the heatsink had come lose and I hadn't realized it, so it was running really hot, but didn't self-destruct: it was in a tower and the plastic heatsink clamp or clip came half-off, so there was roughly 1 mm of gap between the CPU and heat sink)
All that said, and back on topic with the 2.2V rated Cyrix parts. I haven't risked overvolting the few 180 nm examples I have (several PR 366 266 MHz rated parts, and a single PR 400 3x83 MHz rated part) and also never got around to seriously stress testing the clock speed limits of those. I stumbled on some good ebay deals for those well after I'd given up on hunting them down, but then they popped up from some overseas sellers at reasonable prices. (I believe the same seller that appeared to have a ton of new old stock coming out of China or Hong Kong ... at some point around 2020 they had ST DX4 100 CPUs going for $7 plus offered combined shipping, so I'd picked up a handful of those cheap and was less afraid of burning out ... initially at least; the single Cyrix 5x86 I overvolted significantly was sold for scrap in a batch of surface mounted QFP to PGA adapted 5x86s with bent, mangled, or lifted pins and traces, but about half of them could be un-bent and un-shorted to make function, others probably work but I haven't gotten around to trying de-soldering and re-soldering with an air pencil ... need more practice with that)
I also can't recommend risking the same overvolting I've done, as it's obviously not fool proof. I can just say what my own experiences have been. (plus I would definitely not go above 2.6V for 250 nm AMD parts, from both modern and 90s/2000s era anecdotes, that's the max overvolt that actually works long-term and 2.8V has been known to work for a while and eventually kill the chip ... 2.6V is usually what's required to make K6-2 550 parts run at 600 MHz ... and I haven't tried pushing that rate 2.2V rated 250 nm K6-III 450 to 2.6V to see if it will go to 600, or even 550. I was happy using it at 5x100 at 2.0 or 2.2V for extended periods ... plus someone had lifted the lid on that one at some point, and mounting it was kind of funky ... I didn't try a direct die mount for fear of shorting the chip on the heatsink, so I applied thermal paste to the lid and placed it back on)
