First post, by voodoo1907
Hello is it worth to buy Creative Soundblaster Live 5.1 SB0100 for GA-7ZX with VIA VT8363 and VT82C686A. I've read about many problems with Soundblasters and mobos with this VIA chipsests and Southbridges - is it even worth it to try to make it work, or just leave it?
Reply 1 of 3, by dominusprog
The motherboard have a Creative CT5880 onboard sound chip, I doubt installing a different Sound Blaster card cause any problems. Just remember to disable the onboard chip.
Reply 2 of 3, by dionb
The issue isn't with Soundblasters in general, but specifically between Sound Blaster Live! series (incl 5.1 and Audigy) and the Via 82C686B southbridge. You have the A southbridge so should be OK.
There's no need to disable the onboard chip, you can have multiple sound cards active side by side.
Reply 3 of 3, by voodoo1907
Thank you, so I'll risk it 😀 I'll notify here how it goes.
