Reply 140 of 154, by DustyShinigami
- l33t
asdf53 wrote on 2025-10-22, 03:01:DustyShinigami wrote on 2025-10-21, 22:56:Hmm. Odd. I followed the steps exactly, and the old ROM was removed, but when I installed the new one, it says 50+% but doesn't say if it's done. I was allowed to type in a follow-up command. And then rebooting, the HPT screen still shows 1.25.
You need to write the modified BIOS to your board with Awdflash after you're done with Cbrom.
Okay, just re-flashed the BIOS with the modified version and it's all done. Now on 1.28. It also recognises the drive with the right capacity in the HPT BIOS screen. 😁 Thanks for the help.
However... heh.
I have a couple of follow-up issues. Though the BIOS screen shows the HDD, it fails to show it in Windows. I can't remember what I installed last time, so I may have to play around with some of the tools I've downloaded. Also, one thing I still haven't managed to figure out is why Windows is seeing my D drive twice.
And yet FDISK sees the right number of drives:
I tried loading up SeaGate Tools for DOS, as I used that before when the E drive had the wrong capacity. Like the last time I tried to load it up though, I'm greeted with an error and I can't figure out how to solve it.
I tried enabling/disabling various memory commands in config.sys, but nothing seems to work. I swear last time it just... worked on one occasion.
OS: Windows 98 SE
CPU: Slot 1 Pentium III Coppermine 933MHz (SL448)
RAM: Kingston 256MB 133MHz
GPU: Nvidia 16MB Riva TNT/128MB Geforce 4 Ti 4200
Motherboard: ABit AB-BE6-II Intel 440BX
Sound Card: Sound Blaster Live Value CT4670
