Reply 30360 of 31546, by MutedFFS
Thermalwrong wrote on 2025-10-25, 00:17:
Dual wielding :D Ehh, an SB16 in a 386 is fine but especially since you're using it for IDE. What are you using for a CD drive […]
sunkindly wrote on 2025-10-23, 20:00:
It seems heretical to dual blaster but I had to put in my SB16 into the 386 temporarily for the IDE interface so that I can install Windows 3.0 Multimedia.
The attachment IMG_7598.jpg is no longer available
The attachment dualblaster.jpg is no longer available
Dual wielding 😁
Ehh, an SB16 in a 386 is fine but especially since you're using it for IDE. What are you using for a CD drive now that Windows 3.0 Multimedia is installed?
I tried out that Panasonic Matsushita CR-501B - SCSI Caddy CD drive and there's still something wrong with it 😒 It detects 8 times with any SCSI controller and drive ID# I try and obviously that doesn't work, so I guess there's something wrong with the SCSI sub-board on the drive. That's a shame and I'm ignoring the drive for a while.
MutedFFS wrote on 2025-10-23, 20:41:
Long time reader, first time poster: I have finally finished the building part of my Dual Boot Win98/XP Box last night, albeit […]
I have finally finished the building part of my Dual Boot Win98/XP Box last night, albeit in an old case for which the front panel plastic has long since been lost. Had a quick play with installing the two operating systems and drivers. Very difficult to believe that as a teenager I could build & repair these things in my sleep, and now, some 30 years later, I can't solve the simplest problems.
It also seems to occur to me that a motherboard "Technically" running Windows 98, doesn't mean, it will run it in the real world, without a lot of real world problems. It does run well in XP though,so at least I'm 50% of the way there.
The A-Bit AV8 motherboard, which I bought, following a lot of research on the most modern system that could run both 98SE & XP, it seems to have a LOT of bugs on any 9X version of Windows, despite being shipped with drivers for 98/Me/XP.
Issues that have appeared after just 24 hours, that I am currently working my way through:
1 . Windows 98 works when it wants to, last night I was happily playing some games, today I don't have a mouse, nor a resolution above 800x600 16 colours.
2. Changing to booting off the Win98 drive as opposed to the XP Drive, currently mean removing half the RAM from the system before changing boot drive, and trying various Legacy settings in the BIOS, to see if it's a mouse & keyboard day today or not.
3. Every time I find the correct Legacy USB settings to have a mouse in Windows 98, it decides to run scandisk, and I can't select to skip it, because I don't have Mouse/Keyboard in DOS.
4. My VGA Capture card won't capture anything in MS-DOS mode, ruling out playing anything that isn't native to Windows, at least for streaming/recording purposes.
But I am getting there slowly, by the 40th anniversary of Windows 9X, I should at least be able to open Solitaire 😁
Hey welcome to the forum 😀 That's a pretty late build to run Windows 98 on so maybe that's causing some of the problems, do you have the Via 4in1 chipset driver installed?
I know your pain with the capture card, I got this very interesting 640x480 VGA LCD recently which I thought would be amazing for old games but it's a TV and will *only* do 640x480 and higher, it won't display 320x200 or 720x400 text mode so that's kind of ruined it. No display at all when trying to run DOS games. There are lots of good VGA games though, I was having a lot of fun with Diablo 1 on my laptop that scales VGA perfectly the other week.
I wonder if there's some kind of decent low latency scaler that would do VGA in > VGA out, probably the GBS-Control would do it
Yeah, I hope i can get something sorted out. One of the main aims of this build was to be able to play the original "Theme Park" in real period (ish) correct hardware. It seems a shame that I can't do it on stream, because DOS games just don't seem capturable by this card. I'll keep researching and get there eventually!
MutedFFS - Aspiring Retro gaming streamer - When the d*mn Retro PCs work!
Abit AV8 - Athlon 64 3200+ - Geforce 2 MX 4000 - 2GB DDR - Win98 & XP Dual Boot
i7 10700k - RTX3070 & RTX2070 - 128GB DDR4 - Windows 11 24H2 - With 7 monitors!!
Reply 30361 of 31546, by PcBytes
Two board combos have been selected for 98SE and ME builds.
- ConRoe865PE/C2D E6850 - Windows 98 SE - GPU Radeon 9800
- AM2NF3-VSTA/Phenom X4 955BE - Windows ME - GPU Geforce 7600
Reply 30362 of 31546, by Locutus
Today, my FIC motherboard got socket for easy DALLAS removal.
Someone must have really insisted on making the ’made in Taiwan’ marking not visible… 😆
The attachment IMG_2579.jpeg is no longer available
Reply 30363 of 31546, by Susanin79
Did the initial LOGI PC88XT motherboard inspection
The board has clearly seen better days and shows signs of an unsuccessful past repair, but I’m going to try to bring it back. I started with the obvious: severed traces are restored, questionable ones reinforced, and I’ll reuse the alternative capacitor pads that are in better shape. As you can see it looks not great but most of the pads are good.
Will post an updates here.
Reply 30364 of 31546, by Nexxen
Susanin79 wrote on 2025-10-25, 20:34:
Good job!
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
- Bare metal ist krieg.
Reply 30365 of 31546, by Dan386DX
DarthSun wrote on 2025-10-25, 01:03:
Dan386DX wrote on 2025-10-25, 00:51:
Full reinstall of Windows 98SE on the Socket 7 machine. […]
Opening 'My Computer' was causing a full on freeze; at first suspected the CD-ROM as the issue went away when it was removed. But drive didn't cause issues in other machines.
Full reinstall solved it.
But thinking about it, I'm suspicious that the culprit may have been Daemon Tools. I had only recently installed it when the issue began. Possibly caused a driver conflict with real optical drive?
Yes, DaemonTools sometimes caused problems for me too.
Glad I'm not the only one - I've started using a program I hadn't heard of before; Virtual Clone Drive. Version 5.1.1.1 works on Win 9X and is very lightweight, so far no conflicts or issues!
90s PC: IBM 6x86 120Mhz. 128MB/6GB. ATI Rage Pro 3D.
Boring modern PC: R9 3900X, RX 7800XT. 32GB/1TB.
Fixer upper project: NEC Powermate 486SX/25. 16MB/400MB.
Reply 30366 of 31546, by DaveDDS
Locutus wrote on 2025-10-25, 17:57:
Today, my FIC motherboard got socket for easy DALLAS removal. ...
Wow .. looks like your Dallas RTC hasn't had to be delided yet!
I've had to grind the top off almost all of mine (RTC & SRAMs) to replace the internal bettery.
https://dunfield.themindfactory.com ; "Daves Old Computers" ; SW dev addict best known:
ImageDisk: rd/wr ANY floppy PChw can ; Micro-C: compiler for DOS+ManySmallCPU ; DDLINK: simple/small filecopy(w/o netSW)via Lan/Lpt/Com
Reply 30367 of 31546, by H3nrik V!
Is it retro updating BIOS on a Lenovo M900 motherboard with an i7 6700 to support TPM2.0? I mean, it's from 2016 so 9 years old 🤣
Reply 30368 of 31546, by PcBytes
Repairing an ASUS TX97-E
Reply 30369 of 31546, by picmaster
I'm working on a MyCPU build, which is a complete computer with TTL-based CPU and peripherals. Here's some eye-candy:
The attachment 20251027_004629.jpg is no longer available
The attachment 20251027_004652.jpg is no longer available
The attachment 20251027_004718.jpg is no longer available
The attachment 20251027_005149.jpg is no longer available
The attachment 20251027_005242.jpg is no longer available
Reply 30370 of 31546, by picmaster
More eye-candy:
The attachment 20251027_005252.jpg is no longer available
The attachment 20251027_005257.jpg is no longer available
The attachment 20251027_005335.jpg is no longer available
The attachment 20251027_005351.jpg is no longer available
Reply 30371 of 31546, by picmaster
All credit should go to Denis Kuschel and his wonderful project, I'm just trying to collect the parts and make it work.
Reply 30372 of 31546, by gerry
inspired a bit by this post/thread: Re: DOS Shareware Collection CD
I'm trying to program a simple game in Quick Basic and DirectQB (DQB), not with the aim of making a great game o to have nice graphics or anything, but something complete with a few features
it's a throwback to earlier times 😀
Reply 30373 of 31546, by TechieDude
Fixed my LG Flatron F900B's VGA cable. It sure was a pain in the ass, but at least it no longer pisses itself anymore 🤣
I do, however, get the impression the signal isn't quite as clean now, so I'll probably have to revisit it soon. Still, not bad for a first time replacing a VGA plug
Reply 30374 of 31546, by PcBytes
Unfortunately no dice for the repairing of the TX97-E so far. No beeps and no POST either.
Reply 30375 of 31546, by RetroBus
I know as retro geeks we love Matrox because they are a bit of a rarity compared to the BIG 2, but I had a hell of a time with this Matrox Millenium P650, the Parhelia core was the last chance grasp the Matrox took into the 3D Graphics market, video review below
https://www.youtube.com/watch?v=x40aLdJUsDU
https://www.youtube.com/@ComputerRetroBus Computer Retro Bus - My Youtube Chanel
Reply 30376 of 31546, by Kekkula
I've been trying to get my genoa superega card working.
It works in text mode, but when I try to switch to graphics mode, it changes the refresh rate to 75hz, and not my hp 35743 ega monitor nor rgbtohdmi is able to sync that signal.
I can't figure out the dip switches, and I'm starting to think that my 486 motherboard bios might have something to do with the problem.
https://www.abc80.net/archive/misc/PC/Genoa-s … odel-4850-6.pdf
https://www.dosdays.co.uk/topics/Manufacturers/genoa.php
https://theretroweb.com/expansioncards/s/geno … es-model-4880-9
The card I have is 4880, but I can't find manual for it... I don't think it differs much from 4850.
Reply 30377 of 31546, by yourepicfailure
Well, just when I found time to open up and start fixing the 1740A:
yourepicfailure wrote on 2025-02-14, 06:38:
Someone gave me this scope the other day. […]
The attachment scope-1.jpg is no longer available
The attachment scope-2.jpg is no longer available
But it's got some issues. Learning how to disassemble it so I can test caps.
Will probably have to wait a little to open the CRT driver side.
Either way, this bohemoth is perfect for what I like to play with: old video equipment and old computers.
Someone hands me a 1725A...
The attachment 1725-scope.jpg is no longer available
Sadly don't have the space for both so the 1725A will be the keeper. Will need some fixes, but this will probably be an even better scope for me when I get it going.
Reply 30378 of 31546, by Delerious
Got the right(-ish) drivers to install for my ATI FireGL T2-S64 card. Thank Phil for an old video he happened to have on that particular card.
Now I'm trying to figure out why my mouse stutters when extracting files in Windows 98. That said, if anyone knows why this is, please let me know.
Current builds:
Soyo SY-5ED | Intel Pentium MMX @ 233 MHz | 64 MB SDRAM | ATI Rage 128 PRO Ultra GL | Windows 95/Windows 98 SE
Asus A7N266-VM | AMD Athlon @ 1.0 GHz | 512 MB DDR RAM | ATI FireGL T2-S64 | Windows 98 SE/Windows 2000 Professional
Reply 30379 of 31546, by Ozzuneoj
Delerious wrote on 2025-10-29, 05:49:
Is it a USB or a PS/2 mouse? And what are the specs of the system?
