First post, by carlitosbala
I have in my hands a MORSE P1 motherboard, revision v3.10
The attachment IMG_20251019_193848.jpg is no longer available
Seems to be a weird, rare motherboard model, to the point theretroweb doesn't even have a photo of it (although it does have a useful PDF), much less a BIOS I can try. I have found few references to its 'MORSE 91A401A' chip, a few more but not that many about its 'MORSE 91A402', and while its UMC 82C206L chip is not that rare it seems it wasn't usually paired with 486 CPUs, I get the idea after a few searches that it was used with earlier 386 and 286 boards instead.
This board belonged to a friend who supposedly just had it in storage, having retired it from a working system years ago. It has a 486 DX-33 CPU, 8 30-pin SIMM modules, and 256K of cache. I checked all jumpers and they seem to match the cache and CPU. Visually, apart from a very small touch of corrosion in the battery contacts, it seems to be in perfect state, not even a scratch I can see.
Unfortunately it doesn't work. My POST card shows it stopping at different steps in the boot process. Not that I trust my POST card completely, especially not in an ISA slot, but the board seems to be either failing in early boot (showing '05'), failing in a step seemingly related to RAM (C1) or cache (C5), or moving past that and stop at '00'. Or, instead of doing that, it gets stuck at a seemingly random code. I never get beeps or any signs of life in the video card.
I've tried different cache configurations, with different chips, and also different RAM configurations, but the behavior is always the same. There are no voltage regulators or almost any transistor in the board, power is getting straight from the power connector to the CPU, so really there isn't much that can go wrong. I'm inclined to think the CPU is fried, as the only thing this board does consistently is get it warm after about 10-15s and hot after 30-40s, which I don't think is normal. Unfortunately I don't have another CPU to try, I've been trying to find my 486SX-25 without success...
Any suggestions?
Reply 1 of 13, by mkarcher
A convection cooled 486-33 is perfectly OK, but it is supposed to get hotter than comfortable to touch. A case temperature of around 45°C to 50°C is likely fine.
The UMC82C206L chip is one of a (it feels like) a million of clones of the classic C&T 82C206 chip, which is part of the NEAT AT chipset. While possibly this clone is uncommon on 486 mainboard, most ISA and VL boards up to 486 boards have a 82c206 clone. Even some 486 PCI chipsets still mention in their datasheet that the south bridge "contains a 206 macrocell", which means they cut-and-pasted the 82c206 as a part of a bigger chip. Other parts of the chip may be created from assembling complex logic from simple cells using a hardware modelling process, the 206 is a ready-made block (not a simple cell, but a "macro-cell"). The 206 contains most of the basic Intel chips that make up an 80286 mainboard, for example the DMA controllers, the Interrupt controllers, the Programmable Interval Timer. The 80c206 is (mostly) just an ISA device, and as every board with ISA slots has an ISA bus, it universally fits with any ISA-based board. The presence of a 206 does not tell you anything about the board architecture (except that it is not EISA, because EISA replaced the DMA controller which was originally intended for computer designs of the early 80s with something slightly more sensible in an AT environment).
So, you face general instability of your system. The POST codes you mention look like the boot process of a boot-block based Award BIOS. This type of BIOS has a small recovery BIOS and a decompressor at the end of the ROM chip which initializes RAM, then decompresses the actual BIOS into a portion of RAM. I'm surprised to see a boot-blocked based BIOS on a mainboard of that generation, because this kind of BIOS layout makes more sense with a flash ROM, in which an untempered boot block is still enough to re-flash your BIOS. Your system, though, does not contain a flash ROM chip, but a classic UV-erasble ROM. POST codes C0..C5 are used during memory initialization and decompression of the actual BIOS by the boot block, before control is transfered to a standard Award BIOS, which starts at POST code 00.
Your symptoms scream "memory issues" to me. So my recommendation is to strip down the memory system to the minimum possible. Pull the cache chips (no need to change jumpers, the BIOS is supposed to detect missing cache chips and just not enable cache), and reduce to 4 SIMMs. Likely you only need SIM1..SIM4 for operation. If you still get the same issue, swap the SIMMs in the board with the 4 SIMMs you just pulled from SIM5..SIM8. Connect a PC speaker, because beep codes may be interesting. Your POST card might contain a speaker and a cable you can use to connect that speaker to the mainboard.
Reply 2 of 13, by picmaster
You can try carefully reseating the cache ICs, keyboard controller and BIOS, sometimes it helps.
Reply 3 of 13, by picmaster
Ahh, and some 486 motherboards just plain refuse to boot without a battery connected.
Reply 4 of 13, by picmaster
You can try to connect the pc speaker, in case something decide to beep, it can help. You can remove all SIMMs and inspect the sockets' condition, and clean it with a brush and alcohol of needed. Inspect the SIMM memories contact pads themselves, sometimes they're corroded or worn from usage, which can cause issues. You can select the 4 most preserved SIMMs and plug them into Bank 0 for testing. If you can test these SIMMs on another machine (if you have or a friend of yours has one available) it will reduce the testing guess-work. Also
Also, the usual boring stuff will also help - check the voltages are within range (especially the +5V), check for +5V on the VCC pins of the bigger/more important chips on the pcb, check the oscillators are running and producing well-formed clock signals (if you have a scope), check the ISA bus clock, check the reset signal pulses during power-on and reset button press.
I think that if the POST card is showing different codes, this means cpu is highly unlikely to be fried. If you can cause RAM error beeps during start-up, that's also good - the beeps are generated by the cpu+kbd controller so they are working. The cpu being hot is quite normal - that's 2.5W of power that has to be dissipated somehow.
Reply 5 of 13, by carlitosbala
Thank you for your help, picmaster and mkarcher! Only today was I able to get back to this board, and I started testing your suggestions.
To begin, I plugged my POST card and my speaker. I also put a heatsink on the CPU, to prevent it from getting too hot.
As first step, I soldered a lithium battery with a diode to the battery terminals. This seemed to stabilize the boot process, as after that I no longer got any "random" codes in the POST card, and I started getting "C5 C1" consistently, except a few times where it would show "d0 C5". Some progress at last!
Then I removed the RAM sticks, put some contact cleaner in the slots and tried to clean them with a toothbrush, and used an eraser on the contacts on the sticks. I hadn't noticed before, but there were two sets of sticks, four with golden contacts and four with silver contacts. Just to choose one, I put the 4 with the golden contacts in BANK0 and turned on the PSU...
"beep"
The attachment IMG_20251026_130906.jpg is no longer available
It booted! It complains about a few things, but cache size is correct, image is crap likely due to my video card, but the board works!
Now, about the errors:
* When I put the rest of the RAM sticks the board boots, but RAM size displayed doesn't change. So it seems I do have an issue with my other RAM sticks
* The keyboard is not working. I have just one keyboard I can test, and I know the keyboard itself works, so I'll see if there is any issue with the keyboard traces or the keyboard controller chip
In any case, I have a working board, thank you very much for your help!
Reply 6 of 13, by mkarcher
picmaster wrote on 2025-10-23, 23:22:
I know people generally say that "the keyboard controller" is used for interfacing with the PC speaker, but technically, this is wrong. As the original poster is having keyboard issues, I think it is fair to point out that beeps do not tell you anything about the condition of the keyboard controller chip.
The technical details are like this:
  1. On the original IBM PC/XT, there was no keyboard controller, but just a general-purpose interface chip, which handled keyboard input and some other things. The code of the key you pressed or released was captured using a discrete TTL shift register, and then presented as 8-bit parallel data to that interface chip. The interface chip on the PC/XT is an 8255, which has 3 "ports" of 8 bits each, named "Port A", "Port B" and "Port C". Port A is used to read the data from the keyboard shift register and the mainboard DIP switches. Port B is used to control various things on the mainboard, like resetting the parity error / ISA NMI latch, selecting whether port A reads keybaord codes or DIP switches, and it controls pins that are involved with the PC speaker. Port C is used as status feedback port, for example to detect the source of an NMI. As the PC speaker control bits are generated using the same chip that also handles keyboard input on these computers, this is where the connection between "PC speaker" and "keyboard" comes from. The ports A, B and C of the 8255 are mapped to ISA I/O addresses 60h, 61h, 62h
  2. On the IBM PC/AT (and all clones or later AT compatible system), the primitive I/O chip was replaced by an 8042-based microcontroller, which handles Port 60h (for XT-compatible keyboard input), and it can receive commands on a new port: Port 64h. This chip is what we know today as "the keyboard controller", and it was never involved with the PC speaker. On the AT, ISA port 62h does no longer exist, and ISA port 61h is handled by logic that is completely unrelated to the keybaord controller.
In short: On the PC/XT, keyboard and speaker were indeed handled using the same chip, but it is not really valid to call that chip a controller. On the AT and newer, there is a keyboard controller, but that chip is no longer involved with the PC speaker. So the claim that "the keyboard controller handles the PC speaker" was technically never true on any kind of IBM-compatible system.
carlitosbala wrote on 2025-10-26, 12:30:
You seem to be using an LCD monitor. That monitor samples every pixel generated by your VGA card. The LCD monitor likely knows that each line in VGA text mode consists of 720 pixels, and samples a part of the scan line that is assumed to be the visible part 720 times. As you can clearly see, the monitor does not display the full width of your text screen, so the 720 samples it takes during each line are not distributed over the full text width, but over something that looks more like 700 to 710 pixels. This will result in some samples taken "in the center" of a pixel and other samples to be taken "between pixels". It is usual for VGA cards to produce some "switchng noise" between pixels, so if the monitor samples the VGA output near the switching point, a different intensity than "at the center of the pixel" is not unexpected. Long story short: If you use the auto-adjust button on your LCD monitor, not only the image size should be correct afterwards, but also those ugly vertical stripes will be gone, because after that auto-adjust procedure, the monitor will sample all pixels at the perfect time that there is no switching noise.
Except for the keyboard error, all other errors are due to the CMOS being unconfigured.
The keyboard controller also works. I know it because in an AT system, the keybaord controller is actually a general-purpose controller that handles some system-management function besides its core job of handling the keyboard interface. One of the system control duties of the keyboard controller is configuring the mainboard into an XT-compatible mode, in which only 1MB of address space is accessible, and an "extended mode", which allows even DOS software to access nearly 1088KB of address space instead of just 1024KB of address space like on the XT. If that control function fails, the POST will stop way before the point you took the picture at. So you know that the keyboard controller is executing its control program. Thus, checking the keyboard traces is a good idea. Checking the keyboard socket (might be correded, it is often next to a leaky CMOS battery) is also a good idea, as is checking whether the +5V from the power supply reach the keyboard connector. If your keyboard blinks during power-up, it does receive power, but if all LEDs stay off the whole time, there either is a connection issue or a component in the +5V supply is blown. Most mainboards have an anti-interference inductor and/or a fuse between the +5V from the AT power supply and the keyboard socket. If there is no fuse, the anti-interference inductor may burn out instead if there is a short circuit at the keybaord connector.
Reply 7 of 13, by picmaster
mkarcher wrote on 2025-10-26, 13:40:
Hi mkarcher. Thanks for the clarification. I just looked around to see why I had the wrong impression regarding the kbd controller involvement with the pc speaker. I guess the 1st diagram on this page is what misguided me initially:
The attachment Ps2-kbc.png is no longer available
Also these notes from Bochs ports listing, and specifically:
0061	w	KB controller port B (ISA, EISA)   (PS/2 port A is at 0092) system control port for compatibility with 8255
bit 7 (1= IRQ 0 reset )
bit 6-4 reserved
bit 3 = 1 channel check enable
bit 2 = 1 parity check enable
bit 1 = 1 speaker data enable
bit 0 = 1 timer 2 gate to speaker enable
0061 r KB controller port B control register (ISA, EISA) system control port for compatibility with 8255
bit 7 parity check occurred
bit 6 channel check occurred
bit 5 mirrors timer 2 output condition
bit 4 toggles with each refresh request
bit 3 channel check status
bit 2 parity check status
bit 1 speaker data status
bit 0 timer 2 gate to speaker status
But I also checked 82C836 datasheet (386SX AT chipset) I have available, and here is an extract supporting your statement:
The attachment port61.jpeg is no longer available
Seems that port 0x61 has a dedicated i/o address decoder and register, all unrelated to the kbd controller. And of course pc speaker is connected to a chipset dedicated pin, and not to a 8042 pin. Which makes me agree with your remarks.
Regards.
Reply 8 of 13, by picmaster
Ha, glad it started to work 😀
I have 1 or 2 ISA video cards with somewhat similar crappy output, and my assumption is either bad power filtering (maybe bad caps? too lazy to check it) or just coupled noise from the mainboard into video dac. Or just overall crappy video card, who knows. I've also put other cards (both ISA and PCI) on the same mobo and all the others have nicer output on the same LCD.
So I bet your issue is also a crappy VC.
Reply 9 of 13, by picmaster
You can clear CMOS with JP7, this can help get rid of some of the error messages.
Also you can try to temporarily disable the keyboard diagnostic (JP19 = open) and see if the boot advances a little bit more.
Reply 10 of 13, by mkarcher
picmaster wrote on 2025-10-27, 00:37:
I don't blame you for having this wrong impression. As you noticed yourself, the claim that Port 61h is associated with the keyboard controller is very widespread. There are many sources that are misleading or just plain wrong, even in files shared via BBSes before worldwide public Internet access was a thing. The diagram from the OSDev Wiki is plain wrong. The page that contains this diagram is mostly correct, and just deals with the actual keyboard controller ports 60 and 64, even the diagram has these port numbers explicitly listed, but those ports have undoubtedly no association with the speaker at all. The top part of the diagram needs to be removed. Timer 3, the and gate and the speaker do not belong into this diagram.
I believe you, even without following that link, that you found this listing in the Boxes repository. Nevertheless, I want to point out the original origin of that snippet: It is part of "Ralph Brown's Interrupt List" (RBIL), one of the most comprehensive resources about DOS and BIOS services, as well as I/O port level programming of common PC hardware. It wrongly calls it "keyboard controller", but at the same time correctly refers to the name "port B" of the 8255 I/O interface chip of the PC/XT. This level of inaccuracy is the norm.
On the original AT mainboard, the speaker is connected to a transistor, driven by the output of an AND gate (the gate shown in the OSDev diagram), which combines the output pin of the timer with bit 1 of "Port B". Furthermore, bit 0 of "Port B" is connected to the "gate" input of the speaker timer channel. All of these parts: The 8254 timer, the system control port B and the AND gate are integrated in the 82c206, while the 8042 KBC is not.
Reply 11 of 13, by carlitosbala
Hi again,
I didn't answer it before, but the behaviour I see from the keyboard is that it flashes twice when the board turns on. That's all.
I checked if all pins in the keyboard connector linked with pins in the KBC, and they do:
KBC pin 1 is CLK
KBC pin 5 is +5V
KBC pin 20 is GND
KBC pin 39 is DATA
I have an usb oscilloscope, so I tried it on those pins in the KBC and it seems both DATA and CLK are being pulled up to +5V and staying there. Both have 4.7k ohm resistance to +5v, so that I guess is correct.
I removed the sticker on the KBC, the model is NEC D80C42C-317, so a microcontroller. I found a datasheet for a slightly different model and assuming pins match, I think CS and RESET signals are correct, but of course can't be sure. In different pins I see an 8MHz sinusoidal, a 500kHz pulse, and some signal activity, but nothing on the pins that are actually connected to the keyboard.
Just to try something different, with the battery on and the board off, I shorted the "82C206 DISCHARGE" jumper and left it for around 10s. That got rid of the "KEYBOARD ERROR OR NO KEYBOARD PRESENT" message in the boot screen, but did nothing to make the keyboard work.
As a second "just to try" thing, I put a different KBC in the socket, after verifying the pins I had identified matched. I got the same behavior: same messages, same two blinks of the leds, and no working keyboard.
I guess it is time to start following traces and checking logic chips, especially those below the kbc. But it would be very useful if you had any more specific suggestion than that 😀
Reply 12 of 13, by carlitosbala
By the way, to answer the questions I still didn't answer:
* Indeed using the auto-adjust feature of the monitor got rid of the bands and gave me solid color 😀
* Shorting JP19 causes a boot loop, instead of staying at the error screen the motherboard shows a message like "MANUFACTURED POST LOOP" at the bottom and restarts after the POST process finishes.
Reply 13 of 13, by mkarcher
carlitosbala wrote on Yesterday, 19:50:
Two blinks is actually interesting. You expect one blink from a typical keyboard on the power-up reset, but the second blink would indicate the keyboard controller sent a reset command to the keybaord (which it is supposed to do during POST). As you said you see nothing on CLK/DATA, I wonder whether you missed that single byte that causes the reset, or the reason for the second blink is entirely different.
Are you aware that there are two kinds of keyboard controllers? There are AT-style keyboard controllers that can interface with one AT-type device (the keyboard), and PS/2-style keyboard controllers, that can interface with two AT-type devices (a keyboard and a PS/2 mouse). Those are not interchangable! Some modern keyboard controllers can detect whether they are installed in an AT-style mainboard or a PS/2-style mainboard, but it might be that your spare KBC is PS/2 only.
It's OK you see +5V on the CLK and DATA line, because, as you said, there are 4.7k pull-up resistors. It's not OK that these lines stay high all the time, though. The keyboard controller is supposed to send the RESET command during POST, so you should see activity. Oh, wait! There is another chip in the equation: A driver chip. You traced the keyboard to pins 1 and 39, which are input pins to the keyboard controller. The keyboard controller is too weak to drive the keyboard cable, so it has a "little helper", typically an 7406 hex inverter chip, which is used to send signals to the keyboard. Pin 38 of the 8042 is the data output and Pin 37 is the clock output. On AT-style keyboard controllers, clock is inverted twice, but data is only inverted once using gates in the 7406. If the 7406 is broken or has no power, it will not drive the keyboard lines low.
So check for activity on pins 38 and 37. If there is activity (only for a brief moment during POST), but there is no activity on the keyboard clock/data lines, check the 7406.
