First post, by carlitosbala
Hi,
I have in my hands a MORSE P1 motherboard, revision v3.10
Seems to be a weird, rare motherboard model, to the point theretroweb doesn't even have a photo of it (although it does have a useful PDF), much less a BIOS I can try. I have found few references to its 'MORSE 91A401A' chip, a few more but not that many about its 'MORSE 91A402', and while its UMC 82C206L chip is not that rare it seems it wasn't usually paired with 486 CPUs, I get the idea after a few searches that it was used with earlier 386 and 286 boards instead.
This board belonged to a friend who supposedly just had it in storage, having retired it from a working system years ago. It has a 486 DX-33 CPU, 8 30-pin SIMM modules, and 256K of cache. I checked all jumpers and they seem to match the cache and CPU. Visually, apart from a very small touch of corrosion in the battery contacts, it seems to be in perfect state, not even a scratch I can see.
Unfortunately it doesn't work. My POST card shows it stopping at different steps in the boot process. Not that I trust my POST card completely, especially not in an ISA slot, but the board seems to be either failing in early boot (showing '05'), failing in a step seemingly related to RAM (C1) or cache (C5), or moving past that and stop at '00'. Or, instead of doing that, it gets stuck at a seemingly random code. I never get beeps or any signs of life in the video card.
I've tried different cache configurations, with different chips, and also different RAM configurations, but the behavior is always the same. There are no voltage regulators or almost any transistor in the board, power is getting straight from the power connector to the CPU, so really there isn't much that can go wrong. I'm inclined to think the CPU is fried, as the only thing this board does consistently is get it warm after about 10-15s and hot after 30-40s, which I don't think is normal. Unfortunately I don't have another CPU to try, I've been trying to find my 486SX-25 without success...
Any suggestions?
