Reply 20 of 72, by zuldan
- Oldbie
tehsiggi wrote on 2025-10-28, 05:07:The write-up instructions don't look too bad. I don't know of course the menus of your rigol, but you'll get around them I am su […]
The write-up instructions don't look too bad. I don't know of course the menus of your rigol, but you'll get around them I am sure of that.
I'll see today if I can find any card in my stash that uses a similar schematic, so I can see what normal operation would look like on pins for your reference.
Fingers crossed.The similar rail resistance gives me hope as well!
Well I configured the Rigol like so (I think)...
But when I measure the SS pin, I don't get any sort of signal so I'm probably not doing something right on the Rigol.
After going through all the menu options and configuring settings, I feel the oscilloscope is like a hobby in itself.
I guess I'm hitting a dead end with my technical abilities here 🤣. A bit disappointed. I have ordered some replacement ISL6525's incase the chip itself is faulty.
