Ti4200 x8 (Ti4800) - ASUS V9280S Broken
Reply 20 of 70, by zuldan
tehsiggi wrote on 2025-10-28, 05:07:
The write-up instructions don't look too bad. I don't know of course the menus of your rigol, but you'll get around them I am su […]
The write-up instructions don't look too bad. I don't know of course the menus of your rigol, but you'll get around them I am sure of that.
I'll see today if I can find any card in my stash that uses a similar schematic, so I can see what normal operation would look like on pins for your reference.
Fingers crossed.
The similar rail resistance gives me hope as well!
Well I configured the Rigol like so (I think)...
The attachment SS.png is no longer available
But when I measure the SS pin, I don't get any sort of signal so I'm probably not doing something right on the Rigol.
The attachment IMG_20251028_185343_1.jpg is no longer available
After going through all the menu options and configuring settings, I feel the oscilloscope is like a hobby in itself.
I guess I'm hitting a dead end with my technical abilities here 🤣. A bit disappointed. I have ordered some replacement ISL6525's incase the chip itself is faulty.
Reply 21 of 70, by tehsiggi
Just for verification, connect the probe to the 5V of your PSU. You should see a nice flat line around the 5V mark on your scope.
I don't expect this to be a measurement issue to be honest. Perhaps we're seeing already what's bad.
shevalier wrote on 2025-10-28, 07:14:
According to the ISL6525 block diagram, its oscillator should start immediately.
Check for a sawtooth voltage on pin 1.
I checked the ISL6522 (which is basically the cousin). The RT principle is the same as for both (same formula, same functional description by either strapping it with a resistor to +12V or GND).
I measured (3!) working ISL6522 on a Radeon 9500 Pro, which all have a flat voltage on RT. I don't think it's directly part of the RC oscillating circuit, since it can also be omitted. So I wouldn't bet on that as a verification to see if the ISL runs. The noise I have on the flat line is the same as if I would just connect the probe to ground. Noise, to be expected.
The attachment rt_isl6522.jpg is no longer available
Just to verify: Yes, the ISL is running at around 290kHz and my measurement setup works, here is the PHASE pin of one:
The attachment phase_isl6522.jpg is no longer available
And I also measured that just with the ground wire going to the AGP slot bracket, no sweat.
Don't overengineer what you're trying to do. We should see a voltage going to around 4V on SS. Either flat (working fine) or ramping (if current limit). That's not hard to measure and works easily with even the jankiest setup. Is it the best way to measure? Of course not. Is it sufficient? Yes. Don't sweat it.
AGP Card Real Power Consumption
AGP Power monitor - diagnostic hardware tool
Graphics card repair collection
Reply 22 of 70, by shevalier
tehsiggi wrote on 2025-10-28, 09:59:
This depends on the controller's internal circuitry.
When using a current mirror, a straight line will be displayed.
Sometimes artifacts from sawtooth voltage of several mV are visible.
If there is nothing holding ISL from starting (some external power sequencing circuit), then it looks like it has totally failed.
Aopen MX3S, PIII-S Tualatin 1133, Radeon 9800Pro@XT BIOS, Audigy 4 SB0610
JetWay K8T8AS, Athlon DH-E6 3000+, Radeon HD2600Pro AGP, Audigy 2 Value SB0400
Gigabyte Ga-k8n51gmf, Turion64 ML-30@2.2GHz , Radeon X800GTO PL16, Diamond monster sound MX300
Reply 23 of 70, by tehsiggi
shevalier wrote on 2025-10-28, 10:45:
This depends on the controller's internal circuitry. When using a current mirror, a straight line will be displayed. Sometimes a […]
The interesting part about the ISL6525 is that it does not have the EN pin, like the ISL6522. There is a potential connection between the AGP PG signal and OCSET, however R1305 (0Ohms) is not populated, so that "over-current trigger" to inhibit operation is not in place.
So we know that the 12V are present to power the ISL (measured through R1262, having 12V on both ends). We don't see any activity on SS, which is odd (either solid 4V or ramping is to be expected (current limit)). So perhaps that ISL just gave up? If the caps are blind, at least some activity should be there.
Just for some sanity checks Zuldan, could you measure resistance of:
  • GL1 (Gate, Pin 4 of Q905) against ground (non operation)
  • GH1 (Gate, Pin 4 of Q210) against ground (non operation)
  • Pin 4 of U831 (OCSET) against ground (non operation)
  • R1072 (non operation)
  • R1118 (non-operation)
  • R1118 both sides during operation - one should be 5V.
Interesting side note: NVVDD_PWRGD is pulled to 5V via 10k (R1118) - if it is kept low, that means that the ISL is actually doing "something", albeit just saying power is not good. Since PGOOD is open drain, there must be somebody pulling it low and that can just be the ISL.
Reply 24 of 70, by zuldan
Confirmed it's 4.4v on SS
tehsiggi wrote on 2025-10-28, 10:56:
The interesting part about the ISL6525 is that it does not have the EN pin, like the ISL6522. There is a potential connection be […]
  • GL1 (Gate, Pin 4 of Q905) against ground (non operation) - 10m ohms
  • GH1 (Gate, Pin 4 of Q210) against ground (non operation) - 11.5m ohms
  • Pin 4 of U831 (OCSET) against ground (non operation) - Cannot get a reading, made sure pin was super clean and tried with another multimeter
  • R1072 (non operation) - 1.5k ohms
  • R1118 (non-operation) - 10k ohms
  • R1118 both sides during operation - one should be 5V. - Confirmed, 1 side is 5v
Reply 25 of 70, by tehsiggi
Thanks for checking.
Having a solid 4.4V on SS would mean the soft-start is done and the ISL6525 is not in current limiting mode.
I assume your measurements that stage m ohms mean megaohms, so the values for GL1 and GL2 appear good. No short to ground between the gates, meaning they should be able to nicely switch.
R1072 being 1.5k is exactly the value of the schematic, which is good.
R1118 having 10kOhms is good as well. The pull-up to 5V is in place and would be working, if the ISL6525 is not pulling PGOOD low.
That leaves us a bit out in the open.
Just to state what we know:
  • GPU is cold, PGOOD for NVVDD is LOW, meaning all other rails are NOT enabled and thus have no voltage
  • We have 12V on the ISL6525 to supply it and the switching of the mosfets
  • There is no dead short on the NVVDD rail, the reading (around 9Ohms) is in the same region as with a regular Ti4200
  • Pull-up (R1118) for PGOOD is of right value and has the pull-up voltage 5V available.
  • SS of the ISL6525 appears to have 4.4V, meaning the chip should be active and not current limited, but the output is not currect
  • OCSET (overcurrent configuration) is set via 10k and confirmed to be correct
This is quite odd.. not sure what's going on here. And not having any activity on the gates (apparently) seems even more odd.
I just drop some thoughts / ideas what could be checked as well:
  • Is NVVDD really 0.0V?
  • Check if R1075 is 1.02K and connected to NVVDD and FB (pin5) of ISL6525
  • Check if R1078 is 2.61K and connected to FB (pin5) of ISL6525 and GND
  • If available, you could put known good low ESR caps parallel on the back of the card for the input (3.3V) and output (NVVDD) to see if that gets the ISL going (in case the caps are dead)
  • What's the resistance of the 3.3V rail of the card when not installed? Typical resistance climbing because we charge a capacitor?
I also tried something on my Ti4200 earlier on:
Used a current limited lab power supply. Set it 1.5V and current limit to 300mA (0.45W overall). Inject that 1.5V to NVVDD with the card not in the system and see if the PSU goes into current limit. If it does, I'd assume something's wrong on the rail. In my case it pulled around 120mA (iirc) and did not go to current limit, thus ruling out the rail to have a real issue.
Unfortunately, I have no card with a ISL6525 in my collection. Only 6522s and 6529s 😒 so i can't get some reference readings.
Reply 26 of 70, by zuldan
tehsiggi wrote on 2025-10-29, 19:56:
Thanks for checking. […]
Love the detail in the recap you're doing. The time you're putting into this diagnosis is really appreciated.
Yes megaohms
Here is what I could do before work. Will try the cap later today.
  • Check if R1075 is 1.02K (736 ohms) and connected to NVVDD and FB (pin5) of ISL6525 (confirmed)
  • Check if R1078 is 2.61K (741 ohms) and connected to FB (pin5) of ISL6525 and GND (confirmed)
  • What's the resistance of the 3.3V rail of the card when not installed? Typical resistance climbing because we charge a capacitor? (245 ohms)
Reply 27 of 70, by zuldan
Installed 16v 470uf (low ESR) caps on C1303, C1301, C1267 and C1263.
The attachment Installed Caps.JPG is no longer available
Voltages taken with caps installed
The attachment Front - Voltages More.png is no longer available
Reply 28 of 70, by tehsiggi
zuldan wrote on 2025-10-29, 22:18:
Always welcome. I just love to see those cards getting back to life. Yes, there is no potential use apart from retro computing, but I feel it's better to have it working for that than not working at all.
That, together with your test with the caps leads me to believe that the caps are not the issue. The in circuit measurement of the resistors is good enough I think. Especially since you verified that they are connected with the ISL6525 at the right place.
Thanks for measuring again. Perhaps it's really ISL6525 that's a goner. I've started an inquiry at my trusted vendor to see if they have some in stock as well.
I plan on building some "evaluation board" for ISL6522, ISL6525, ISL6529, SC1075, HIP6012 and some IR parts as well, so that I can "simulated" failure modes and get reference measurements of that. That would be a good collection I assume.
Reply 29 of 70, by zuldan
tehsiggi wrote on 2025-10-30, 06:53:
Always welcome. I just love to see those cards getting back to life. Yes, there is no potential use apart from retro computing, […]
Happy to do any testing you need. Learning heaps! Got some ISL6525's arriving in a week or so, I'll swap the old one out and see what happens.
Reply 30 of 70, by dm-
isl chip most likely is ok.
check with oscilloscrope if there is any initial "attepmpts" to start mosfets. there must be 3 pulses and isl will go to protection mode.
from my expirience, a caps in feedback/ comp chain is very important. failed caps will cause isl not functioning
also check voltage on OCSET pin.
Reply 31 of 70, by tehsiggi
Previous measurement attempts on GL, GH showed no activity. However they didn't also show anything on SS, which measured with a DMM shows 4.4V now, so perhaps worth a shot measuring again.
To check if the probe setup works, go measure one of the rails, like 3.3V or 5V first. That should give you a solid flat line at the voltage of that rail on the scope. If that works, go ahead with trying to measure on GL and GH.
Reply 32 of 70, by zuldan
tehsiggi wrote on 2025-10-30, 08:47:
Here are the measurements and settings of the oscilloscope. I'm sure I'm doing something wrong.
The attachment 5v rail.jpg is no longer available
The attachment SS pin.jpg is no longer available
The attachment Vertical Settings.jpg is no longer available
The attachment Hotizontal Settings.jpg is no longer available
The attachment Trigger Settings.jpg is no longer available
Reply 33 of 70, by tehsiggi
Looked at your pictures:
5V and SS measurement look good.
And SS is stable, meaning the ISL is not in current limiting mode! Good news!
Your settings look good. For measuring GL / GH, you'll probably go from ms to µs - but you'd even see something happening if it tries to periodically do something.
Give it a shot to check GL and GH again, with the current trigger settings.
If you don't see any activity, try switching your trigger to "single".
This will capture the waveform on the first trigger, giving you a "snapshot" of the first time we have a rising flank that exceeds 2V. Could be that this only happens during power up.
So the setup is: Single shot trigger, same settings. System is off. Probe onto GH. Turn system on, check if there is something captured on the scope.
Haven't worked with Rigols in while, but to configure the trigger to single shot, you can probably also use the "Single" button on the top right of the scope.
We're getting there. SS is high, non ramping. There's hope 😁
Reply 34 of 70, by zuldan
tehsiggi wrote on 2025-10-31, 09:06:
Looked at your pictures: […]
Ok changing it to Horizontal scale to 10us and setting the Trigger to Single, I was able to capture this on the LGATE when powering on the card. On UGATE I'm not getting a rising flank when powering up the card, there is no signal. I also hooked the Rigol up to the network so I could get a better picture.
The attachment Horizontal Settings.jpg is no longer available
The attachment LGATE.jpg is no longer available
Reply 35 of 70, by tehsiggi
zuldan wrote on 2025-10-31, 22:38:
Ok changing it to Horizontal scale to 10us and setting the Trigger to Single, I was able to capture this on the LGATE when power […]
So something happens on LGATE, thats good. Can you run the same test with a longer time frame? We might be able to see when the gate goes low again.. (if it does)
No activity on HGATE is concerning.
Reply 36 of 70, by zuldan
tehsiggi wrote on 2025-11-01, 06:46:
I changed the trigger from single to normal and got this. Double checked HGATE, still nothing 🙁 What could that mean?
The attachment LGATE ISL6525 on power up.jpg is no longer available
Reply 37 of 70, by tehsiggi
First of all: Glad to see that you're getting along with the scope so well now!
Seeing only gate low working is good. So the ISL is doing *some* work.. And the behavior we see kind of makes sense: PGOOD is low, because FB is probably 0V as well (just check for safety). The output will not reach any voltage if the high side FET is not switching.
Where are you measuring the gate signals? Directly at the ISL or at the FETs?
The top FET has R1080 R1302 between the ISL output and the gate of the FET. It's fairly low resistance with 2.2 Ohms. So in case you are measuring the signal at the gate pin of the FET, you might wanna check out R1080 as well. And perhaps directly at the ISL output too.
If you don't see any output at the ISL direct upper gate output, that's very odd indeed. You could check directly, if the BOOT pin is really connected to the 12V. It's driving the output of the high side fet driver in the ISL. Normally they'd use a bootstrap circuit, but since the FETs used on the card are logic level capable, they skipped that and connected the BOOT pin directly to 12V.
These would be the things I'd check next.
Edit: You measured the BOOT pin already, i forgot. It appears to get 12V, thus the output should have power to be driven.
Reply 38 of 70, by zuldan
tehsiggi wrote on 2025-11-02, 12:48:
Feeling a little more confident with the scope. Actually slowly starting to enjoy it.
I was measuring directly from the ISL pins
The top FET has R1080 R1302 between the ISL output and the gate of the FET. It's fairly low resistance with 2.2 Ohms. So in case […]
Sorry to be painful, I'm a little confused now 🤣. Could you tell me in point form what you would like me to measure? R1080 is just empty pads.
Reply 39 of 70, by tehsiggi
No, all right. You've measured directly at the ISL, so that's good.. Let my grind my gears for a little while and I'll come back to you 😁
I just saw R1080 in the schematic, but that's an alternate BOM. R1302 is the interesting part. But since you've measured directly at the ISL, it doesn't matter.
