Gsquared wrote on 2025-11-02, 15:43:
Initial power-on did nothing, the power supply fan turned on but nothing else.
One thing you should be aware of: On the old XT supply, the fan is an AC fan, connect directly to the 120V AC input (unsure about the European version). So for XT supplies, a running fan in the power supply only means AC is present, and does not imply that any part of the power supply is working. This is different in newer power supplies: Those newer supplies generally use 12V DC fans, and fan spin means that 12V DC is up and running. You observed it yourself:
I checked the voltages on that first, and the 12v line output 2v.
12V was not up and running. The reason for the 12V to not work will be obvious in a moment. In your case, it was most likely not due to a broken power supply.
So I bought another power supply which according to the seller was pulled from a working system. [...] but still nothing happened when I powered it on.
Your other power supply had similar issues.
I took everything out except the video card, but when I powered it on a capacitor blew next to the AT connector on the motherboard labelled C58, followed shortly by the three-pin on the top right of the video card.
And that's actually due to the original fault of the system: These capacitors were broken all along, and kept the +12V line down by drawing excess current. After you removed the extra components, the power supply had enough power to blow the shorts on the +12V away.
1. Did the power supply cause this? If so, how? I checked all of the voltages and they lined up well.
The power supply is not to blame. If the original XT supply is strong enough, it would have blown the caps as well. They were already bad when you got the system.
2. How did the capacitors blow with the minimal setup but not the full setup? I imagine this has something to do with the first question.
There are two theories: One theory is that the power supply entered overload/short cirucuit protection mode with the full setup before heating the capacitors enough to catch fire. The other theory is that the caps degraded further on each power-up attempt, and it is pure coincidence that they blew after you removed the components.
3. Stupidly, I didn't keep track of the position of the capacitor on the video card and I'm not sure if I put it in the right way. There seems to be only one trace on the board going to the middle pin, so does it even matter? I've attached some images for reference.
The 3-pin tantalum capacitors have the two outer pins connected to each other, so the orientation doesn't matter. If you replace them by more modern 2-pin tantalums, you need to connect the positive end to the center pin, and the negative pin to one of the outer pins. You can find further information about this type of capacitor and how to replace them on "-0°", one of the most comprehensive information sites about the IBM PC, XT and AT: https://minuszerodegrees.net/failure/IBM%2051 … 0capacitors.htm
It is very common for this type of capacitor to blow up when you power up an XT that has been in storage for a long time, so I don't think you did anything bad or wrong. If you were more experienced , you might have concluded that most likely one or multiple capacitors on the +12V are shorted before they caught fire, and have them removed without them exploding. But as this kind of failure (while slightly spectacular) does not typically cause any collateral damage, I wouldn't worry about it.
The +12V line on the CGA card is not used for anything except for the connector next to that capacitor which is meant to connect a 12V-powered monitor (like the internal monitor in the IBM 5155 Portable Personal Computer), so the CGA card would work fine even if you did not install a new capacitor. After replacing the capacitors, you should be able to run the system with either of your power supplies without further problems.
