First post, by Gsquared
A few months ago I got an IBM PC XT 5160 for pretty cheap, with the caveat that it wouldn't turn on. I've restored newer vintage PCs before, but I think this might be a little too much for me to do on my own without making some expensive mistakes. I thought this forum would be the best place to get help on this. Here's the rundown on what I've done so far:
Initial power-on did nothing, the power supply fan turned on but nothing else. I checked the voltages on that first, and the 12v line output 2v. So I bought another power supply which according to the seller was pulled from a working system. The voltages and pins lined up, but the AT connector was slightly different and wouldn't fit on the motherboard. I decided to cut that connector and take the connectors from the other power supply and solder it onto the wires. I tested all the voltages once it was done and they were all good and that they corresponded to the correct pin, but still nothing happened when I powered it on. At that point I though it might be something wrong with one of the cards or drives, so I took everything out except the video card, but when I powered it on a capacitor blew next to the AT connector on the motherboard labelled C58, followed shortly by the three-pin on the top right of the video card. I have since replaced the capacitors, but I'm afraid to try again on the same power supply. Here are my questions on what caused this and how I can fix it:
1. Did the power supply cause this? If so, how? I checked all of the voltages and they lined up well.
2. How did the capacitors blow with the minimal setup but not the full setup? I imagine this has something to do with the first question.
3. Stupidly, I didn't keep track of the position of the capacitor on the video card and I'm not sure if I put it in the right way. There seems to be only one trace on the board going to the middle pin, so does it even matter? I've attached some images for reference.
Reply 1 of 10, by mkarcher
Gsquared wrote on 2025-11-02, 15:43:
One thing you should be aware of: On the old XT supply, the fan is an AC fan, connect directly to the 120V AC input (unsure about the European version). So for XT supplies, a running fan in the power supply only means AC is present, and does not imply that any part of the power supply is working. This is different in newer power supplies: Those newer supplies generally use 12V DC fans, and fan spin means that 12V DC is up and running. You observed it yourself:
12V was not up and running. The reason for the 12V to not work will be obvious in a moment. In your case, it was most likely not due to a broken power supply.
So I bought another power supply which according to the seller was pulled from a working system. [...] but still nothing happened when I powered it on.
Your other power supply had similar issues.
And that's actually due to the original fault of the system: These capacitors were broken all along, and kept the +12V line down by drawing excess current. After you removed the extra components, the power supply had enough power to blow the shorts on the +12V away.
The power supply is not to blame. If the original XT supply is strong enough, it would have blown the caps as well. They were already bad when you got the system.
There are two theories: One theory is that the power supply entered overload/short cirucuit protection mode with the full setup before heating the capacitors enough to catch fire. The other theory is that the caps degraded further on each power-up attempt, and it is pure coincidence that they blew after you removed the components.
The 3-pin tantalum capacitors have the two outer pins connected to each other, so the orientation doesn't matter. If you replace them by more modern 2-pin tantalums, you need to connect the positive end to the center pin, and the negative pin to one of the outer pins. You can find further information about this type of capacitor and how to replace them on "-0°", one of the most comprehensive information sites about the IBM PC, XT and AT: https://minuszerodegrees.net/failure/IBM%2051 … 0capacitors.htm
It is very common for this type of capacitor to blow up when you power up an XT that has been in storage for a long time, so I don't think you did anything bad or wrong. If you were more experienced , you might have concluded that most likely one or multiple capacitors on the +12V are shorted before they caught fire, and have them removed without them exploding. But as this kind of failure (while slightly spectacular) does not typically cause any collateral damage, I wouldn't worry about it.
The +12V line on the CGA card is not used for anything except for the connector next to that capacitor which is meant to connect a 12V-powered monitor (like the internal monitor in the IBM 5155 Portable Personal Computer), so the CGA card would work fine even if you did not install a new capacitor. After replacing the capacitors, you should be able to run the system with either of your power supplies without further problems.
Reply 2 of 10, by Gsquared
mkarcher wrote on 2025-11-02, 16:29:
I tested the old power supply with nothing connected to it. Nothing outside of the supply was pulling the +12v line down to +2v. That being said, it would make sense that these caps are going bad, I just figured they would be more robust than the electrolytic capacitors I'm used to working with and started worrying if the new power supply was bad in a different way.
You gave me the courage to power the motherboard again to see what would happen, and lo and behold another capacitor blew, C56 this time. At this point I just bought a new working motherboard instead of going through each capacitor until none of them blew anymore, or just replacing all of them outright. I'll test it again when it arrives.
Reply 3 of 10, by mkarcher
Gsquared wrote on 2025-11-02, 18:36:
OK, so I misunderstood that part. In that case, the +12V did not work, because you did not have sufficient load on +5V. The old PC supplies typically require a load of at least 1A at +5V to operate properly.
If your new board is an original IBM 5160 again, it might have bad caps as well. If the condition is "worked before it was put to storage, so most likely still working", you might face the same issue with the new board. The tantalums on IBM hardware of that age are well-known for going bad. Recapping at least all +12V and -12V tantalums on a 5150 or 5160 mainboard is somehow a rite of passage for retro computing enthusiasts.
Reply 4 of 10, by DaveDDS
Recapping early IBMs in almost always needed/recommanded.
Also, Are you absolutely sure the connector is wired correctly and voltages are in the right place.
I noticed a few times you referred to the "AT" connector - but the that connector didn't come into use until the PC-AT
The XT had a different connector - I don't recall how compatible the power supplies were otherwise.
Dave ::: https://dunfield.themindfactory.com ::: "Daves Old Computers"->Personal
Reply 5 of 10, by Gsquared
DaveDDS wrote on 2025-11-02, 23:09:
Recapping early IBMs in almost always needed/recommanded. […]
Huh, I didn't know that. Still, the other power supply I got was made for an XT clone. I made sure the voltage of each pin matched the old power supply, it's just the connector itself didn't fit on the motherboard.
Reply 6 of 10, by Gsquared
mkarcher wrote on 2025-11-02, 21:48:
Well then, good to know lmao. I should have figured since the same thing applies for old Macintoshes, which I have worked on before. The listing on eBay showed it working in a screenshot, so it should be fine for a bit at least. Silver lining, the board the computer came with is the 64-256k board while the one I bought is the 256-640k, so I won't need the RAM expansion boards the computer came with.
Reply 7 of 10, by mkarcher
As far as I know, the only difference between the XT and the AT power supply pinout is that pin 2 is not connected/key on the XT and +5V on the AT.
I just rechecked the IBM PC technical reference manual (16KB-64KB), and it seems to confirm my claim. It has this pinout for the power supply:
1 - PWR GOOD
2 - KEY
3 - +12V
4 - -12V
5,6 - GND
7,8 - GND
9 - -5V
10,11,12 - +5V
I continued counting pins over both 6-pin connectors.
The usual references for AT power supplies indicate
1 - PWR GOOD (typically orange)
2 - +5 (typially red)
3 - +12 (typically yellow)
4 - -12 (typically blue)
5,6 - GND (typically black)
7,8 - GND (typically black)
9 - -5 (typically white)
10,11,12 - +5 (typically red)
The connector with pins 1-6 is called "P8", the connector with pins 7-12 is called P9. The colors may deviate, especially in early AT supplies by big brands (HP, Compaq). I've repeatedly seen orange for +12V, and thus some other color (green?) for PWR GOOD.
Reply 8 of 10, by Gsquared
Well, the new motherboard came, but the power supply's overload protection activated when I turned it on. I decided to get a new one (like, new old-stock) of the same model that came with the computer, and that works, but the computer doesn't do anything. No display, no beeps from the speaker (although I'm not 100% sure that works either). I made sure the motherboard switch settings were set correctly. To be clear, I don't own a CGA monitor so I'm using the composite out. Is there anything I can do to see where the fault is?
Reply 9 of 10, by Gsquared
Never mind, on a whim I swapped the 8088 from the old motherboard to the new one and it posts now. Now to get an XT keyboard so I can actually do something with it...
Reply 10 of 10, by dionb
As already pointed out, even completely unused new old stock items of this age are highly likely to have degraded capacitors too. I've had tantalum fireworks when hooking up NOS 486 boards ten years younger than this stuff. So I'd strongly recommend focusing on troubleshooting what you already have and restoring that to working state rather than roll the dice again and get more stuff that will just as likely need work - particularly as you have now twice replaced the wrong component...
Best case you replace the bad part with another that works when you first fire it up - but 40yo caps are going to fail sometime soon when used in any event.
