How about a MR-BIOS ROM file repository?
Reply 440 of 547, by OzzFan
I can't seem to find the MR BIOS for the Opti 82C495SX chipset. It looks like according to the Opti document, it should be file V068B470 but it seems to be missing. Was anyone able to recover this file?
Reply 441 of 547, by douglar
OzzFan wrote on 2025-09-21, 19:56:
This one works on my board…
https://theretroweb.com/motherboards/s/edom-w … tech-mv008#bios
Reply 442 of 547, by arnovdheiden
I'm curious if MR ever made a bios for intel Batmans revenge.. Could be interesting 👍🏻
Reply 443 of 547, by douglar
arnovdheiden wrote on 2025-11-03, 09:07:
https://docs.google.com/spreadsheets/d/1rClAW … 42#gid=70446342
Looking through the list, I don't see any MR BIOS for any motherboards with the 430LX mercury chipset.
Reply 444 of 547, by arnovdheiden
douglar wrote on 2025-11-03, 18:31:
Too bad, but thank you for checking 👍🏻
Reply 446 of 547, by lsorense
dareios wrote on 2025-04-30, 09:31:
appiah4 wrote on 2025-04-30, 09:25:
Still hoping for someone to come across a unicorn SiS471 MR BIOS board and post it here so I can replace the BIOS on my Chicony CH-471..
Yeah, me too. If I knew earlier about that Gigabyte board on eBay UK, I would buy it just to dump the BIOS 😁
I have an Asus VL/I-486SV2G in the basement with a MR-BIOS 3.x in it (upgraded when windows 95 came out to allow bigger than 504MB disk). If someone can tell me how to dump the bios I can do that. Can it be done from DOS?
Reply 447 of 547, by douglar
lsorense wrote on 2026-02-04, 17:09:
You can use debug.exe or try the NSSI utility from Navrátil Software.
https://vogonsdrivers.com/getfile.php?fileid=842
Reply 448 of 547, by lsorense
douglar wrote on 2026-02-04, 17:55:
Hmm, I tried romsavat and debug and while it saves what looks like the bios, the checksum is wrong. I think MR used the bios shadow feature to prevent easy copying of the rom. They were after all selling these to people. I guess it is going to need a programmer to read this correctly. I should look into getting one, I have been meaning to for years.
This is what people have been looking for right?
The attachment 20260204_131228-small.jpg is no longer available
The attachment 20260204_144358-small.jpg is no longer available
The attachment 20260204_144322-small.jpg is no longer available
Anyone have a recommendation for an eeprom programmer that can read a BIOS chip? I was looking at the XGecu T48 [TL866-3G] since the TL866 seems to often be what people recommend.
Reply 449 of 547, by douglar
lsorense wrote on 2026-02-04, 19:54:
I have a Sis 85C471 board and I'd like to test that ROM, yes.
I have a Tl866ii Plus and I like it. Not familiar with the 3G. I imagine it is pretty similar.
Have you tried turning off ROM shadowing in the BIO and using the NSSI utility linked above?
Reply 450 of 547, by lsorense
douglar wrote on 2026-02-04, 20:41:
I have a Sis 85C471 board and I'd like to test that ROM, yes. […]
Cleverly they don't give you an option to turn of shadow. You can pick shadow WP or shadow RW. That's it.
Reply 451 of 547, by Babasha
Hmm, I tried romsavat and debug and while it saves what looks like the bios, the checksum is wrong. I think MR used the bios sh […]
SPEEDSYS 4.7x have command line option for saving BIOS
You should turn off any shadowing in BIOS and boot your system without HIMEM, EMM and other drivers.
Tnx!
Need help? Begin with photo and model of your hardware 😉
Reply 452 of 547, by lsorense
Babasha wrote on 2026-02-04, 21:10:
Tnx!
Well there is no choice to disable shadow in this BIOS. I checked every setting. So I think this is just a hint that I should buy that eeprom burner I have been thinking of getting. It's a good excuse. Then I can also test that a copy of the image actually boots so that might be a good idea anyhow.
Reply 453 of 547, by Babasha
lsorense wrote on 2026-02-04, 21:46:
Tnx!
You can try to dump it with Speedsys without disabling shadowing.
Reply 454 of 547, by maxtherabbit
Tnx!
Get the T48 you won't regret it
Reply 455 of 547, by Mov AX, 0xDEAD
lsorense wrote on 2026-02-04, 21:09:
Try set c000 and c400 to rom #1, then on F000 you will get new option - ROM #0
The attachment Monitor_1_20260205-183233-361.png is no longer available
Reply 456 of 547, by lsorense
Mov AX, 0xDEAD wrote on 2026-02-05, 13:34:
Not on this version. I can set it to ROM #1, and the BIOS area still shows the same two options. Well it was worth a try. I better order that eeprom burner as soon as I figure out which bundle includes the correct adapter for reading BIOS chips and such.
Reply 457 of 547, by lsorense
lsorense wrote on 2026-02-05, 14:46:
Mine is version 3.21, which may be different than the 1.x versions.
Reply 458 of 547, by dareios
Please dump it, been waiting long for this day, when someone appears that has it! Very excited to see this!!
Reply 459 of 547, by lsorense
T48 (TL866-G3) ordered. When I get it I will try to see if I can't get a valid dump of it. I am curious which bytes it is hiding with the shadow ram.
