Reply 30420 of 31035, by sunkindly
H3nrik V! wrote on 2025-11-03, 09:43:
sunkindly wrote on 2025-10-31, 17:51:
So JP16 and JP17 seem to set the fsb, but for JP19, JP20, and JP22 no matter what I set them to...it didn't change from 2.5x at 166MHz. Even setting it to something "normal" like 133MHz at 2x, nothing changed. The only thing that seemed to affect change was changing the FSB through JP16-17. But unfortunately, it doesn't support more than 66MHz.
If that clockgenerator (W49C65-03H) is similar enough to W49C65-01, then according to https://public.dhe.ibm.com/rs6000/PPC_support … ass2/ltspec.pdf I would suspect that both JP16 and JP17 closed would give 75 FSB?
I can't seem to see where the other jumpers are located from your image, though? [Edit:] Found them. Weird, though that JP21 is "skipped" 🤣
Unfortunately closing JP16-17 gives 55 fsb.
Yeah, some things are kind of strange in terms of the jumpers. JP15 is also unpopulated.
The QDI board comes with a 200 MMX so I'll have two. I might put the second one into the M-Tech board just to see if anything changes but for now it looks like the M-Tech will be a spare Socket 7 board.
SUN85: NEC PC-8801mkIIMR
SUN92: Northgate Elegance | 386DX-25 | Orchid Fahrenheit 1280 | SB 1.0
SUN97: QDI Titanium IE | Pentium MMX 200MHz | Tseng ET6000 | SB 16
SUN00: ABIT BF6 | Pentium III 1.1GHz | 3dfx Voodoo3 3000 | AU8830
Reply 30421 of 31035, by TechieDude
Not today, but I revisited the cable of my monitor. I just needed to bridge the color ground pins and connect them to the rest of the ground, and voila! Perfect, clear image.
What I DID do today, is try connecting and posting here from an old PowerMac G5 running 10.5 Leopard, using AquaFox. Works perfectly fine, surprisingly.
EDIT: Hmmm, now that I had more time to pay attention, I can see two rendering errors. One is that all avatars here are blue for some reason, and the other is the search button, while fully functional, has the magnifying glass rendered slightly to the left. Honestly, I expected worse.
Reply 30422 of 31035, by Locutus
Locutus wrote on 2025-11-03, 07:26:
Disassembled Zenith Z-286 LP that does not POST for inspection…
The attachment IMG_2640.jpeg is no longer available
I have determined that the 82C206 controller is damaged and needs to be replaced.
The attachment 82206_REM.jpg is no longer available
The attachment 82C206_NEW.jpg is no longer available
After the replacement, the Zenith came back to life 😀
The attachment Z-286.jpg is no longer available
Reply 30423 of 31035, by PcBytes
Trying to troubleshoot an TEAC CD-C68E drive from 1997.
Reply 30424 of 31035, by pentiumspeed
Locutus wrote on 2025-11-03, 22:21:
I have determined that the 82C206 controller is damaged and needs to be replaced. […]
Great job, Another note, this computer also accepts 386SX daughterboard. Back in the day when were new, as in came in boxes around 1990 or so, we upgraded some of them to 386SX and this was at Queens University, when I was working with computing dept servicing them during summer break between high school.
Cheers,
Great Northern aka Canada.
Reply 30425 of 31035, by Ozzuneoj
I tested some old graphics cards today and ran into this weird situation.
This is what the desktop look like on a Creative CT6710 (Riva TNT 16MB AGP) in Windows 98SE. I've tried a few different driver versions from that time period and they all did this on this particular card. I have tested hundreds of cards and never seen this before so I'm inclined to think it is some kind of defect with the card, but it's just so weird...
The attachment 20251103_221013.jpg is no longer available
Basically, the desktop is rendered squashed and off-center with a black area on the left side. The cursor draws in the correct location. You can see how the cursor is highlighting a button in the file explorer window. I can interact with everything as normal as long as I keep the cursor exactly that distance from what I need to click on.
Windows says it is at 1600x1200 (native res of this monitor), but it is definitely squashed horizontally. Changing resolution causes the monitor to drop to standby. I can press escape and it will return to the previous res, so it isn't crashing. Running a game or other full screen program causes the monitor to drop to standby as well.
The BIOS, DOS and Windows in basic VGA mode (with no drivers installed) are centered properly.
I've inspected the card pretty thoroughly and I can't see anything wrong with it. It's actually in very nice condition.
Anyone have any ideas?
Also, just to be clear... it isn't the monitor.
Reply 30426 of 31035, by H3nrik V!
sunkindly wrote on 2025-11-03, 18:32:
Unfortunately closing JP16-17 gives 55 fsb. […]
FWIW, I noticed that the silk screen inside the CPU socket only mentions P54C and P54CS CPUs. Albeit, the multiplier selectors should be there for selecting at least 2x.
Reply 30427 of 31035, by sunkindly
H3nrik V! wrote on 2025-11-04, 06:47:
Yeahhh, it's all good. I guess the Retro Web entry is for some kind of later revision. The QDI Titanium 1E arrived today and I used the same CPU and it's at 200 so onwards with the Socket 7 build!
Reply 30428 of 31035, by zapbuzz
got my 256mb WD caviar disk from 1995 out today hooked it up to my main via USB to IDE adapter cable and formatted it to EXFAT file system. I then proceeded to tell brave browser to use it for the web cache. I smiled as I listened to a windows 95 hard disk struggle to just be a browser cache disk. Then I reformatted to fat32 and put it back in its shelf. I have to test things from time to time but I haven't had a windows 95 computer for so long!
Reply 30429 of 31035, by Locutus
pentiumspeed wrote on 2025-11-04, 00:42:
Cheers,
Thanks !
I was surprised by the presence (and usefulness) of the six LEDs indicating the results of internal tests.
In fact, after checking result displayed on them in documentation, I was almost certain that the 82C206 is faulty.
Running the SUPERSOFT diagnostic ROM test was just a formality to confirm that.
Reply 30430 of 31035, by sunkindly
My Adaptec AHA-1542B from 1990 came in today and I promptly put it in and got it connected to the 1988 CDR-80.
The attachment IMG_7744.jpg is no longer available
Unlike the Trantor T100, it works consistently on every boot and the drive even works in Windows 3.0 MME!
The attachment IMG_72760316-D7E6-48CB-8AF4-C213D94135D7.jpg is no longer available
That was basically the last piece of the build, so the 386 is officially complete!
The attachment IMG_7762.jpg is no longer available
Reply 30431 of 31035, by sunkindly
I also discovered that the drive wasn't exactly cheap when it was released 😅
The attachment excerpt1.png is no longer available
The attachment excerpt2.png is no longer available
Reply 30432 of 31035, by Ozzuneoj
sunkindly wrote on 2025-11-05, 23:45:
That is one of the coolest looking desktop cases of that era I've seen. There's just so much going on with the buttons and little accents. Gives it a very "The beige coloring and sharp angled protrusions tell customers that it's from the future!" kind of look that was prevalent back then. Very nice. 😀
... it's like if the Chrysler Conquest was made into a PC case.
Reply 30433 of 31035, by PcBytes
Tried reviving a Prophet 4000XT without success. Flashers just don't want to acknowledge the flash on it.
Reply 30434 of 31035, by sunkindly
Ozzuneoj wrote on 2025-11-06, 00:39:
I agree, I love the angles and it's so satisfying powering it on. I'm very thankful to pretty much have found it like that too, didn't have to do much besides wipe it down and get the dirt that had gotten in all the crevices. I've seen some other examples where even the cool design hadn't saved it from time and the elements haha:
The attachment yellow.jpg is no longer available
I also just realized seeing this photo that I put the bay drive cover upside down, oh well.
Reply 30435 of 31035, by Ozzuneoj
sunkindly wrote on 2025-11-06, 01:31:
I agree, I love the angles and it's so satisfying powering it on. I'm very thankful to pretty much have found it like that too, […]
Oh man. Yeah, there's a certainly room for PCs that have turned yellow over the years... but on a slick-looking retro setup where everything matches it is hard to make them look good!
Also, sorry if this has been mentioned already, but what keyboard is that? You managed to get a case, monitor and keyboard that all have unusual lines on them. They look awesome together. 😁
Reply 30436 of 31035, by sunkindly
Ozzuneoj wrote on 2025-11-06, 01:42:
It's a Qtronix Scorpius 104 which has gotten the job done although I'm not a fan of the tiny backspace.
I'm hoping to eventually replace it with a Northgate Omnikey since the motherboard is also from Northgate (and supposedly it's an amazing keyboard) but those prices lately 😮‍💨
Reply 30437 of 31035, by Living
My Adaptec AHA-1542B from 1990 came in today and I promptly put it in and got it connected to the 1988 CDR-80. […]
i want to be your friend so i can sit there while you play some game and not to be allowed to touch the computer xD
The time when you had "that" friend with THE computer.
Damn...40 and i feel old
Reply 30438 of 31035, by sunkindly
Living wrote on 2025-11-06, 02:41:
Hahah, my dad built computers so even growing up I was *that* friend. Though in turn I'd always be jealous of friends who had N64s and PlayStations.
Reply 30439 of 31035, by DarthSun
I have a yellow one too. It's nice, it looks like it came from the factory.
The 3 body problems cannot be solved, neither for future quantum computers, even for the remainder of the universe. The Proton 2D is circling a planet and stepping back to the quantum size in 11 dimensions.
