First post, by renejr902
The laptop has a geforce2 go. P3-1000, 512mb, windows 98 SE
Tried with dell original driver and omega geforce 45,23 drvier. Same problem
All power settings at maximum performance.
Tried all low setting and high setting in nvdia parameter driver
I played a lot of NFS iii hot pursuit and porsche unleashed. Before it was 30fps are better in each games, now each games are 5 to 10 fps and 15 in nfs iii even at 800 x 600, same fps at 1024 768 or 1400 x 1050, very strange
The problem first happened after the computer shutdown and the ac adapter burnt and even the connector to the laptop burnt. i bought a 2nd one generic with adapter and it burns too, 19v 4,74a. after 30mins
Now i have 2 other ac adapter with connector adapter, one targus auto detect 15v to 24v 6a and 90w. the other a toshiba at 19v and 4,74a. Both works but randomly sometime. Sometime i connect the ac adpter and the laptop dont turn on. i have to let the laptop unplug for 15min. But when a ac adapter works, i can play 1-2hour without problem and no shutdown for now. But fps always between 5 to 15 in both games in any resolution.
I removed and reinstall both gpu drivers several times.
I dont know if its normal but the laptop fan always run very strong all time.
I tried several settings in windows and bios, no success. I even tried to change the core speed at 145 to 150mhz in omega driver, even with powerstrip, but in powerstrip, very often the core clock fell at 70mhz to 75mhz after tried 145 to 150mhz.
I dont know if its normal, but in everhome software, it show the gpu clock ALWAYS stay at 18mhz instead of 143mhz, all the time, even when performing
I dont know what trying next. My technician father will open it and check it, and check the power where i connect the ac adapter. I really dont know what's the problem. It happens 3 days ago. Before that, for one year no problem at all, fps always 30+ in games. And 5 days ago i bought a geforce4go gpu only to update the videocard, its should be compatible i read a lot about that, but i hope this new gf4go will resolve the problem, if by any chance only the gf2 gpu is defect.
Thanks a lot for help
check video and picture ( if i drive without cars and accident fps stays between 5 to 15 without drop or stuttering.. with cars 5 to 10 without drop or stuttering.
https://jumpshare.com/s/zWU8KzB2XO7CvnrbxSYf
Reply 1 of 15, by MikeSG
Possibly the GPU only runs at 18Mhz, because it's not seeing enough power. Modern laptops do that but not sure about old Dells.
If not enough power is detected, you could try changing the battery in the laptop, or removing it and see if that changes anything.
If nothing else works try looking for a new motherboard and test that with and without battery and charger.
Reply 2 of 15, by marxveix
If its dell why dont you use dell power supply?
Best ATi Rage3 drivers for 3DCIF / Direct3D / OpenGL / GLUT / DVD : ATi RagePro drivers and software
33+MiniGL / OpenGL Win 9x dll files for all ATi-Rage3 based cards : ATi RagePro OpenGL files
Reply 3 of 15, by renejr902
marxveix wrote on 2025-11-08, 15:02:
i dont have it. But it was working great with my other ac dapter for one year.
Reply 4 of 15, by renejr902
MikeSG wrote on 2025-11-08, 14:51:
i already tried with no battery, same thing
Reply 5 of 15, by renejr902
WoW ! Very very strange. I went to powerstrip change the core clock from 143 to 145. The strong fan stop working completely, quiet. the mouse pointer disappear, no key works, just ctrl alt del and i reboot with the key and now
the gpu wirks at 30+ fps like always and fan still not working. After 5mins in playing nfs porsche, everything work, but the fan begin to work and and not full strong though. Now 2min after,the fan stop. 5 min the fan begin again. everything works great now. the fan act normally i think.. When it was always full speed it was not normal. i dont use any software for fan. i just use powerstrip. What is hapenning ?????? Thanks for help, i need to understand this strange behavior. Wow
Reply 6 of 15, by renejr902
I forgot to tell you guys, since i had this problem, sometime keyboard stop responding, but the game is still running and working. It could happen between 30min to 1h and i have to reboot the computer. Its very rare but sometime when i double click nsf porsche icon. the game dont start and i have to end it with ctrl alt del and end task and start it again.
The not responding keyboard is not funny.
Please help. Thanks for help.
Reply 7 of 15, by renejr902
Ok i played 3h at porsche only, fps are like always 30+ working great, fan works correctly.
But i have the keyboard problem that stop responding. at least in nfs porsche. It happen every 20 to 30min, very annoying, but i found a way to get it back responding and cintinue my race. but it just no sense. i push at least 3 keys at the same time several times, keys between F1 to F12. doesnt work if i push them separetely. ex: i pushed F1+F2+F3 at the same time, very fast, like 10 times and keyboard respond and works again. i think i got it responding too doing it with f5+f6+f7 like 10 times.
I try to figure out the real reason. Nothing is logical, its no senses. ( do this since the ac adapter problem the first time that burnt )
Any idea ????? Thanks a lot
Edit: i tried with 256mb ram instead of 512mb. keyboard problem still happens.
I only pushed F1-F8 keys several times separetely and it didnt work, but i push F1+F2+F3 together like 5 times and keyboard respond again, i lose the race 🤣.
very strange. but this time it seems the car was stuck on the left direction, when the keyboard stop responding.
Edit2: i tried a external ps/2 keyboard.
Even the external keyboard is not responding, when it happens
Edit3: Even if i start the racing using the external ps/2 keyboard it still happens and external keyboard stop responding
Reply 8 of 15, by MikeSG
Do you have a virus scanner that scans every 20-30mins?
Do the F1-F12 keys correspond to anything on the Powerstrip software, or other software?
Is the external keyboard connector in good condition (external, internal)?
Reply 9 of 15, by cyclone3d
Dell machines will clock down a lot if they cannot detect the power adapter properly or if they detect a lower powered than expected power adapter.
This will absolutely kill performance every single time.
Sometimes, the charging circuit on the motherboard will become faulty and not be able to detect the power adapter properly. At that point, it is time to replace the motherboard unless you have the skills to figure out exactly what the problem is and are able to source the needed parts.
I have also seen where the laptop will either have a bad battery or the motherboard no longer detects even a known good battery. Some models will go into the same type of low performance mode like when the power adapter is not detected as expected.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 10 of 15, by pentiumspeed
cyclone3d wrote on 2025-11-09, 20:21:
Dell machines will clock down a lot if they cannot detect the power adapter properly or if they detect a lower powered than expe […]
Correct on down-clocking if power adapter is not detected correctly, one more thing, the notebook will let you know before pressing F1 to continue booting.
I seen this before with defective power adapters for Dells.
For vintage Dell notebooks, 90W power adapter is required.
Cheers,
Great Northern aka Canada.
Reply 11 of 15, by renejr902
pentiumspeed wrote on 2025-11-09, 23:51:
Correct on down-clocking if power adapter is not detected correctly, one more thing, the notebook will let you know before press […]
Cheers,
Hi! thanks all
We will check the laptop soon. But for now the 90w targus universal chager works perfectly. i tried several hours. its a automatic ac adapter between 15 to 24v and 6 amp
Reply 12 of 15, by renejr902
very strange. I got working nfs porsche after several reinstallation. For the first time, i installed it in the suggested directory and filename, without changing anything and i didnt installed patch 3.5
Now i still have the keyboard problem that randomly stop working in game. ( dont happen in demo )i will changing gpu driver for official from dell.
Reply 13 of 15, by renejr902
MikeSG wrote on 2025-11-09, 11:47:
no antivirus, i uninstall powerstrip. no app on the taskbar. dont happen in demo.
if i press f1+f2+f3 in the same time at least 4 or 5 times, keyboard will respond again. i have to check again, i think mouse dont respond too when it happen. happen only in race. it happens with internal and external keyboard. socket keyboard looks good to me. but it doesnt happen in demo of nfs porsche. i played normandie race several time. in full game it happen within 2 minutes in general.
Reply 14 of 15, by renejr902
Cheers,
no F1. seems ok now with the universal targus 90w charger. its a 100$ charger in Canada, its a good one
Reply 15 of 15, by renejr902
everything resolved ! hurray ! it was my feeling. With official Dell Driver 17.60 no keyboard problem happen. The problem is because of the omega nvidia driver 45.23. i didnt tried other omega version yet, but it i remember well digital vibrance begin in 45.23. No digital vibrance for me 🙁 in 45.23 i always put digital vibrance to max for more colors in my inspiron 8100 lcd screen. If you have any idea to help me, any driver, let me know. otherwise it's fine for now. i'm curious about what cause this keyboard problem in 45.23. Thanks guys
Note: by the way, earlier when i installed it, i just not only installed the nfs5 in default directory, but i cleaned the disc too, it was dirty, but i don't think it could have been that. who knows ! thanks to everyone
Edit: Digital vibrance has been release since version 6.xx ( read release note of 45.23 )
i found it in the dell drivers, but at another place )
Edit: i tested a long time, no problem with 43.45. ( i tried back 45.23 same keyboard problem, i will stay at 43.45 )
