VIA C3 aiming for the stars
First post, by Jasin Natael
Anyone think this would be a fun idea? I know that there have been threads for K6 and Cyrix chips. Might be a cool thing to do one for VIA C3 chips as well?
I don't know if we would have to segregate for Ezra, Nehemiah or just lump them all in?
We would have to use 3DMark 2000 or 2001 as there is that FPS bug in 3Dmark 99.
And, yes I know the point of these chips isn't pure performance, but more flexibility, still might be cool to see how fast we can tweak them.
What does everyone think?
Edit: Added 3DMark Score, system specs - 11/27/2025
Intel Seattle SE440BX-2 Mainboard (Slot 1) (Chipset drivers from Phil's website, early version I believe)
VIA C3 Nehemiah 1.2GHz on Super Slocket III adapter
256MB PC133 (1x256MB)
Abit Siluro nVidia Geforce 3 TI200 (Det 7.76)
Create Labs SB16 ISA Sound (Vibra, can't remember the model, Just windows vxd driver)
Samsung 60GB IDE HDD
CDRom/ZipDrive 100MB
VIA USB 2.0 PCI with NUSB33
Windows 98 SE
DX7.0a
Ran the benchmark at multiple speeds, the best I managed was 1533@133x11.5
CPU-Z won't read the chip right.
I threw up Everest just in case anyone is doubting.
Reply 1 of 39, by mockingbird
I say pass... You will sink a lot of money into a deep pit with Via C3 (ask me how I know). Yes, in theory, it's cook having all those customization options... But the only scenario in which I would now seriously consider a C3 is a Samuel 600Mhz or so, and only if I were looking for something to replace my P233MMX (which is faster than the Samuel at 600Mhz).
(Decommissioned:)
Reply 2 of 39, by MattRocks
Never had one, and I assume VIA C3 will be like other MX chips.
All the MX chips I knew had weak FPUs, but they also had an exaggerated unfair reputation because they were nearly always paired with the cheapest expansion cards, cheapest HDDs, and cheapest RAM - if someone installs silicon/drivers that push more work to the CPU then the system will crawl and that's not the CPU's fault.
To get a fair comparison you need to dismiss the Performance Rating written on the chip (bad Public Relations) and instead compare only the core MHz. Running a 150Mhz Cyrix (IBM 233) against a 150MHz Intel, or a 233MHz Cyrix (MII 300) against a 233MHz Intel, was much more interesting than anything the magazines ran with.
And, overclocking was another area that may have unfairly killed their reputation. I am not saying they overclocked well, but failure rates made me think they may been abused more than Intel chips. Using a P233 as an example: If you stick to MHz then 10% of 150MHz is +15MHz, and apply that to get ~165Mhz total - I expect that 10% increase on stock cooling would work for any CPU. Use the same CPU but this time muddle PR and MHz: You might have said 10% of PR233 is +23Mhz, and apply that to get ~173MHz total - I expect that 16% increase on stock cooling would fry any CPU.
Desktop timeline [ MOS 7501 → 68030 → x86(P5/MMX) → x86(K6-2) → x86(K7*) → PPC(G3*) → x86-64(K8) → x86-64(Xeon) → x86-64(i5) → x86-64(i7) ] * lost
Reply 3 of 39, by mkarcher
Jasin Natael wrote on 2025-11-24, 15:09:
While I'm surprised the "FPS bug" applies to the C3, which is supposed to have a Time Stamp Counter, you might want to try this patch to 3DMark 99, which fixes broken FPS display on processors on which 3DMark 99 does not want to use the time stamp counter: Re: 3dmark99 MegaThread
Reply 4 of 39, by The Serpent Rider
Nenemiah is pretty good for what it is.
Reply 5 of 39, by Jasin Natael
Nehemiah is quite decent. Big improvement of previous cores. The FPU is as fast as the ALU. My 1.2 chip clocks happily to 1.5 on stock voltage.
It's about as fast as a Athlon around 750-800mhz at that speed. Runs very cool and seems to be entirely compatible.
Reply 6 of 39, by mockingbird
Jasin Natael wrote on 2025-11-25, 14:17:
Can you be more specific about your system spec? I had stability issues with Ezra, Ezra-T and Nehemiah... I was using Slot 1.
(Decommissioned:)
Reply 7 of 39, by Jasin Natael
Sure,
512MB PC133 (2x256)
Windows 98 SE
DX7.0a
I use Setmul to change the multiplier.
This board doesn't feature any overclocking options in the BIOS or via jumpers.
I have used CPUFSB in the past and it will overclock FSB that way, to some degree.
It used to be rock stable at 133mhz with the Nehemiah and Tualatin's, but it isn't any longer. Maybe caps?
Right now Setmul just runs it at 1.5 from autoexec, it will post and is somewhat stable at 1.6 but isn't 100%.
I think that I have some numbers from the same board and CPU of it at 1533 somewhere on a previous thread.
Reply 8 of 39, by Pino
Does anyone knows a good place to buy a Nehemiah ?
I have a slot1 motherboard and a slocket ready, but can't find C3 cpus for a decent price on ebay, and most are 600/700Mhz
Reply 9 of 39, by Jasin Natael
Pino wrote on 2025-11-25, 20:01:
I bought mine on eBay from a seller in China. He seems to no longer be selling on eBay.
I'd say just put up a saved search on eBay and eventually one will pop up. I'd just search 'VIA C3' and peruse by speed.
Most sellers won't have any clue if it's Ezra, Samuel, Nehemiah or what have you.
Reply 10 of 39, by mockingbird
Jasin Natael wrote on 2025-11-25, 18:20:
Sure,
Intel Seattle SE440BX-2 Mainboard (Slot 1) (Chipset drivers from Phil's website, early version I believe)<snip>
Ok, thanks for the info. May I ask a favor? Would you please run 3DMark2000 benchmark mode (the pro version, which is now freeware) at 1024x768x32, and see how long it loops.
Nehemiah did not pass stability for me with this benchmark satisfactorily.
(Decommissioned:)
Reply 11 of 39, by Jasin Natael
mockingbird wrote on 2025-11-25, 20:43:
Sure,
Sure thing. I don't that I've ever tried it with the 32-bit mode, and I know that I've never looped it. I usually just test my builds with Unreal flyby demo, if it passes like 20-30 loops with that I call it good, 🤣.
I don't do Prime95 levels of stability tests. I just don't see it as necessary but I will let you know if/when mine crashes.
Edit:
Ok it exited to the desktop at 54 minutes. The machine didn't crash or anything, just exited the program. Windows is still running. I don't know if this is normal behavior for 3DMark 2K on a loop test or not.
Reply 12 of 39, by Living
does my HP 2133 with c7 @ 1.2Ghz counts?
All the c3 i ever seen came in a Pcchips 789CG and similars paired with the shittiest parts on the market at that time. Then that place was occupied with Durons Spitfire and morgan SOLDERED to similar Pcchips
i really, REALLY hated when i visited a client and had one of those, it was guaranted a waste of time. So of course, when they started to come as a trade in for upgrades, it was going all straight to recycle.
Reply 13 of 39, by mockingbird
Jasin Natael wrote on 2025-11-25, 22:24:
Edit:
Thanks very much for confirming... Yes, the crash to desktop in such a short time means the system is not completely stable.
It's stable enough for most people.
If my systems do not do 24 hours of 3dMark2000 with those parameters (or 3DMark2001SE for a DirectX 8 build), they get disqualified.
This is going to raise a lot of eyebrows, but I think slot1 is a very bad platform for anything over 600mhz... My theory is that signal integrity weakness inherent to the design (which was never meant for more than 300-400mhz in the first place) causes instability.
I did have good stability with Samuel though... But Samuel is going to bring you to Pentium 1 territory... So if you want a Windows95/98se DirectX 6 system, yes go for Samuel.
(Decommissioned:)
Reply 14 of 39, by The Serpent Rider
Living wrote on 2025-11-26, 03:37:
I don't see an issue with C7, but you can't do much with a notebook. There's a bunch of desktop Mini-ITX boards with C7 though which are tweakable and expandable. And with some soldering it's probably possible to overclock FSB via PLL modding on those boards.
Reply 15 of 39, by Jasin Natael
mockingbird wrote on 2025-11-26, 04:05:
Thanks very much for confirming... Yes, the crash to desktop in such a short time means the system is not completely stable. […]
Edit:
Well I certainly see your point. I did some ram cycling and while I ended up with 256MB on a single stick I did manage to increase not only the stability but I was also able to get it tolerant of 133MHZ FSB. Seems to be ideal. 256MB is more than plenty for this system anyway.
Reply 16 of 39, by Jasin Natael
does my HP 2133 with c7 @ 1.2Ghz counts? […]
I mean, why not? I don't know much about C7's. I've a little bit of experience with the embedded ones they used in thin clients from my enterprise days. But yeah bring it on, the more the better(er)
Reply 17 of 39, by Jasin Natael
Edited OG post, added specs and 3DMark score
Reply 18 of 39, by The Serpent Rider
3DMark 2000 is a horrible test for stability. MadOnion didn't nail their benchmark quirks until 3DMark 2001.
Reply 19 of 39, by mockingbird
The Serpent Rider wrote on 2025-11-27, 17:28:
How so? 3DMark2001SE will also crash to desktop on otherwise perfectly stable systems after 24 hours. It could run for a week, or it could run for a couple of days. It's unpredictable. Maybe that's inherent to Windows 9x, maybe not. But I've found 3DMark2000 to be a pretty good indicator to attain at least a penumbra of intuition on whether your system is at least relatively stable
(Decommissioned:)
