ATi RagePro OpenGL files
Reply 140 of 148, by Hoping
vetz wrote on 2025-08-25, 10:43:
Hoping wrote on 2025-08-22, 15:57:
It would be good if the administrators explained the reason for banning the user ‘marxveix’.
I'm interested in knowing, because without his great work we wouldn't have the drivers for the rage3 so well studied and fixed.
It's been fixed now. We do not allow registration on email-addresses that do not accept mail. This is an effort to reduce spam accounts. Unfortunately it can also affect genuine users who has trouble with their email provider.
Great, thank you, it's good to know in case I find myself in a situation like that.
Reply 141 of 148, by marxveix
Added two more OpenGLs versions, v1087 and v1102 (new in the package).
File naming is the same and Takedasun mentioned variables also added to the readme. Thank you!
33 w9x MiniGL/OpenGL versions collected already:
https://hingetee.ee/library/ati-rage3gl-win9x.7z
marxveix wrote on 2025-04-15, 02:42:
Fog City 220 added, Rage Pro detected in Window mode for the quick bencmark test,
i am sure ATi Rage gets detected in full screen also @ OpenGL. D3D run at full screen.
OpenGL fullscreen and in window rendering quickfix: use direct draw resolution change option at unclicked (automatically its enabled).
Before it rendered Rage OpenGL only at in window mode. Someone maybe has older 1.xx verions of the FogCity bencmarks (only OpenGL).
Thank you!
Best ATi Rage3 drivers for 3DCIF / Direct3D / OpenGL / DVD : ATi RagePro drivers and software
30+MiniGL / OpenGL Win 9x dll files for all ATi Rage3 cards : Re: ATi RagePro OpenGL files
Reply 142 of 148, by marxveix
Takedasun wrote on 2025-08-16, 18:27:
A few more variables. I didn't check it. […]
[OPENGL]
EnableMTSGI
EnableMTARB
FlipTextures
WatchBack
AGPEn
CpuType
UseGeq
UseGeqPolyOffset
GuardLeftRight
GuardTopBottom
RageDraw
RageCull
GeqCulling
GeqClipping
GeqClipVolume
GeqClipUser
GeqVpScaleZ
GeqVpTransZ
NoStartFlag
DrawVertexBuffer
SleepTri
SleepList
SkipTex
DualCrtc
BreakPageFlipping
[Performance]
SkipFlipWaitIdle
UseAsmDraw
UsePioDraw
BMPad
[Kelvin]
Bilinear
Alpha
TexMap
TexTiling
TexName
WatchDraw
BMLoadTex
DisableBusMaster
SkipFrame
ATi did not implement palleted texture in their Rage Pro / Rage 128 Pro OpenGLs and they both supported it at Direct3D. Bit weird if the cards where capable to do it, have to use GLDirect or some other tools for it.
Some info about Quake2 Palleted texture here.
https://community.khronos.org/t/gl-ext-color-table/34496
All RagePro related and atidbg.ini has debug mode. Probably there are more options for Rage card.
atidbg.ini
[Debug]
DbgLevel=1 (1 is enabled)
System.ini
[Display]
DD32bppOff=1
five6five=1
Blockwrite=1
Win.ini
[atid3d]
u32ReadBack=1
atidraw.ini
[Texture]
Gutts=1
TexTiling=1
[Flip]
BreakPageFlipping=1
Reply 143 of 148, by marxveix
Spark wrote on 2023-07-18, 07:54:
Thanks marxveix it's great that multitexture can get you a few more fps on Quake 2.
Interesting I couldn't get multitexture to work with GLQuake, when starting it detects multitexture support in the console then just crashes, I had to remove the multitexture extensions from atidbg.ini to get it started.
I did some quick testing and it seems that multitexture crashes come from newer driver, not directly from OpenGL itself and its related to ATi driver version. My latest 540x2611x3d drivers work with multitexture and macxw4 and ati2ddad drivers are working with multitexture, but ati2drab / ati2drae driver are not. Someone maybe would like to test more drivers and get full picture from situation. Many single driver drv file: macxw4.drv or ati2ddad.drv or ati2drab.drv or ati2drae.drv wont work with all Rage3 cards. Example, sometimes RageXL card is kicked out from OpenGL party, even if D3D and 3DCIF is working with the same driver and this is with all OpenGL versions for Win9x, but not Rage3 MiniGL-s, they are all working and GLDirect wrapper also work. Picture gets clearer that after ati2ddad drivers some of the good old stuff gets ripped off, driver by driver.
Example:
Rage XL OpenGL is missing + D3D/3DCIF ok
Macxw4.drv = 4.11.2598 is one such file
Ati2drab.drv= 4.11.1014 up to 1027 is another
Two simple and good options here below if multitexture is working with your ATi driver and with multitexture and bilinear enabled + its easy to check if it crashes or not. Multitexture enabled situation gives performance boost with bilinear enabled and fastest max performance you get if you disable both options (bilinear + multitexture).
atidbg.ini@multitexture (fast: bilinear on)
Multitexture and bilinear enabled
[OPENGL]
EnableMTSGI=1
EnableMTARB=1
[Kelvin]
Bilinear=1
atidbg.ini@ (max fast: bilinear off)
Multitexture and bilinear disabled
[OPENGL]
EnableMTSGI=0
EnableMTARB=0
[Kelvin]
Bilinear=0
Reply 144 of 148, by villeneuve
Is "w98_r128_4_12_6277.exe" useful for you guys? I found it today on a CD-ROM from a German Gaming magazine, issue 8-2000.
The included "ATIO9XAA.DL_" is dated 2000-02-23.
Reply 145 of 148, by marxveix
villeneuve wrote on 2025-10-25, 01:34:
Thank you villeneuve, ATIO9XAA.DLL is Rage128/Rage128 Pro OpenGL file, here i am collecting ATi Rage Pro OpenGL files.
Rage3 33 OpenGL files for Win9x already together and latest OpenGL package is inside ATi3DRageProSoftwarebundle.7z package.
https://hingetee.ee/library/ATi3DRageProSoftwarebundle.7z
Here are my latest Rage3 5.38 and 5.40 Win9x 3DCIF/Direct3D/OpenGL/DVD driver package bundle,use with my Softwarebundle!
https://hingetee.ee/library/ATiRage2611x3Dx2.7z
I update soon ATi RagePro OpenGL files at first posting to have download link in the first page as well and maybe extract OpenGL package from
Oh wait, its already here and its name is ATi Rage 3GL-Win9x.7z
https://disk.yandex.ru/d/eV600jDAliJ_3w/Tweak … re%20bundle?w=1
https://disk.yandex.ru/d/eV600jDAliJ_3w/Tweak … GL-Win9x.7z?w=1
Reply 146 of 148, by marxveix
ATi Rage Pro may like monitor refresh rate at 85hz more than others, check glquake.zip (glquake.htm) out.
Re: ATi RagePro drivers and software
Reply 147 of 148, by marxveix
marxveix wrote on 2025-01-08, 00:16:
Joseph_Joestar wrote on 2023-07-12, 11:24:
Is there a setting which can enable GL_EXT_shared_texture_palette as well?
ATi Rage3 paletted textures with OpenGL possible with GLDirect. For me, best worked GLDirect 3.00 CAD Driver + Disable Mipmapping.
RageXL Quake2 example added.
All MiniGL-s (1005, 1010,1021,1036) and first OpenGL (1045) from ATi should support OpenGL GL_EXT_paletted_texture for Rage Pro and XL cards.
If you look this video from youtube and look glquake with 1036 first and look the same screen after, you see one detects GL_EXT_paletted_texture.
Specially made auotexec.cfg for Quake2-RagePro, there is paletted texture enabling command and its from time when MiniGLs was available @ ATi.
Successfully i get it going only with GL Direct 3.0 and added screenshots from GLQuake and Quake2, its ATi Rage without D3DtoOpenGL wrapper tool.
Compaq ATI Rage Pro Turbo AGP
https://www.youtube.com/watch?v=8pDIraOMWug
Why to enable set gl_ext_palettedtexture "1" at Rage Pro cfg if it does not work. It did detect gl-ext-palettedtexture without any extra commands.
glquake.7z had this:
Checked all Win9x Rage GLs and these very old ones should have support for paletted texture.
MiniGL (Opengl32.dll)
4.10.1005 has GL_EXT_paletted_texture
4.10.1010 has GL_EXT_paletted_texture
4.10.1021 has GL_EXT_paletted_texture
4.10.1036 has GL_EXT_paletted_texture
OpenGL (Atoglrp9.dll)
4.10.1045 has GL_EXT_paletted_texture
Newer ones dont have gl paletted texture!
What final puzzle piece is missing if it shows ATi Rage Pro GL_EXT_paletted_texture with older GL files (1005 up to 1045)?
D3D/3DCIF paletted textures are working well!
No one talks about ATi GL_EXT_paletted_texture, but it shows up, Atoglrp9.dll/Opengl32.dll has GL_EXT_paletted_texture.
https://registry.khronos.org/OpenGL/extension … ted_texture.txt
Maybe it needs special/older driver version, havent tested with many and maybe it needs to be enabled first at atidbg.ini, atidbg has many Rage3 OpenGL commands. Not a big deal, still Rage3 should have palleted textures GL support with small number of older MiniGL files and 1 OpenGL file.
Anyone has managed to get it working without GL Direct 3.00-D3D to OpenGL tool?
So far it goes, look pics, find GL_EXT_paletted_texture from these two screenshot.
Reply 148 of 148, by marxveix
ZDoom
https://doom.fandom.com/wiki/ZDoom
This version works well with ATi Rage Pro and Win9x, its ZDoom@OpenGL.
ZDoom Classic 2.1.4a (GL 1.0.17a) JAN 26 2019
https://github.com/drfrag666/lzdoom/releases/tag/2.1.4a_R2
https://github.com/drfrag666/gzdoom/releases/ … L_2.1.4a_GL.zip
Made ATi RagePro game topic, anyone that has good experiences with Game@Rage : Re: ATi RagePro supported games
