Reply 60 of 71, by DaveDDS
- Oldbie
66mhz would be a fast clock used somewhere .. divided down to get processor clock - and bear in mind that marketing causes companies to say things that aren't always truly obvious.
I don't recall exactly what 386 flavors did, but often it can be things like:
- We'll call it 33mhz because we think our slower but improved design behaves just as fast as a real 33mhz CPU.
- Some little circuit in our CPU runs an 33mhz, so we'll call it 33mhz.
- Access to the outside world is slower, but the CPU does run a 33mhz in cache when there are no other buss conflicts.
So -- you can't always trust speed ratings to reflect real world conditions. As long as something is working and is "fast enough" - it's good.
- Dave ; https://dunfield.themindfactory.com ; "Daves Old Computers" ; SW dev addict best known:
ImageDisk: rd/wr ANY floppy PChardware can ; Micro-C: compiler for DOS+ManySmallCPU ; DDLINK: simple/small FileTrans(w/o netSW)via Lan/Lpt/Serial
