First post, by DustyShinigami
- Oldbie
Thought I'd start a new thread, rather than in the Audigy one, as I no longer have the Audigy 2. I received my Sound Blaster Live! Value today and everything has been headache-free! 😁 Installed and configured perfectly. The problem I have though, is trying to juggle between two sound cards (if possible) in DOS.
So my main sound card is the Yamaha OPL3 YMF719E-S. This is what I use mainly. This was installed first. This is what I use for 90-95% of games. The PCI card is for daisychaining so I can make use of S/PDIF and redbook audio in some games. Thankfully, the Sound Blaster Live! Value is backwards compatible with DOS and uses SB16 Emulation. However, because of the Yamaha, it pinches the default ports, so the SB uses totally different ones and doesn't configure anything for MPU-401. I've tried manually setting things in autoexec.bat, but SBEGO fails to initialise the card and gives me an Environment Validation error. So it's a safe bet nothing much is going to work if I test a game.
I'm sure someone said I can't have two cards configured in DOS, which makes sense, but is there a way of unloading my ISA drivers once in DOS? There is an uninstaller, but I think the last time I tried that, it removed a lot of needed files, and I had to revert back to an image of my HDD. At the moment I'm backing things up to an image before trying it again. Apart from that, I haven't seen an unloader.
If it's possible to unload, that would make it easy to configure specific games with a custom BAT file. Or would I need to install the Sound Blaster drivers first and then the ISA card's drivers?
EDIT: Ah. The uninstaller is for Windows anyway, not DOS.
Thanks
OS: Windows 98 SE
CPU: Slot 1 Pentium III Coppermine 933MHz (SL448)
RAM: Kingston 256MB 133MHz
GPU: Nvidia 16MB Riva TNT/128MB Geforce 4 Ti 4200
Motherboard: ABit AB-BE6-II Intel 440BX
Sound Card: Sound Blaster Live Value CT4670
