Juggling between two sound cards in DOS
First post, by DustyShinigami
Thought I'd start a new thread, rather than in the Audigy one, as I no longer have the Audigy 2. I received my Sound Blaster Live! Value today and everything has been headache-free! 😁 Installed and configured perfectly. The problem I have though, is trying to juggle between two sound cards (if possible) in DOS.
So my main sound card is the Yamaha OPL3 YMF719E-S. This is what I use mainly. This was installed first. This is what I use for 90-95% of games. The PCI card is for daisychaining so I can make use of S/PDIF and redbook audio in some games. Thankfully, the Sound Blaster Live! Value is backwards compatible with DOS and uses SB16 Emulation. However, because of the Yamaha, it pinches the default ports, so the SB uses totally different ones and doesn't configure anything for MPU-401. I've tried manually setting things in autoexec.bat, but SBEGO fails to initialise the card and gives me an Environment Validation error. So it's a safe bet nothing much is going to work if I test a game.
I'm sure someone said I can't have two cards configured in DOS, which makes sense, but is there a way of unloading my ISA drivers once in DOS? There is an uninstaller, but I think the last time I tried that, it removed a lot of needed files, and I had to revert back to an image of my HDD. At the moment I'm backing things up to an image before trying it again. Apart from that, I haven't seen an unloader.
If it's possible to unload, that would make it easy to configure specific games with a custom BAT file. Or would I need to install the Sound Blaster drivers first and then the ISA card's drivers?
EDIT: Ah. The uninstaller is for Windows anyway, not DOS.
Thanks
OS: Windows 98 SE
CPU: Slot 1 Pentium III Coppermine 933MHz (SL448)
RAM: Kingston 256MB 133MHz
GPU: Nvidia 16MB Riva TNT/128MB Geforce 4 Ti 4200
Motherboard: ABit AB-BE6-II Intel 440BX
HDD: C, D - IDE 1, CD-ROM - IDE 2, E - IDE 3
Reply 1 of 60, by Shponglefan
DustyShinigami wrote on 2025-12-02, 17:16:
I'm not sure who claimed you could not have two sound cards configured in DOS. That isn't right at all. I've installed up to 6 sound cards concurrently in DOS. It's just a matter of assigning hardware resources so the devices don't conflict.
Insofar as "uninstalling" drivers in DOS, first you need to know how DOS drivers work. Typically driver installation will make changes to CONFIG.SYS and/or AUTOEXEC.BAT files. Removing drivers from being loaded on boot up can be accomplished by either putting a REM statement in front the respective lines or just deleting those lines altogether.
Personally I'd recommend the REM approach since you can always undo those changes by removing the REM statement, if you wanted to activate the drivers again.
If you are finding the two cards won't play nice concurrently, you can look into setting up a DOS boot menu with individual configurations for each card.
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 2 of 60, by Pino
I have system with multiple sounds cards, including a Audigy 2 PCI, and the best way I found to manage it in DOS was not initializing any card at boot, and then using .BAT files with Unisound to initialize just what I want to use at that moment.
Ex.: you would creat a .bat named yamaha.bat that would look something like this:
set blaster=a220 i5 d1 p330 t4
c:\drivers\unisound /c1
and another one called live.bat, that would look something like this:
ECHO Initializing SoundBlaster Audigy 2 ZS under DOS...
SET CTSYN=C:\LIVE
SET BLASTER=A220 I5 D1 H5 P330 T6
C:\LIVE\SBEINIT.COM
ECHO Initialization complete.
More details about my system and how I do it here:
I call it "poor man's Orpheus" :-)
Reply 3 of 60, by Joseph_Joestar
You can have multiple sound cards in pure DOS without too many issues, as long as each one is assigned different resources.
Under Win9x, this is a bit harder, because Adlib and Joystick ports from different cards tend to conflict with each other. That can be worked around by manually disabling or reconfiguring resources on each sound card, but it requires a lot of careful work. That's why I don't recommend it with my guides, as it tends to create resource conflicts and disrupt the normal driver installation procedure under Win9x.
Reply 4 of 60, by DustyShinigami
Shponglefan wrote on 2025-12-02, 17:59:
I'm not sure who claimed you have two sound cards configured in DOS. That isn't right at all. I've installed up to 6 sound cards […]
I'm not sure who claimed you have two sound cards configured in DOS. That isn't right at all. I've installed up to 6 sound cards concurrently in DOS. It's just a matter of assigning hardware resources so the devices don't conflict.
I see. I may be mis-remembering, or misunderstood, about it not being possible. Or it wasn't recommended. I know resource assignment is a bit of an issue if multiple cards are installed. I did try and free some by disabling the two COM ports and LPT.
But what you've described confirms that my understanding is correct. 😀 That's how I've been doing it. I've still yet to figure out how to set up a custom DOS boot menu with different configurations. With my ISA card, apart from the SET BLASTER line, nothing else appears to be configured for it. Though I need to check in the config.sys file for anything. So the problem lies with those ports already being configured to the card, which I presume it does automatically when DOS is initialised...? I tried removing the card and seeing if the SET BLASTER line would assign it to the only card present, but I still get that error and the wrong ports.
OS: Windows 98 SE
Reply 5 of 60, by DustyShinigami
Joseph_Joestar wrote on 2025-12-02, 18:07:
Ahh, okay. Gotcha. So I need to find out how to assign different resources. Because even with my ISA card removed, it's still assigning the wrong ones to the SB Live! card.
OS: Windows 98 SE
Reply 6 of 60, by DustyShinigami
Pino wrote on 2025-12-02, 18:00:
I have system with multiple sounds cards, including a Audigy 2 PCI, and the best way I found to manage it in DOS was not initial […]
SET CTSYN=C:\LIVE
C:\LIVE\SBEINIT.COM
Great. Thanks for the link; I'll check that out. Does Unisound need to be initialised in autoexec.bat first? And then get it to call those custom BAT files from there?
OS: Windows 98 SE
Reply 7 of 60, by NeoG_
Unisound just needs to be called once from anywhere to initialize the Yamaha card. Unlike CD-ROM devices for example, there's no two step device driver and then load extension process. Just one and done.
By default both Unisound and SBEINIT should follow the BLASTER variable for resource assignment. My recommendation would be to use Address 220, IRQ 7 and DMA 1 as some older games are hard coded to use one or more of these values.
That would mean that your Yamaha BLASTER line would be "A220 I7 D1 P330 T4" and your SB Live BLASTER line would be "A220 I7 D1 H5 P330 T6"
I expect that the DOS driver installation has put a default value for BLASTER in your "C:\AUTOEXEC.BAT" file, which is where SBEINIT is currently getting it's resource values from.
Reply 8 of 60, by DustyShinigami
NeoG_ wrote on 2025-12-02, 22:33:
Unisound just needs to be called once from anywhere to initialize the Yamaha card. Unlike CD-ROM devices for example, there's no […]
I expect that the DOS driver installation has put a default value for BLASTER in either your windows "C:\AUTOEXEC.BAT" file, which is where SBEINIT is currently getting it's resource values from.
Great. Thanks. I'll have a play around with it soon. But yeah, the line has been added to autoexec.bat by the driver, along with the directory of the DOS files. I'll see about setting up different BAT files with the commands and see if they're called correctly. 😀
OS: Windows 98 SE
Reply 9 of 60, by DustyShinigami
Okay, I seem to be running into another issue. I think it might have something to do with resources...? But I'm not sure. Basically, when I had the SB Live's drivers installed first I went and installed the Windows drivers for that HPT IDE controller. After restarting, I keep getting a BSOD. A 'fatal exception 0E has occurred at 0028:C2A230E2'. I tried going back and installing the controller's drivers first and then the sound card's, but the same issue has happened. It goes if I disable the controller in the BIOS though.
I am tempted to just disable the controller and be done with it, but if it is a resource issue, and there is a way of getting things to work together in harmony, I'm all for it.
OS: Windows 98 SE
Reply 10 of 60, by NeoG_
Do you have access to any other driver versions for the controller? Typically you won't have resource issues with built in PCI devices on the motherboard. But at the end of the day, if it's not necessary I would can it. No need to complicate matters just to show something as enabled in the BIOS.
Reply 11 of 60, by NJRoadfan
I've run the Orpheus II in a machine with a SoundBlaster Live! It worked fine. The reality is the SB Live! only consumes one IRQ in DOS if you aren't using it for legacy emulation, and why would you if you have a real ISA card?
Reply 12 of 60, by DustyShinigami
NeoG_ wrote on 2025-12-03, 02:41:
There's only a few. On this site: https://soggi.org/drivers/drivers.htm#HiPo T
The one for the BIOS is up to date - 1.28 - though I thought the one I was using in Windows was 1.25. That site is only showing 1.26 and it's Beta. So I'll try re-downloading and installing that first. See what happens.
EDIT: Ahh. Yeah, that might explain it. Though I swear I put 1.25 on several times before and it was fine, but the one for 1.25 is actually for flashing the BIOS. ^^;
OS: Windows 98 SE
Reply 13 of 60, by Shponglefan
DustyShinigami wrote on 2025-12-02, 18:17:
It's perfectly fine to have multiple sound cards, but it does require some know-how regarding hardware configurations. With only two sound cards, you shouldn't need to disable any BIOS resources especially for serial/COM ports. Typically you would need free IRQs and with only two sound cards, using IRQ 5 and 7 should be all that is needed.
There's an example/tutorial here if you're interested: https://retrocomputing.stackexchange.com/ques … windows-and-dos
It's not difficult to do, just requires making some modifications to both CONFIG.SYS and AUTOEXEC.BAT. If you're using native DOS, I recommend learning how to do this as it can be really useful for setting up different configurations for sound cards, memory, etc.
SET BLASTER is just an environment variable. It's used by some configuration programs (game setups) to predict default values for the card. But it's not the same thing as configuring the card itself.
For setting the hardware config I would recommend using UNISOUND. This will allow you to specific individual hardware resources (address/ports, irq, DMA channel) and initialize the card with those hardware settings.
Reply 14 of 60, by DustyShinigami
Shponglefan wrote on 2025-12-03, 13:51:
It's perfectly fine to have multiple sound cards, but it does require some know-how regarding hardware configurations. With only […]
Awesome. Thank you. I've bookmarked that guide for the boot menu configurations. I'll definitely follow that and report back if I have any issues. 😁
And I see. Gotcha. But yeah, I was using Unisound before I was messing around with a second sound card. I also occasionally used SetYMF, though I remember Daggerfall having problems detecting my sound canvas with that. Unisound sorted it though. Thing is, should I call for these different BAT files - for the Yamaha and SB - via autoexec or DOSSTART? Or maybe both?
OS: Windows 98 SE
Reply 15 of 60, by Joseph_Joestar
The reason why I usually recommend disabling COM ports is because a) most people on a Pentium (and newer) system don't use them nowadays and b) it frees up IRQs 3 and 4.
To clarify, those IRQs aren't meant for the second sound card, but rather to move other devices that might have taken up IRQs 5 and 7 there. Stuff like USB controllers and network cards love hogging IRQs 5 and 7 by default. With a bit of BIOS tweaking, you can move the offending devices to the now unused IRQs 3 and 4 instead.
Reply 16 of 60, by DustyShinigami
Joseph_Joestar wrote on 2025-12-03, 14:31:
I've set IRQ to use Legacy ISA devices, but should I also set IRQ 7 as well?
OS: Windows 98 SE
Reply 17 of 60, by Joseph_Joestar
DustyShinigami wrote on 2025-12-03, 14:46:
Technically, the Legacy ISA setting is meant for older non-PNP ISA cards. In theory, Win9x should be able to manage free resources on its own when dealing with newer PNP capable ISA cards. In practice, that doesn't always work out.
So it depends on what hardware you use, and how well your system configures that hardware by default.
Reply 18 of 60, by DustyShinigami
Joseph_Joestar wrote on 2025-12-03, 14:49:
Ah. Okay. What are considered non-PNP ISA cards? Any particular era? I'm guessing my Yamaha YMF719E-S is plug and play...
OS: Windows 98 SE
Reply 19 of 60, by Joseph_Joestar
DustyShinigami wrote on 2025-12-03, 15:02:
In terms of sound cards, the ones which have jumpers on them for manually configuring all resources. Usually stuff made before 1995.
Creative's first SB16 model (CT1740) is a good example of a non-PNP card.
