yes old build is 26 fps max at starting position of Scorched planet vs 33 fps max at last build.
DMA still faster
Try adding this to the joystick section. On dual core machines this needs to be added. I don't know what the situation will be on your machine.
[joystick]
multithreaded=false
Early Attempts to test Formula 1:
The game can be installed trough otvdm , thanks.
And it seems could not detect Randition, and doesnot installs f1red.exe file.
So i extracted it by UniExtract Tool a archiver which supports way nearly all archive types.
placed f1red.exe into newly installed formula1 game and ready to go.
in Game:
Performance variety goes from 19 fps, average 35 fps, max 60 fps(vsync).
The game seems rendered perfectly.
Only suspicious 2 things:
Wheels at far distance on foggy weather , not fogged , stays dark .
Cars very rarely 'jumps' off of their positions a little bit up.
RaVeN-05wrote on 2025-12-06, 17:04:Early Attempts to test Formula 1:
And it seems could not detect Randition, and […] Show full quote
in Game:
Ok, I'll test this on the v2200 tomorrow. The v1000 still has issues rendering file explorer, randomly locks up, with rredline drivers. I saw a post here where someone said v1000 struggles to render the desktop with the full acceleration slider set to max on an Athlon xp, but works fine on older, slower cpus.
in Game:
There's also a problem with the water spray texture from the rear of cars under wet weather not being sized correctly sometimes. I'm going to try to fix that today.
The cars jumping *might* just be LOD for the model changing. On real hardware it changes, but the framerate is low so it's less dramatic. I'll also see what's up with the fogging on the wheels.
You have to tick the checkbox manually for all the versions you need. I reinstalled this earlier today, on my W98 machine, because the F1 wrapper, (RReady.V2k), wouldn't work with the reference drivers. I had to revert to Diamond drivers to get this to work. I should probably update the thread F1 V2k.RReady thread.
