Pentium 200 extremely slow
Reply 40 of 165, by NeoG_
dionb wrote on 2025-12-10, 23:51:
If you want info on jumpers or mods, we need to know exactly what hardware you have. If you don't know the name of the motherboard, give us the model number of the Aptiva.
Nothing kills a troubleshooting thread faster than lack of information
98/DOS Rig: BabyAT AladdinV, K6-2+/550, V3 2000, 128MB PC100, 20GB HDD, 128GB SD2IDE, SB Live!, SB16-SCSI, PicoGUS, WP32 McCake, iNFRA CD, ZIP100
XP Rig: Lian Li PC-10 ATX, Gigabyte X38-DQ6, Core2Duo E6850, ATi HD5870, 2GB DDR2, 2TB HDD, X-Fi XtremeGamer
Reply 41 of 165, by Señor Ventura
Señor Ventura wrote on 2025-12-10, 19:07:
The CPU definitely shows 120mhz in every bench program i use (119.mhz), probably my bios sets this frequency and it can't be changed from there... maybe some jumper?...
If you're running your P200 at 120MHz that can explain a thing or two...
As for BIOS setting CPU frequency - not very likely on a system this old. Almost certainly this will either be with jumpers or - IBM did this on some early Aptivas - simply hardwired to 2.0x multiplier and 60MHz bus speed. In the latter case you would need a simple mod to get to 3.0x multiplier. 66MHz FSB options depend on the exact motherboard. I already asked which Aptiva you have there. You didn't answer. If you want info on jumpers or mods, we need to know exactly what hardware you have. If you don't know the name of the motherboard, give us the model number of the Aptiva.
It is an aptiva 2144-351 (SL-A), chipset 5511/12/13 with integrated vga SIS5598, sorry, i was pretty convinced that i already wrote this.
Jumper jp10 and jumper jp11 in positions 1-2 supossedly set the cpu to 150mhz, but i think jp10 must be 2-3, i need confirmation. I'm searching some, if i find it i will post it here.
Reply 42 of 165, by bertrammatrix
Señor Ventura wrote on 2025-12-11, 01:49:
It is an aptiva 2144-351 (SL-A), chipset 5511/12/13 with integrated vga SIS5598, sorry, i was pretty convinced that i already wr […]
It is entirely possible that only the FSB, or, only the multiplier is available to be changed, or that one jumper does either/or fsb and another either/or multiplier, since the amount of cpu configurations a model came with was usually pretty limited. Often manuals only list what jumper positions to use for what cpu speeds opposed to if a jumper actually does FSB or multiplier
Usually you are fine to set these any which way without doing any damage, worst case the board wont post. I would go ahead and try all possible combinations of jp10 and jp11, you will likely be able to figure out which one does what by doing so
Reply 43 of 165, by Ozzuneoj
Sorry if this has been posted already, but does your motherboard resemble the one in this system at all?
IBM Aptiva 2144-M51
I haven't read every detail of the thread but there is discussion of CPU jumpers and upgrading to a 200Mhz Pentium.
Reply 44 of 165, by Señor Ventura
bertrammatrix wrote on 2025-12-11, 04:05:
I can achieve P90, P120, P150, and P180.
With 180mhz bios shows it as "0", but "speed sys" doesn't agree with that... tomorrow i would confirm.
Edit: and now i realizing that bios reports "error 127" main board when i try p180 (it is recognized in bios as "p0").
Reply 45 of 165, by Jasin Natael
Maybe try CHKCPU?
Reply 46 of 165, by Señor Ventura
Jasin Natael wrote on 2025-12-11, 14:04:
Maybe try CHKCPU?
I don't see any jumper like that, really is a very basic motherboard.
It has its irony xD
-As "P0" (180mhz), bios detect a problem (error 127), but the computer is stable, windows 98 boots properly, and all runs good (lacks 20mhz, but ok).
-As "P90" bios gives its ok, but the system is enormouly unstable, windows with glitches, etc.
Edit: i'm seeing myself setting up as "P150", and lacking 50mhz in order to get stability, and not having to read error messages.
Reply 47 of 165, by douglar
Señor Ventura wrote on 2025-12-11, 04:36:
What's the date on your BIOS? Perhaps there's a BIOS upgrade that understands the higher multipliers.
Can you find your motherboard here? https://theretroweb.com/motherboards
I suppose it is possible that the jumpers for the fastest multipliers were not connected to the CPU correctly.
Reply 48 of 165, by Señor Ventura
douglar wrote on 2025-12-11, 14:56:
What's the date on your BIOS? Perhaps there's a BIOS upgrade that understands the higher multipliers. Can you find your motherb […]
I can't find it in this link, but i have seen this here. Supossedly i should can have a pentium 200 in this computer, but...
P.D: jumpers are all rigth placed.
file.php?id=86480&mode=view
Reply 49 of 165, by dionb
You already wrote 5511/12/13 with integrated vga SIS5598 and we already concluded that was incorrect...
Is this the board? https://theretroweb.com/motherboards/s/ecs-si … 8p-vio-rev-1-0b
It certainly seems to correspond to the diagram you posted and the other specs. And clearly shows you have a SiS5511/12/13 with SiS6205 chip in UMA, as we had already discovered earlier. No 5598...
Jumper jp10 and jumper jp11 in positions 1-2 supossedly set the cpu to 150mhz, but i think jp10 must be 2-3, i need confirmation […]
According to that documentation JP10 and JP11 gives a 2/5 ratio, i.e. a 2.5x multiplier, so if the bus is set to 60MHz, you get 2.5x60=150MHz. So that's correct.
Señor Ventura wrote on 2025-12-11, 15:14:
What do you call "rigth placed"? Please be clear:
- which position(s) is J35 in?
- which position(s) are JP10 and JP11 in?
A P200 should be configured with 3.0x66MHz. According to the documentation you posted there, that means J35 should have both 1-2 and 3-4 jumpered to give 66MHz bus speed; JP10 should be set to 2-3 and JP11 to 1-2 to select 3.0x multiplier (or as IBM has listed it, 1/3 ratio).
If this is not stable, the first place to look is the RAM. 66MHz FSB requires 60ns EDO or FP DRAM. 70ns RAM sometimes runs OK but sometimes doesn't. What is yours? (look at the chips on your SIMMs, the identifying line will usually end with -6 or -7, if -6 it's 60ns, if -7 it's 70ns)
Another thing to check is the BIOS version. You say the CPU speed isn't reported correctly. That could indicate the BIOS is older than your CPU. The Pentium 200 was released in June 1996. On TheRetroWeb two BIOS versions are listed, with the older being from the summer of 1996 and the newer from early 1997. It might be worth upgrading to the latter if you're not already running BFLUK4L.
Reply 50 of 165, by Ozzuneoj
Señor Ventura wrote on 2025-12-11, 14:48:
I don't see any jumper like that, really is a very basic motherboard. […]
Maybe try CHKCPU?
It has its irony xD
CHKCPU is a program that identifies your processor:
http://www.steunebrink.info/chkcpu.htm
Reply 51 of 165, by bertrammatrix
Shouldn't the multiplier be a non issue here? If it runs at 180 that would mean it already has the required 3x set, it should just work at 200 once the fsb is set to 66. Or are you thinking that the system just spits that error out because it is not recognizing that cpus fsb/multi combination to identify it correctly? Usually I just see them get identified wrong, but I suppose it could be spitting up an error because of it being an ibm.
Reply 52 of 165, by Señor Ventura
dionb wrote on 2025-12-11, 16:26:
I see the problem... SIS5598 is the SoC, not the integrated VGA itself... sorry for the inconvenieces.
All this time i thought never was a third jumper, so the fourth conmutation was driving me to think that it was "auto detecting mode" or something like this, but now i see that setting up to "P150" enters into conflict with "j35" jumper, which is not near of "JP10" and "JP11".
I meant the douglar's commet about if i putted wrong some jumper, and all are well contected.
Jumpers are:
-JP10 (2-3)
-JP11 (1-2)
-J35 i don't know if reading "same oriented" as JP10 and 11, or in the same orientation as its name (J35).
I almost there, then... the only thing right now is how to consider the pin positions 1, 2, 3, 4 of J35 (from up to down, or from left to right).
Checked!, it says clearly -60, so 60ns... and all this time it has no issues from bios marking 60ns, so, it seems to be all right.
Nightmares right now...
Ok, i will try to set the pentium working at its frequency, and if it fails trying to report the cpu, then i will dive into this... somehow... xp
P.D: And thank you so much for your patience!.
Ozzuneoj wrote on 2025-12-11, 16:29:
No problems here with this, is a pentium 200 p54c.
bertrammatrix wrote on 2025-12-11, 17:17:
Theoretically no one configuration could harm the processor because is the top electrically... but never knows... maybe there could bw one that enables too much multiplier...
Ancestral fears i suppose xD
Reply 53 of 165, by bertrammatrix
Looks like you just have to put the one jumper on jp35. 3&4 are already connected 1 &2 is all that is left to connect for 66 and you should be good to go
You don't have to worry about setting the multiplier "too high" - it is always locked upwards on Pentium cpus, meaning you can always set a lower multiplier of choice, but anything higher then the chip supports will have no effect
Reply 54 of 165, by Señor Ventura
bertrammatrix wrote on 2025-12-11, 18:28:
So, i only have to connect the one wich is alone to the unused pin, not changing positions, or whatever.
I was so lost... j35 was hide under 3 boards near the riser ^^u
Thanks to all!
Reply 55 of 165, by dionb
Also, there is no higher multiplier than 3x for P54C, so you couldn't set an unlocked Pentium non-MMX higher regardless
Reply 56 of 165, by Ozzuneoj
Señor Ventura wrote on 2025-12-11, 17:48:
I mean... nothing is letting you run the processor at the speed it should run at, I would say that's a problem. haha 🙂
This program will tell you exactly what you're working with and what the configuration is (FSB, Multi, etc.). It is free and in just a few minutes you could be posting a screenshot here of it's output, like the one shown below:
http://i.imgur.com/7JtPCRJ.jpg?1
Reply 57 of 165, by Señor Ventura
Well, as expected, i am now at this point.
I've find a link with a bios dated from 1/22/99, but seems that my aptiva is not in this list:
https://aptivasupport.com/uas/bios/odyflash.h … rce=chatgpt.com
I should go exclusively with "BFLUK4L – circa 1997", right?.
Reply 58 of 165, by Intel486dx33
iBM Aptiva is a Very Good computer for gaming.
Originally I think that mine came with a Matrox video card.
I have one of these original computers.
Intel 200 CPU is a very good reliable and Stable CPU too.
Back in 1990 we ran Win95: WinNT 4.0 workstation and Server on 100mhz CPU with 32mb of Memory
we ran just about every program and application on these computers in classroom environments.
Very good computers.
I think your CPU is fast enough.
Try to add a dedicated video card like S3 3D PCI
Or Geforce fx5500 PCI
Or Voodoo-3 PCI
Try this.
Fresh install of Win98
Then install video and sound card drivers
Reboot
Get SP3 from Philscomputerlab website
Select to Install “main core updates” only
Reboot
Then install DirectX from 6 and reboot
You are dome.
Everything should work
Reply 59 of 165, by Jasin Natael
Once you get the CHKCPU output we can probably help more, to determine what your CPU is being detected as, bus speed, multiplier etc.
Reinstalling Windows and buggy /broken unofficial service packs, plus a later version of DX9 that your hardware supports will not help you at all.
