EEPROM corruption on Creative cards
Reply 20 of 41, by Redeemer
ott wrote on 2025-06-13, 15:41:
songoffall wrote on 2025-01-12, 07:20:
I'll do some investigating and try things out on my own card, and document the process here.
Any updates?
I want to backup EEPROM of Audigy 2ZS card using CH341A clip, but not sure about success.
I restored my 2zs. I desoldered the chip, flashed it on the T48 programmer. The firmware (worked) for 2zs is on the retroweb website
Reply 21 of 41, by songoffall
Any updates?
Apparently my card's EEPROM was doing just fine, which is both a good thing and a bad thing - I really wanted to play around with flashing it. The real problem was - apparently you need the driver CD for your exact card model (mine being the original Audigy 2 SB0240). Took me a while to get the original driver CD.
I think it's understandable, my unwillingness to risk harming a working card by taking off a working EEPROM chip. But once I get my hands on a dead one with erased EEPROM, I'll see what comes out of it.
P2 300MHz/Matrox Mystique/Sound Blaster AWE 32 Value
Pentium 3 733MHz/3dfx Voodoo 3 3000/Aureal Vortex 2 (Diamond Monster Sound)
Pentium 4 HT 3.0GHz/GeForce FX 5500/Creative Audigy 2
Core2 Quad Q9400/GeForce 8800GT/Creative X-Fi Titanium Fatal1ty
Reply 22 of 41, by shevalier
songoffall wrote on 2025-01-11, 10:10:
ROM files, part 1
Audigy 2 value SB0400
Audidgy 4 SB0610
download/file.php?id=232817
PCI-e X-Fi SB0880&886
in attach of this post
Aopen MX3S, PIII-S Tualatin 1133, Radeon 9800Pro@XT BIOS, Audigy 4 SB0610
JetWay K8T8AS, Athlon DH-E6 3000+, Radeon HD2600Pro AGP, Audigy 2 Value SB0400
Gigabyte Ga-k8n51gmf, Turion64 ML-30@2.2GHz , Radeon X800GTO PL16, Diamond monster sound MX300
Reply 23 of 41, by ElTentakel
jmarsh wrote on 2025-01-11, 17:51:
myne wrote on 2025-01-11, 17:36:
It's an Soic8. At face value I don't see why a standard ch341a clip wouldn't work
(ie no need to desolder)
Just because it's the same pin layout, doesn't mean the pin functions match (they don't). You would need a custom intermediate board between the programmer and the clip to remap them.
I had no issues at all with an SB32 (ct3670), which had the same issue. The nasty thing is, that I had to desolder the chip, because the programmer was not able to power half of the card with 5V. But after resoldering, the card worked like a charm.
After reading that thread however, I have a bad feelingy that I will have to do it again some day. I have to check, which chip they used.
Reply 24 of 41, by shevalier
ElTentakel wrote on 2025-12-17, 17:01:
Some 24 chips and all 93 support write protect pin& functionality
With the x-fi its working like a charm
For x-fi just need to replace one resistor 😀
Reply 25 of 41, by Space Ace
I have one of those Audigy 2 zs Dell verion cards - if I reflash the eeprom with retail version does this mean the Creative drivers will install without all the workarounds usually required for the Dell cards on Windows 98?
Reply 26 of 41, by myne
shevalier wrote on 2025-12-17, 18:32:
Some 24 chips and all 93 support write protect pin& functionality With the x-fi its working like a charm For x-fi just need to […]
That may sound wise, but they're 30yo chips.
They might be naturally degrading by now.
If they are, then you've just made it far more annoying to fix.
I built:
Reply 27 of 41, by maxtherabbit
myne wrote on 2025-12-28, 23:45:
That may sound wise, but they're 30yo chips. They might be naturally degrading by now. If they are, then you've just made it f […]
I'm sure the mod is easy to revert if needed. The most important thing is this way he would KNOW the actual cause if it gets corrupted again.
Reply 28 of 41, by shevalier
EEPROM erasure in sound cards is a known bug, but no one knows why it happens.
All audio cards on C-media chipsets (i.e. all from Asus) are susceptible to this bug.
There is even a utility that restores EEPROM for them.
There was no such utility for Creative cards, there is none now, and there will be none in the future.
So it is impossible to rewrite EEPROM on a sound card without desoldering it.
This does not complicate anything.
Reply 29 of 41, by shevalier
maxtherabbit wrote on 2025-12-29, 01:05:
The PCI-e X-Fi has a jumper next to the EEPROM, which, when installed, would allow you to write to the EEPROM.
However, the configuration resistor on the write protect is set to the "disable" position , i.e. parallel to this jumper.
This is what needs to be moved.
Apparently, Creative planned to update the EEPROM using drivers, and in order to avoid problems with users, decided to allow rewriting by default.
Sound cards do not write anything to the EEPROM during operation, and there will never be any other drivers.
If a utility for on-board recording appears and the need arises, well, you'll have to install the jumper.
I don't remember whats a jumper in Audigy do.
Think just need to set it to write-protect enable.
I remember that Audigy uses EEPROM from CSI, where the ‘Write Protect’ output is marked in the datasheet as N(ot)C(onnect).
In other words, this particular IC from this manufacturer does not have the specified function.
Reply 30 of 41, by myne
So, are we effectively saying VCC is always >4.5v?
I built:
Reply 31 of 41, by georgel
shevalier wrote on 2025-12-29, 07:18:
Re: SB2AWE EEPROM flasher utility.
EDIT: Removed completely unnecessary Russia vs Ukraine reference violating community guidelines.
Reply 32 of 41, by shevalier
myne wrote on 2025-12-29, 11:43:
If this question is about my answer regarding WriteProtect, I must admit that I did not understand it.
PS. Some pic`s added
Reply 33 of 41, by jmarsh
The 24CXX series are I2C EEPROMs, not SPI. This is just getting more confusing.
I2C EEPROMs are usually a lot simpler to program in-place, since the lines are only ever driven low they are easy to tap into. You just need to wait until the bus is idle (assuming the WP pin is taken care of).
Reply 34 of 41, by shevalier
jmarsh wrote on 2025-12-29, 16:04:
I don't remember which Creative cards use the 93 series.
I have an SB0220(?) somewhere, I can check.
But the thing is, 24/93 with write protection are usually marked with the letter ‘S’ (Secure), for example, 24CS32.
And on the Audigy 2V, they didn't skimp on soldering the jumper, but used 24FC32.
Reply 35 of 41, by jmarsh
shevalier wrote on 2025-12-29, 16:51:
That is not the case, implementation of WP pin simply varies between manufacturers.
Reply 36 of 41, by myne
shevalier wrote on 2025-12-29, 14:27:
I was looking at the opcodes of the first datasheet in this thread.
The erase commands are only valid if VCC > 4.5v
I built:
Reply 37 of 41, by shevalier
myne wrote on 2025-12-30, 00:35:
https://www.alsa-project.org/wiki/Xonar_EEPROM_Failure
I am not inclined to believe that this is a hardware problem related to voltage fluctuations or ageing EEPROM chips.
Xonar is a card based on the C-Media chipset.
In addition to the ID, the EEPROM also stores code for the built-in C51 microcontroller core.
Creative also has something similar in the EEPROM for DSP code (?).
Most likely, there is competition for access between the CPU (main BIOS execution) and the internal computing core of the add-on card.
jmarsh wrote on 2025-12-29, 17:52:
I have never been able to find the datasheet for the 24FС32 from Catalyst Semiconductor (CSI).
As a result of the acquisition of Catalyst Semiconductor by ON Semiconductor, www.catsemi.com has been integrated into www.onsemi.com.
Reply 38 of 41, by shevalier
There were conspiracy theories.
Thanks to the datasheet below (founded by @myne), the CSI is CAT24FC32 with write protection.
Therefore, to prevent EEPROM corruption, owners of Audigy 2 Value/4 non-pro should simply do not install jumper JP1.
JP1 - is write enable pin
Closed (GND) - This input, when tied to GND, allows write operations to the entire memory.
Open-When this pin is tied to Vcc, the entire memory is write protected.
Reply 39 of 41, by myne
shevalier wrote on 2025-12-30, 06:36:
https://www.alldatasheet.com/datasheet-pdf/pd … /CAT24FC32.html
No?
I built:
