Reply 800 of 1253, by sharangad
- l33t
Joseph_Joestar wrote on 2025-12-11, 07:07:sharangad wrote on 2025-12-11, 04:15:SB0353 (Dell OEM), I think.
Yeah, OEM variants sometimes removed certain features to save the company a few cents. The missing AD_EXT connector on your card is one such example.
These cards can also be very picky about their drivers. Under WinXP, DanielK's Audigy pack should work, but you may also want to look into Dell's own drivers, just in case. The easiest way to find them is by looking up the relevant Dell Part Number, which should also be printed on one of the stickers on the back of the card. Whichever drivers you end up using, be sure to also install the latest version of EAX Unified and Creative's OpenAL after that.
Thanks!
I'm using it under w98se with your audigy 1 drivers. If I get around to dual booting xp, I'll look into the Dell drivers, though Danielk's would probably be easier.
https://www.youtube.com/@sharangadayananda\
https://patreon.com/Rready
