Juggling between two sound cards in DOS
Reply 100 of 112, by DustyShinigami
NeoG_ wrote on 2025-12-20, 01:07:
DustyShinigami wrote on 2025-12-19, 14:02:
I think the final piece of the puzzle would be a sound mixer, but at the moment, I need to have my speakers plugged into the Sound Blaster primarily. Especially if I want to use the SB's limited MT-32 capabilities. Otherwise with the Yamaha, I won't get music in those games.
You were extremely close to getting EK1M working as the mixer, the config file was just edited in the wrong way. I think you changed "-as line" to "-as line mix" when it should have been "-as mix"
Ohhh, okay. I can give that a try much later on, but again - unlike a physical mixer, how exactly would you control the mixing? I take it with an actual mixer you can specify the chosen card at any given time at the press of a button? With this method though, would I not still be specifying on a game-by-game basis via a BAT file? Or is there some other kind of shortcut?
OS: Windows 98 SE
CPU: Slot 1 Pentium III Coppermine 933MHz (SL448)
RAM: Kingston 256MB 133MHz
GPU: Nvidia 16MB Riva TNT/128MB Geforce 4 Ti 4200
Motherboard: ABit AB-BE6-II Intel 440BX
Sound Card: Sound Blaster Live Value CT4670
Reply 101 of 112, by NeoG_
DustyShinigami wrote on 2025-12-20, 06:35:
What you are talking about is switching - Mixing means both cards can be heard at the same time and you just leave it like that so any card can play when it wants
98/DOS Rig: BabyAT AladdinV, K6-2+/550, V3 2000, 128MB PC100, 20GB HDD, 128GB SD2IDE, SB Live!, SB16-SCSI, PicoGUS, WP32 McCake, iNFRA CD, ZIP100
XP Rig: Lian Li PC-10 ATX, Gigabyte X38-DQ6, Core2Duo E6850, ATi HD5870, 2GB DDR2, 2TB HDD, X-Fi XtremeGamer
Reply 102 of 112, by DustyShinigami
NeoG_ wrote on 2025-12-20, 06:52:
Ahh, I see. And when each one plays it depends on which IRQ and/or DMA is selected…? They surely don’t both play the same tune at the same time in a game, right…?
OS: Windows 98 SE
Reply 103 of 112, by Shponglefan
DustyShinigami wrote on 2025-12-20, 09:27:
Generally no.
Common use cases for a mixer is to have one sound card playing sound effects and another playing music. This is why in DOS game set up programs you can often choose different sources for sound effects and music.
Another common use case is to be able to use different sound cards with different games.
There are some exceptions to this, for example FM synthesis. If both sound cards are configured to the same FM port (typically 388) it's possible to have multiple sound cards playing FM sounds and music at the same time.
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 104 of 112, by DustyShinigami
Shponglefan wrote on 2025-12-20, 15:04:
Generally no. […]
Generally no.
I see. I did not know that. I missed out on so much stuff with computers growing up, mainly because of being so young and not having access to what I now have. I’ve learnt loads since using a retro PC. And it’s insightful for how things were to what things are like now. 🙂
I take it with multiple FM cards they’d play different SFX/music to each other, Increasing the scope and number of instruments being played?
I take it that doesn’t apply to modern sound cards, does it? Considering how far tech has come? Having one sound card for SFX/speech and one for music?
OS: Windows 98 SE
Reply 105 of 112, by Shponglefan
DustyShinigami wrote on 2025-12-20, 16:15:
Yes and no.
Different FM implementations will sound different. But it's not really a case where you are increasing the number of instruments per se. Just different sounding variations of the FM synthesis itself.
Once digital music recordings became common, the need for separate sound cards for sound and music become obsolete. The main reason to have separate sound/music cards is for the MT-32 and General MIDI era.
Reply 106 of 112, by DustyShinigami
Shponglefan wrote on 2025-12-21, 20:05:
Yes and no. […]
Yes and no.
Okay, great. Makes sense. So yeah, the missing ingredient(s) would be an actual MT-32 sound canvas. And a mixer. But for now, the SB's own MT-32 will do as a placeholder. 😀
OS: Windows 98 SE
Reply 107 of 112, by NeoG_
If you want a less hassle way to get every MT-32 type and good General MIDI in one device, an MT32-Pi wavetable board would give you MT-32 Rev.0, MT-32 New, CM-32L and high quality GS compatible MIDI on an internal board. I use the WP32 McCake.
But I think I saw you already have an SC-55 module so it would be a shame not to get an MT-32 to stack with it
Reply 109 of 112, by DustyShinigami
Shponglefan wrote on 2025-12-21, 21:59:
Nice thing about a real MT-32 is the LCD display.
Just the LCD display...? Not that it has proper MT-32 music...? :p
OS: Windows 98 SE
Reply 110 of 112, by NeoG_
DustyShinigami wrote on 2025-12-21, 23:05:
There are numerous modern devices that give you extremely accurate MT-32 sound (To the point where you can't easily tell the difference, or can't at all) but they would not have the physical presence or display of a real MT-32
Reply 111 of 112, by DustyShinigami
NeoG_ wrote on 2025-12-21, 23:16:
Fair enough, yeah. But the idea of owning the original hardware definitely appeals. Just a shame they cost as much as they do. ^^; That reminds me though - I still need to look into whether there's a tool/manager for adding custom sound fonts for that SB. I take it once they're loaded in Windows, they'll also work in DOS...? Or would that require an additional setup? Also, are there any recommended sound fonts to get?
OS: Windows 98 SE
Reply 112 of 112, by NeoG_
DustyShinigami wrote on 2025-12-21, 23:23:
Unfortunately the DOS drivers use a proprietary patch library format - ECW - for which there's only a few available files, the largest of which is the 8MB General MIDI file
