First post, by DrLucienSanchez
Hello there, I've acquired a Celeron 300a SL32A, as I never had one before and read exstensively about it's legendary overclocking, so wanted to try for myself.
I've got it to 100 FSB / 450MHz, however it required 2.2v to be stable at that speed, anything lower, it will BSOD. I can also run at default 66 FSB / 300MHz at a nice undervolted 1.6V.
I do have a PII 400MHZ and a PIII 733MHz as well, but just fine the 300A very interesting compared to the other two, but my concern is using the processor at 2.2V.
Heat is no issue, I have cleaned the fan, repeasted the heatsink, it does not get hot to the touch when benching at 450, and I also have a 80MM fan over my Voodoo which keeps everything well ventialted and cool.
My motherboard is an Abit BH6, recapped - I read the VRMs are good up until 2.8v, but it is an old board nontheless.
I would like some opinions on this one, yay or nay, should I even consider and overvoltage using such an old board, or stick to a more efficient Deschutes/Coppermine CPU for my aged BH6?
Reply 1 of 19, by mockingbird
Get a Costa Rica 300A.
(Decommissioned:)
Reply 2 of 19, by smtkr
They aren't all stable at 4.5 x 100. The one I have won't do it (retail SL32A).
IMO, overclock it for fun, but if you really need the extra speed, just get a faster CPU.
Reply 3 of 19, by myne
It's a 10% bump. Spec of that era is likely +/- 15%.
On silicon nodes the size of Manhattan compared to today's.
Today's voltages are barely 1/3 lower (~1.3v).
I wouldn't worry about it as long as the board's voltage is fairly stable.
Infact, if the caps are original, the extra voltage might simply be masking unstable caps.
If you really want to be safe, replace all the big caps near the cpu (usually 1200-1500 6v) and you might be surprised to see it stable at 2v.
I built:
Reply 4 of 19, by zyzzle
I had an SL36A Celeron 300a that overclocked to 558 mhz (124x3.5) at 2.0V and it would even run at 600 mhz at 2.3V but unstable. A 100% overclock. It was legendary. Best overclock ever. I'm not sure if I still have that chip or not. It's been about 27-28 years ago. I remember I was running it on an Abit BH6 motherboard.
Reply 5 of 19, by DrLucienSanchez
I think it's just the processor itself. The BH6 has been recapped, I can run my Deschutes 400 at OCd 126 FSB stable with 2.0v. It was fund to OC and use such a legendary CPU though and one off my list of things to do.
Reply 6 of 19, by shevalier
If I'm not mistaken, the maximum frequency in Mendocino is 533 MHz.
Therefore, anything below ~500 MHz is simply a mediocre processor one — just a big loss in the “silicon lottery”
133 MHz FSB for Mendocino is an impressive result (from 600 MHz CPU core).
The rest of the average results should be around 500 MHz.
Aopen MX3S, PIII-S Tualatin 1133, Radeon 9800Pro@XT BIOS, Audigy 4 SB0610
JetWay K8T8AS, Athlon DH-E6 3000+, Radeon HD2600Pro AGP, Audigy 2 Value SB0400
Gigabyte Ga-k8n51gmf, Turion64 ML-30@2.2GHz , Radeon X800GTO PL16, Diamond monster sound MX300
Reply 8 of 19, by shevalier
ott wrote on 2025-12-22, 19:06:
mockingbird wrote on 2025-12-21, 15:11:
I have 300A SL2WM (MALAY), is it much worse?
Stepping was important when purchasing these processors at the that time—a preferable stepping means a higher probability.
At the moment, there are only two questions about your specific processor:
- Stable operation at an FSB frequency of 100 MHz.(Its the "classic" overclocking for Mendocino in thats time)
- Stable operation at an FSB frequency of 133 MHz (you very lucky, its result better then almost any P2 performance)
Reply 9 of 19, by ott
300A SL2WM (MALAY) is much worse?
It seems to be a myth, both CPUs from COSTA RICA and MALAY are OK and acceptable for overclocking.
I tried to find any info about best 300A chips and everyone recommends their own CPU 😀
The attachment malay-300a.png is no longer available
Reply 10 of 19, by myne
The fabs were never in either country.
The chips were cut from the wafers and put on the pin package there.
I built:
Reply 11 of 19, by shevalier
It is traditionally believed, and I tend to agree, that later processors have better frequency potential.
When the output of usable processors reaches its maximum, but supply contracts are concluded for low-frequency ones.
As a result, 533s are marked (programmed by burning fuses) as 300A.
Therefore, it is not the factory that packages the die that is important, but the date of manufacture.
That way, the chances are greater.
Reply 12 of 19, by subhuman@xgtx
Mine does 600mhz at 2.2v but temperatures will skyrocket, upwards of 65c, even with an all-copper Thermaltake Volcano cooler.
My experience tells me a better cooling solution would let me decrease vcore down to 2.1
Bear in mind I usually post to the forums using my old systems.
Reply 13 of 19, by rasz_pl
subhuman@xgtx wrote on 2026-04-12, 22:44:
what? is that on cryo cooling or something? 250nm tapped out after ~500MHz
Reply 14 of 19, by bofh.fromhell
I have one of those golden chips too:
Stable as far as I'm concerned, tho I haven't done any insane 2 week CPU burn thingys.
And I also have a SLOT1 C300A that will not even post at 450 however i tweak.
Reply 15 of 19, by subhuman@xgtx
That is on a standard socket 462 copper cooler (Thermaltake Volcano 9). I also have a cacheless Celeron 266 which I really like but that won't go anywhere beyond 420-443 mhz.
Reply 16 of 19, by myne
Lol 65c
Oh noes! A rock got +40 over room temperature!
I used to pull the hsf off mine while it was running just to show the athlon boys that it wouldn't burn.
It took minutes to crash while running q3 timedemo
I built:
Reply 17 of 19, by subhuman@xgtx
myne wrote on 2026-04-13, 01:55:
Lol 65c Oh noes! A rock got +40 over room temperature! I used to pull the hsf off mine while it was running just to show the ath […]
Lol 65c
Maybe I could run it at 450/100 without a heatsink but at 600 it's a whole different story, it can get quite unstable if you don't really care about temps
Reply 18 of 19, by PcBytes
I have a 400 Mendocino here (genuine cartridge model off a Dell G1, SL39Z). Any chances I can get it higher with the BH6 or am I cooked and better off with anything else?
Reply 19 of 19, by myne
400/66=6
100*6=600 =unlikely.
75*6=450= probably
83*6=498=maybe
I built:
