NeoG_ wrote on 2025-12-22, 22:28:
I've been kepeing my eye out for a combo floppy for a while but the prices are somewhat eye watering
Although it might be nice to have both drive types in one slot, I'm not sure I'd be comfortable in relying on a drive that is irreplacable (or at least would be very expensive to replace - if you could find one).
As you might guess, over the years I've used a LOT of floppy drives, and have seen enough of them fail that I still have a good stack of replacements.
And... since this has been mostly ImageDisk related, I usually had to switch between many different drive types:
5.25" 40-Track DD (360k)
5.25" 80-track HD (1.2m)
5.25" 80-track DD (720k)
3.5" 80-track DD (720k) *1
3.5" 80-track HD (1.4m) *1
8" 77-track
*1: Yes, there were some disk types I had to use an actual DD drive, to reliably read on some controllers.
And there were sometimes cases where I needed to use actual single-sided drives.
So... I have come up with ways to more easily add/change a second drive on a system without having to have "slots" for them all:
Re: TexElec Quad-Flop (FDC) and Windows 95
https://dunfield.themindfactory.com ; "Daves Old Computers" ; SW dev addict best known:
ImageDisk: rd/wr ANY floppy PChw can ; Micro-C: compiler for DOS+ManySmallCPU ; DDLINK: simple/small filetransfer(w/o netSW)via Lan/Lpt/Com
