First post, by darkfalzx
I'm trying to get my dumpster-find Gateway 2000 PC fully working. It came with an Epson SD-800 5.25"/3.5" combo drive. Both parts of the drive seem to work fine (3.5" works if I hook it up crossed, 5.25" - if straight), but I can't seem to be able to get both drives working simultaneously. Does anyone have experience with these? Do I need special drivers?
Reply 1 of 14, by wbahnassi
Yes I have one that I used extensively. It is pretty much plug and play. Plug the ribbon cable and it will operate both drives. You have a jumper to decide which would be A and B.. that's about it. For the BIOS just set A as 1.2MB and B as 1.44MB. If POST complains about bad floppy drive settings, flip them and you're good to go.
The ribbon cable doesn't even need to have a twist. It is just going to flip the drive assignments one more time.
Turbo XT 12MHz, EGA, MFM HDD
Intel 386 DX-33, Speedstar 24X, SB 1.5, 1x CD
Intel 486 DX2-66, CL5428 VLB, SBPro 2, 2x CD
IBM BlueLightning 100MHz, CL5428, SB16, 4x CD
Intel Pentium 90, Matrox Millenium 2, SB16, 4x CD
HP Z400, Xeon 3.46GHz, YMF-744, RTX2060
Reply 2 of 14, by darkfalzx
Ah! Interesting. In the bios it only showed up as a single drive, so I assumed it's not recognizing the dual setup, but once I set drives A and B to 5.25" and 3.5" it just worked in spite of saying drive B isn't installed.
I know these drives are pretty desirable/expensive, but are they reliable?
Reply 3 of 14, by DaveDDS
Does your BIOS actually detect a second drive (B:) if it's not set up.
I know some BIOSs didn't.
Presumably this thing show up the same as two drives - I don't see how BIOS could tell the difference.
You could try my ImageDisk and do floppy operations/test on both drives and see if it has any problems, this might help detect if there are any actual differences from two distinct drives.
ImageDisk accesses the floppy drives/controller directly and does not go through BIOS (in fact I keep the drives set to "None" on my ImageDisk system to keep anything else from messing with them). If it does detect "problems" that might help figure out what exactly is different from two separate drives.
- Dave ; https://dunfield.themindfactory.com ; "Daves Old Computers" ; SW dev addict best known:
ImageDisk: rd/wr ANY floppy PChardware can ; Micro-C: compiler for DOS+ManySmallCPU ; DDLINK: simple/small FileTrans(w/o netSW)via Lan/Lpt/Serial
Reply 4 of 14, by wbahnassi
darkfalzx wrote on 2025-12-22, 16:51:
It worked great for me. The only downside is the difficult maintenance. It is much harder to clean the heads should they get dirty.. so if you plan to use the drive with disks from bad storage, you'll hate it. Otherwise it served me really well. No complaints.
I used it in my Lego PC build because I was aiming for a fully featured yet-compact form factor.
Lego PC - Traditional Damascus Theme
Reply 5 of 14, by NeoG_
I've been kepeing my eye out for a combo floppy for a while but the prices are somewhat eye watering
98/DOS Rig: BabyAT AladdinV, K6-2+/550, V3 2000, 128MB PC100, 20GB HDD, 128GB SD2IDE, SB Live!, SB16-SCSI, PicoGUS, WP32 McCake, iNFRA CD, ZIP100
XP Rig: Lian Li PC-10 ATX, Gigabyte X38-DQ6, Core2Duo E6850, ATi HD5870, 2GB DDR2, 2TB HDD, X-Fi XtremeGamer
Reply 6 of 14, by darkfalzx
DaveDDS wrote on 2025-12-22, 19:28:
Initially, BIOS only shown drive A: installed, but allowed me to configure both A: and B:. Once I set them up and rebooted, the second drive just showed up like it was always there. No additional software needed in either DOS or Windows 95!
NeoG_ wrote on 2025-12-22, 22:28:
It's basically two completely independent drives sandwiched together, presenting a really neat and compact front, but looking really awkward on the inside. I didn't even know such things existed until literally pulling one out of a dumpster.
Reply 7 of 14, by DaveDDS
Although it might be nice to have both drive types in one slot, I'm not sure I'd be comfortable in relying on a drive that is irreplacable (or at least would be very expensive to replace - if you could find one).
As you might guess, over the years I've used a LOT of floppy drives, and have seen enough of them fail that I still have a good stack of replacements.
And... since this has been mostly ImageDisk related, I usually had to switch between many different drive types:
5.25" 40-Track DD (360k)
5.25" 80-track HD (1.2m)
5.25" 80-track DD (720k)
3.5" 80-track DD (720k) *1
3.5" 80-track HD (1.4m) *1
8" 77-track
*1: Yes, there were some disk types I had to use an actual DD drive, to reliably read on some controllers.
And there were sometimes cases where I needed to use actual single-sided drives.
So... I have come up with ways to more easily add/change a second drive on a system without having to have "slots" for them all:
Re: TexElec Quad-Flop (FDC) and Windows 95
Reply 8 of 14, by DaveDDS
darkfalzx wrote on 2025-12-23, 02:44:
I did get that - I was just wondering if there is "something enough different" about this drive that BIOS didn't detect it when I would have detected a "normal" B: drive.
To test this, you need to connect an actual second drive as B:, clear/reset BIOS and see if the system finds it.
Probably not worth doing now as you've figured out a workable solution.
Reply 9 of 14, by weedeewee
DaveDDS wrote on 2025-12-23, 11:40:
I did get that - I was just wondering if there is "something enough different" about this drive that BIOS didn't detect it when […]
the guy just didn't have his second floppy drive defined in the bios. there is nothing more to wonder about.
Do not ask Why !
Reply 10 of 14, by NeoG_
It sounds like darkfalzx was saying the BIOS was not "detecting" the B drive, but it was just the previous configuration unchanged with a single drive A: set and drive B: unset. I guess they thought the BIOS would detect the floppy drive type automatically.
Reply 11 of 14, by DaveDDS
NeoG_ wrote on 2025-12-23, 12:24:
Yeah, I'd guess thats what happened. From the initial posts I though that this mainboard was expected to auto-detect drive B:
Most BIOS detect drive A: - many don't detect drive B: (but some do).
The big problem with BIOS auto-detect is that it can't tell some drives apart without "stressing" the drive.
You *can* tell a 360k from a 1.2m by stepping out past track 39 then counting steps back till track0 detect comes on, but most 40track drives will go a few tracks past 39 - so you have to step far enough to insure it hits the stop, and not knowing the drive you have to go 10 or more tracks past 39 - which "hits the stop" every time to try to step past the stop - and there is indicator to tell the PC it's hit the stop...
And even if you detect 80 tracks, is it a 5.25" or 3.5"? If the latter is it HD or DD?
Most BIOS will try to detect drive A: and make a "guess" as to the most common drive type at the time it was made... Basically trying to reduce the number of "my new PC doesn't boot" tech support calls.
Reply 12 of 14, by DaveDDS
weedeewee wrote on 2025-12-23, 11:54:
Well... you could "wonder" why the "the drive I just installed doesn't work"? ... As I tried to explain, this gave the impression that it was either configured or expected to be auto-detected.
We didn't learn till later that it wasn't configured, leaving "expected to be auto-detected" as the thing that didn't work.
I couldn't think of a reason a dual-drive would be functionally different ... but I've not personally had one, and I like to know as much about the various drives available as I can.
Reply 13 of 14, by weedeewee
DaveDDS wrote on 2025-12-23, 15:33:
Well... you could "wonder" why the "the drive I just installed doesn't work"? ... As I tried to explain, this gave the impressio […]
There's nothing different about it aside from the 5"1/4 drive is thinner, and the 3"1/2 drive is like a laptop drive.
Squish those together, add an interface board so you only need to hook up one connector and you get one of these "dual" drives.
I've never known any consumer ibm-pc bios to autodetect the floppy drive,
and I do not want to go off on a tangent here.
Do not ask Why !
Reply 14 of 14, by DaveDDS
weedeewee wrote on 2025-12-23, 16:01:
Exactly as I suspected - good to have confirmation!
I have seen a few - more common before HD and 3.5" drives were a thing (all PC drives were the same back then) - and agreed, no need to go on a tangent.
