First post, by elmatero
Has anyone run successfully ToCa 1 with Ati Rage II video mode selection?
I had run it on RAGE IIC PCI and RAGE PRO (PCI and AGP) using early 1998 drivers and 1999 drivers with ATI CIF-s Support, but always I've got rainbow pallet of colors.
Maybe ATI IIC and PRO is too late for this mode? Can someone try to run it on classic Rage II?
ATX 1998 build: IBM 6x86MX-PR266@208MHz on Tekram P5MVP-A4, 128MB SDRAM, Ati Rage Pro Turbo AGP 2X 8 MB SGRAM, Yamaha YMF719e, Adaptec 1200A IDE 100, Windows 95b
Reply 1 of 5, by vvbee
It's Direct3D with tweaks for various chips. Use 16 bit on the desktop and test earlier drivers.
Reply 2 of 5, by elmatero
ATI Rage IIc earliest drivers are from fabruary 1998 and still color palete is inncorect. On ATI Rage pro i used 4.10.2227 form 1997 its probably first driver for this card, issue still exist. On desktop i try 16 bit and 256 colors.
So maybe this mode really only classic Rage II compatible.
Reply 3 of 5, by vvbee
Use older Rage II/+ drivers with a modified INF. If that can't be done then you can assume the IIc is different enough from the II. Probably all the game's Rage II mode does is apply workarounds for some rendering issues and maybe downgrade some visual elements for performance.
Reply 4 of 5, by marxveix
I will test this game with my drivers. Thank you!
I did run this game with Rage2+DVD 2MB PCI up to Rage XL 8MB AGP, all of them has the same issue.
If you choose Auto-Detect, S3 or Riva128, you can play it with Rage2 or Rage3 cards with no problem.
I will check this game more, but i think its Direct3D game.
Best ATi Rage3 drivers for 3DCIF / Direct3D / OpenGL / GLUT / DVD : ATi RagePro drivers and software
33+MiniGL / OpenGL Win 9x dll files for all ATi-Rage3 based cards : ATi RagePro OpenGL files
Reply 5 of 5, by marxveix
It got bit intresting, if i turn off international rally championship 1997 game d3d,
i can get similar picture as top post Toca1 ( RageII ) and this game has ati 3d logo.
If i use forced3d 0 (default is disabled, not used command or forced3d 1 option).
forced3d 1 ; This forces the program to use d3d drivers, not card specific drivers.
Re: ATi RagePro supported games
Toca1 game with original RageII, not RageII+, similar as before 🙁
