First post, by Putas
For the first time, I am forced to use the first release of Windows 95. The solutions I was used to are not working here. Dependencies like the USB supplement cannot be installed. How do you guys handle CD images under such conditions?
Reply 1 of 10, by marxveix
Try Virtual CD-ROM v1.01, its for Win95, but it has its own image format as i member, you have to convert images.
Best ATi Rage3 drivers for 3DCIF / Direct3D / OpenGL / DVD : ATi RagePro drivers and software
30+MiniGL / OpenGL Win 9x dll files for all ATi Rage3 cards : Re: ATi RagePro OpenGL files
Reply 2 of 10, by Putas
marxveix wrote on 2025-12-17, 06:28:
It works well, and the compression feature makes the conversion worthwhile for me. Thank you!
Reply 4 of 10, by marxveix
Putas wrote on 2025-12-18, 15:44:
I have used it view times, good that it works well for you.
Now i usually use Win95B and there even DaemonTools works with some extra needed files.
Reply 5 of 10, by leonardo
marxveix wrote on 2025-12-18, 17:56:
Now I usually use Win95B and there even DaemonTools works with some extra needed files.
Would you mind sharing which version of DaemonTools is still compatible (with B / OSR2) and which support files you need in order for it to run?
[Install Win95 like you were born in 1985!] on systems like this or this.
Reply 6 of 10, by Linoleum
After extensively testing both Daemon Tools and Virtual CloneDrive, I ultimately chose Alcohol 120% v1.4.7.1005 for all my Windows builds (from 95 to XP). I It’s the only solution that consistently avoided issues with Windows hanging during the shutdown process.
P3 866, V3, SB Audigy2
P2 400, TNT, V2, SB Audigy2 ZS
P233 MMX, Mystique220, V1, AWE64
P166, S3 Virge DX, SB32, PicoGus
486DX4 100, CL-GD5424, SB32, SC55
Prolinea 4/50, ET4000, SB16
SC386SX 25, TVGA8900D, Audician32
286 10, ATI VGA Basic, Forte16
Reply 7 of 10, by marxveix
leonardo wrote on 2025-12-18, 21:57:
Same Daemon Tool that you use for Win98/Win98SE/ME, i have been using it with Win95B / OSR2 (Smallest Floppy Disk Edition).
Instructions i got from this forum somewhere.
Daemon Tools for 95b or 95c instrctuions ( No IE4 bloatware, at least with B )
1. install InstMsiA.exe
2. "Microsoft MCI CD Audio"(control panel--add new hardware--no--sound,video--Microsoft MCI--CD audio device(need win95cd), reboot
3. install usb supplement (Usbsupp--reboot) (need SCANDSKW.EXE to /WINDOWS).
(Cant rembember any scandskw.exe /windows, just installed usb supplement or xusbsupp, do it if its need it - Scandisk it does automatically)
4. copy to /WINDOWS/SYSTEM
riched32.dll(cab5)
WINSPOOL.DRV (cab4)
SETUPAPI.DLL (ie4)
CFGMGR32.DLL(ie4)
5. install Daemon Tools
If you want, i have those files already, but i think you can extract them and find them.
Reply 8 of 10, by leonardo
marxveix wrote on 2025-12-18, 22:17:
Which version is this? 3.47?
Linoleum wrote on 2025-12-18, 22:06:
Thanks for the tip - I'll consider Alcohol as well. I don't really do disk images since I have most of my game disks (and CD-drives) in very good condition, but there may come a time when the disks/drives start breaking down and I might want to be ahead of that situation.
Reply 9 of 10, by marxveix
leonardo wrote on 2025-12-19, 23:05:
Its the same Daemon Tools 3.47, downloaded from here.
https://www.philscomputerlab.com/daemon-tools … windows-98.html
Reply 10 of 10, by Putas
The software said there are 15 days to try it, but only several days later, it behaves as if the trial time has expired.
